Old 21st June 2016, 15:45   #5611
barcalad's Avatar
Thanked: 1,150 Times
Default Re: The KTM Duke 390 Ownership Experience Thread
Originally Posted by Siddy View Post
Glad to know we are in the same boat As you mentioned you service the bike as per your requirement, what interval do you follow now? How often do you change oil? TIA.
Over the past 1 year, my usage of the motorcycle has reduced drastically. It sees the light of the day only once/twice a month, else it's kept under wraps. Hence, getting it serviced according to the normal schedule and changing the oil doesn't make sense, as it doesn't run like a normal 390.
Therefore, I change my oil every 6-7k, sometimes even more (went upto 9k without oil change). I also keep an eye on the behaviour of the bike (like harder gear change) and if it warrants, I get the oil changed.
The dust problem here in NCR demands a cleaning of the air filter every time I pull the bike out. In the last 1 year, I have changed the air filter twice already even though the bike hasn't run enough to require that change. The air is that bad here!
barcalad is offline   Reply With Quote
Old 22nd June 2016, 09:16   #5612
timuseravan's Avatar
Thanked: 335 Times
Yes I'm gonna follow the manual for now, later on I plan to follow the 120 day schedule, sticking to the 7500 km window would be a problem for me because I ride only on weekends and 7500 kms would take up huge time.
I plan to keep the 390 for a longtime, it takes care of all my needs. Won't be upgrading for another 3-4 years.
Post warranty period there is no need to service the bike/change oil every 120 days. The oil and other consumables do not degrade. So stick to 7500km.
Originally Posted by VW2010 View Post
Actually as long as your downshifting was already rev matching you would hardly see or feel the difference what the slipper clutch provides. Atleast thats what i felt. I tested back to back a pre slipper clutch RC390 vs newer RC390. Both had their rev limiter disabled meaning i was able to rev it hard. The slipper clutch was good specially coming out of the curves where you didnt have to rev match as you got out shifting down and the acceleration was linear throughout.
But its personal feedback and to me not having a slipper clutch is not a problem. In fact i am today searching for the 2013 early KTM 390 models to pay may be 50% of current market price. There are so many virgin KTm 390 from 2013 that was hardly used or abused and the delta difference to me is not worth plunging say 2.2L today. Also with 2017 on the way i am sure these 2013 KTM's can be had on or around 1L which is a killer deal and they have run less than 5K kms so far.
Good decision to go for a older bike. A con of slipper clutch is the reduced engine braking. If you manage to use it right (and you don't drive in traffic regularly) engine braking is a very useful tool in riding.
But I think 1 lakh for 2013 bike with less than 5k km is very optimistic
The new ones go for 2.2 lakh on road and the 2017 will come with a small price bump.
timuseravan is offline   Reply With Quote
Old 22nd June 2016, 09:35   #5613
VW2010's Avatar
Thanked: 2,089 Times
You will be surprised how many 2013 bikes with 5 to 7k miles and getting sold at 1.2 to 1.1 today. With 2017 announced its definitely possible to see more Virgin ones showing its avatar and probably optimistic to get it for the 1 to 1.2 bracket.
Rc390 with slipper clutch was sold for 1.7 and 2013 390 with 5k miles for 1.2 just a week back. I was probably a little greedy to miss them
VW2010 is offline   (3) Thanks Reply With Quote
Old 25th June 2016, 12:14   #5614
Thanked: 185 Times
Hi guys, can anyone who gets a lead on the 390 in Mumbai post it here? I am looking for a good specimens but unable to find one. I guess someone who is a part of KTM community may have some leads.
2000rpm is offline   Reply With Quote
Old 28th June 2016, 22:07   #5615
CGB
CGB's Avatar
Thanked: 166 Times
Just wrapped the sides of the bike with CF wrap! Bhpians, your reviews please !
CGB is offline   (1) Thanks Reply With Quote
Old 29th June 2016, 09:31   #5616
Thanked: 31 Times
This sure looks the part. Is this enhancing grip at all?
Kameshwar is offline   (1) Thanks Reply With Quote
Old 29th June 2016, 10:32   #5617
CGB
CGB's Avatar
Thanked: 166 Times
Grip is okay! But prevents scratches due to knee armours on the side of the tank!
CGB is offline   Reply With Quote
Old 29th June 2016, 10:54   #5618
Siddy's Avatar
Thanked: 89 Times
Originally Posted by schakravarthy View Post
Ready to race.. but do check if all the bolts are tightened before you set off.
Quality issues have been a part of KTM in India it seems.
The side stand on my 1 month old duke has paint chipped off at one place (due to my riding boots rubbing at that point maybe) & I could see rust forming. Quickly cleaned it and applied black nail polish to arrest the rust.
Secondly, I could see another small rust spot on the rear tyre hugger's metal pipe (the one that goes around the rear tyre), gave it the same nail polish treatment. Normally people won't notice it, but when you sit next to your bike with a stool and wash it properly, such small quality issues are evident.
Siddy is offline   (1) Thanks Reply With Quote
Old 29th June 2016, 14:10   #5619
ashwin1224's Avatar
Thanked: 232 Times
" Lower portion of mudguard fell off somewhere. Heard a strange noise early morning while riding, didn't stop... maybe it was the mudguard saying goodbye 🤔 "
This was an issue in my late '13 390. I believe it was solved in the later batch with new bolts. The problem was that the bolts KTM had used to fasten the mud-flap to the fender were of poor quality, and got loose quickly and promptly fell off. Later on KTM started using different type of bolts to fix the mudflap and the mudflap is now rock solid.
It is strange that your friend has a new bike and is again facing this issue. I have not seen this being reported for the newer lot bikes
ashwin1224 is offline   Reply With Quote
Old 29th June 2016, 15:35   #5620
Vignesh_N/A's Avatar
Thanked: 126 Times
Smile Re: The KTM Duke 390 Ownership Experience Thread
The finish looks fairly good. Where was it done in Chennai?
Vignesh_N/A is offline   (1) Thanks Reply With Quote
Old 30th June 2016, 16:24   #5621
CGB
CGB's Avatar
Thanked: 166 Times
My friend has a private garage. He did it for me
Old 30th June 2016, 18:28   #5622
Thanked: 126 Times
I happened to meet a fellow from Naked Wolves who had subtle designs on his 200 NS done by Knight Auto Customizers. They seem to have quite a good number of wraps on their portfolio. Do check if you haven't been there before.
Vignesh_N/A is offline   Reply With Quote
Old 1st July 2016, 13:17   #5623
CGB
CGB's Avatar
Thanked: 166 Times
I did the same previous wrap from them. But now the prices have gone up as the portfolio increased.
Old 1st July 2016, 14:03   #5624
noo.b's Avatar
Thanked: 57 Times
Okay so its been almost two months that I have owned the bike and I now have clearer opinion on it, now that the initial euphoria has died down.
Things I love
  • Acceleration - though initially it did scare me but now I am used to it, great nonetheless
  • Handling - its very flickable in city unlike my R15 and also great at leaning
  • Tyres - Enough has been said here about the tyres already and I can't think of anything else
  • Heat dissipation on the 2016 variant - its substantially better than the earlier dukes and its now bearable to ride this bike in stop and go traffic.
  • Strong Midrange - During my trip to Narkanda with my wife and luggage the bike was cruising at a steady 125-130 without breaking a sweat.
Things I hate
  • Brakes - I just hate the brakes on this bike, the feedback is just not there. I will probably upgrade to Brembo pads once these ones get worn out
  • Seat stiffness - While its softer than the earlier bikes its still not great. On my trip to Narkanda both I and my wife had to take frequent bum breaks, the pain at times was unbearable. It was a terrible site too, on the return leg of journey we actually bought additional towels and out them on our respective seats . But honestly this isn't meant to be a tourer so one cant blame KTM for this. I will have to come up with a solution myself
  • Fuel tank range - I could have done with a better range, I lost count of the number of times i refueled on my trip.
  • Front end doesn't feel too planted - I am a cornering junkie and I felt that the front is a little too light and times moves around while cornering hard on less than perfect surfaces, but I had always known this and made a conscious decision to buy the duke over the RC for the other benefits it offers so have no one else to blame.
I have completely stopped using my car ever since I bought the bike, also with my new job my office is just about 2 kms from my place. In a car I actually take more time to find a parking spot than driving to the office.
In this time I picked up the Via Terra Raptor tail bag that I use for my office commutes ( to avoid looking like a dork while carrying my laptop bag and my lunch that I usually carry along ) and the Via terra velox which I used on my trip to Thanedar and Narkanda, both of which are absolutely top notch and total bang for the buck.
I still consider this to be the best bike one could buy at this price point, Iplan to upgrade to a Z 800 whenever I have enough dough but I would definitely keep this one with me for the fun one can have on it.
Adding some pics of the bike as well as some pics from my trip
noo.b is offline   (5) Thanks Reply With Quote
Old 1st July 2016, 21:16   #5625
Thanked: 126 Times
IMO Duke is not exactly suited for doing long trips with a pillion. Given the acceleration, the pillion has to sit closer to the rider at all times. Else they will be in constant fear of toppling over, every time you start from standstill. The grab rails are not of much use either. Even a firm grip on grabrails wont make things better.
KTM Duke 390 - Accessories Thread sridhu Motorbikes 118 22nd December 2017 17:19
Duke of Ram - My Orange Flame, KTM Duke 390. EDIT : Sold! hillram Motorbikes 65 13th May 2016 07:21
India made KTM Duke 390 & RC 390 to be sold in the USA Tushar Motorbikes 1 7th January 2015 13:59
My Flamberge (KTM Duke 390) Ownership report - A middle aged man's perspective sridhu Motorbikes 165 1st April 2014 07:46
KTM Duke 390 - 375cc, 45 PS, 150 kg djay99 Motorbikes 620 25th June 2013 12:45
