Old 14th May 2016, 12:58   #5506
Thanked: 104 Times
Default Re: The KTM Duke 390 Ownership Experience Thread
Originally Posted by nitninja View Post
There seems to be a rattling sound emanating from the big black box near the suspension , something like a metal rattling inside.Im guessing the sound is coming from the catalytic converter.Has anybody else faced a similar problem ?
A picture to liven up the thread
There is nothing in there that should be able to rattle, can you tighten the bolts a bit and see if it makes any difference. The bottom chrome bit is mounted by two bolts underneath the exhaust. If that doesn't help you'll need to go to a workshop or service station.
amitc7 is offline   (1) Thanks Reply With Quote
Old 14th May 2016, 14:36   #5507
schakravarthy's Avatar
Thanked: 4,051 Times
I'm using this charger on my bike-
http://m.aliexpress.com/item/1725875...bilesitedetail
Bought it an year ago from Aliexpress, along with tank traction pads and MRA replica visor.
I've connected the charger to the accessory wires provided in the headlamp unit. Works fine, does the job; I'm happy.
schakravarthy is offline   (3) Thanks Reply With Quote
Old 14th May 2016, 14:42   #5508
b16h22's Avatar
Thanked: 114 Times
If you are talking about the tick-tick sound coming from the exhaust after switching off the bike, it is just the metal inside cat-con cooling down and contracting.
b16h22 is offline   (2) Thanks Reply With Quote
Old 14th May 2016, 20:52   #5509
Thanked: 143 Times
i checked the bolts and they seem tight, no loose nuts nothing.I will take the bike to service centre on tuesday.Thanks.
Its not the ticking sound.The sound comes when the bike is in idle or during riding the bike.The sound seems to be coming from the bottom of the silencer when checked today evening.
nitninja is offline   Reply With Quote
Old 14th May 2016, 21:38   #5510
Thanked: 1,095 Times
Infractions: 0/1 (5)
It is from the catalytic converter, a couple of my friends had this issue and the black box was replaced as it was in warranty. Get in touch with the SVC and press for the replacement.
unk9ja is offline   (2) Thanks Reply With Quote
Old 14th May 2016, 22:13   #5511
Thanked: 143 Times
Did they replace the whole silencer or only the black box in warranty ? I feel whole silencer replacement would feel better in the long run.
Old 15th May 2016, 19:37   #5512
It was only the black box, the other side is just fine. Since this is a closed and sealed part, and with no repairs are possible, the black box was replaced.
unk9ja is offline   Reply With Quote
Old 15th May 2016, 20:05   #5513
barcalad's Avatar
Thanked: 1,150 Times
A friend doing Ladakh this season from Delhi just got these fitted on his bike.
Front - Michelin Sirac Tubeless - Rs. 1700
Rear - MRF Meteor Mogrip - Rs. 2400
barcalad is offline   (3) Thanks Reply With Quote
Old 15th May 2016, 21:01   #5514
Nice looking shoes. One question, does the front tyre scrape the mudguard? Ask his take on this setup vis a vis Metz.
Old 15th May 2016, 22:50   #5515
barcalad's Avatar
It's not scraping the mudguard yet. Running fine as of now.
Regarding Metz, I'm waiting for him to ride on the new shoes for a few days before I ask him. I myself will be riding it this weekend or next and shall post my opinion as well.
barcalad is offline   (1) Thanks Reply With Quote
Old 15th May 2016, 23:08   #5516
Urban_Nomad's Avatar
Thanked: 1,329 Times
Thanks for sharing
Did the sirac have to be flipped over? I think it's actually a rear application, hence the question
Also, the meteor - is it a 100 section? If so, it's definitely pushing the boundaries of how skinny you can go on a rim designed to take a 150 section
Finally - do you know where he sourced these from?
Look forward to your comments on their on-road performance
Urban_Nomad is online now   Reply With Quote
Old 15th May 2016, 23:53   #5517
Thar4x4's Avatar
Thanked: 666 Times
My Duke almost ready to rock the Zenskar roads.
Front : Michelin Sirac 100/90/17 = 1900
Front mudguard is scraping so removed and tried some off road mudguard however no use as it fits on single clip and come down from front and hit badly on tyre on full suspension travel. Wasted 700 Rs on this mudguard and removed in single day. Used the drawing sent by Uday (unk9ja) and it did a fantastic job in just 100 Rs.
Rear : CEAT Vertigo Rage 130/80/17 = 3250
Initial impression is the I am not feeling any difference except I can go must fast on bad roads now. Have been used in city till now so can't comment however have touched 90 on open stretch and no change in braking.
Thar4x4 is offline   (2) Thanks Reply With Quote
Old 16th May 2016, 05:27   #5518
Meccanico's Avatar
Thanked: 141 Times
Could you please share with me the drawing you mentioned for the front off road mudguard? I literally used the same one on my Duke 200 and it broke on the first full suspension travel.
Meccanico is offline   Reply With Quote
Old 16th May 2016, 08:13   #5519
Red Liner's Avatar
Thanked: 1,208 Times
Could you please send me the drawing too. Uday is in Bangalore and we have someone we know in common so I will reach out to him as well, as I might be doing this for another bike and not the Duke.
Red Liner is offline   Reply With Quote
Old 16th May 2016, 11:52   #5520
barcalad's Avatar
Originally Posted by Urban_Nomad View Post
Thanks for sharing
No, they were fitted normally and were a direct fit. No flipping.
The front is stock. The rear is 140/70.
They were sourced from Globe Engineering, Carol Bagh.
Initial reports suggest that the handle feels lighter, ride is smooth and the tyres turn heads.
KTM Duke 390 - Accessories Thread sridhu Motorbikes 118 22nd December 2017 17:19
Duke of Ram - My Orange Flame, KTM Duke 390. EDIT : Sold! hillram Motorbikes 65 13th May 2016 07:21
India made KTM Duke 390 & RC 390 to be sold in the USA Tushar Motorbikes 1 7th January 2015 13:59
My Flamberge (KTM Duke 390) Ownership report - A middle aged man's perspective sridhu Motorbikes 165 1st April 2014 07:46
KTM Duke 390 - 375cc, 45 PS, 150 kg djay99 Motorbikes 620 25th June 2013 12:45
