Old 21st February 2017, 14:00   #5941
Urban_Nomad's Avatar
Thanked: 1,313 Times
Default Re: The KTM Duke 390 Ownership Experience Thread
I think the chain slap has always been a part of the 390 package. My opinion on what causes it:
- different level of tautness at different points in a chain : put up your bike on a paddock stand and rotate the wheel. You will most likely see the chain "hop" at certain intervals. Usually caused by a tight chain linkage. Lot more pronounced at lower rpm than high
- rough idle : variation of the rpm in idle would suggest a rough idle. In my experience, every single 390 has it. On low rpm, this constant change in RPM can cause the chain to hop
My recommendation:
- don't worry too much about it. It's one of the unfortunate traits of what's overall an awesome motorcycle. Just keep your chain tightened and lubed properly and you should be fine
- try a different chain sprocket combo to see if the situation is any better. I think rolon makes a kit for dukes
All the best guys! Ride safe
Urban_Nomad is offline   (3) Thanks Reply With Quote
Old 21st February 2017, 16:29   #5942
scarecrow's Avatar
Thanked: 154 Times
Faced an issue with my Duke 390 recently. Specifically, the radiator fan failed. This was changed under warranty and i was only charged for the labour i.e INR 150.
The symptoms were (for the benefit of all)
- Initially i used to get a burning smell i.e. while starting the bike, something like when water is put on a hot surface like the silencer
- Then the low battery sign showed up (twice)
- Finally during a ride, i saw the high coolant temperature message and the bike shut down.
I let the bike cool down and took it to the service station immediately. They checked everything from the sensor, to the battery, etc. and finally it was narrowed down to a fan which was slowing down.
They have changed the fan. Have been running the bike for the last few days and thankfully no issues have cropped up till now.
Ride Safe
Ronald
scarecrow is offline   Reply With Quote
Old 21st February 2017, 18:00   #5943
Thanked: 143 Times
Originally Posted by Siddy View Post
Hey guys, need some help!
After the oil leaks from the valve cover now my coolant is disapearing No external leaks, no white smoke, oil is not milky, no traces of oil in the coolant (reservoir), I'm losing approximately 5 mm in the reservoir for every 400 kms ridden. What could be the issue? Busted head gasket?
Absolutely no symptoms anywhere!
It's either the water pump seals or the head gasket. My 2016 duke 390 had the same issue, so the pump seals were replaced. After the replacement, i had to top-up the coolant twice or thrice but nothing after that.
nitninja is offline   (2) Thanks Reply With Quote
Old 21st February 2017, 18:04   #5944
Siddy's Avatar
Thanked: 89 Times
Thanks for the info, even mine is a June 2016 model. Did you notice milky coffee colored oil? Or white smoke? Or there was no symptom like me? How much time did the SVC take to fix the issue?
TIA!
Siddy is offline   Reply With Quote
Old 22nd February 2017, 10:45   #5945
Thanked: 143 Times
TIA!
I did not face any white smoke or starting issues, infact the bike was behaving totally normal. SVC took 2 hrs to replace the seals and fill the coolant again, a minor job. Get yourself a can of coolant for top-up as you will be needing it.
nitninja is offline   (1) Thanks Reply With Quote
Old 22nd February 2017, 10:54   #5946
Siddy's Avatar
Thanked: 89 Times
Good to know that its a quick fix, but how did they diagnose the issue? and how did they confirm that the gasket is ok? I know a few friends who got fixes done without proper diagnosis and the issues were back, ktm SVC's are famous for this! How did you engine oil look? bad seals result in coffee colored oil, did you notice this? I know I'm being a little paranoid here but in the past two months this is the fourth time I would be visting the SVC apart from my regular service for niggles!
Old 22nd February 2017, 11:56   #5947
Thanked: 143 Times
The mechanic first took out the seals for inspection and found them to be in damaged condition. I didn't inspect the engine oil, but then the mechanic informed that the coolant was mixing it. As per the mechanic, Starting issues and white smoke are the symptoms of head gasket failure. Since i was not facing any issues, he did not check the head gasket. I was riding with the damaged seals for almost 8k kms, so you don't need to be paranoid. It's best you sit with the mechanic and get the job done, hardly takes half a day . 😀
Old 25th February 2017, 18:43   #5948
Rohitj92's Avatar
Thanked: 61 Times
One more issue with my bike now. The display started showing low battery since yesterday, I was baffled as I use the bike on a daily basis and it's just 11months old (12100kms). Went to the service centre, they charged the battery for a couple of hours and put it back. I went home, approximately 10kms from the service centre, and the low battery sign showed up again. I went to the local battery shop who services car batteries, he checked and said that the battery isn't charging when the bike is running. Now guys, what might be the issue here, do I need to worry ?
Rohitj92 is offline   Reply With Quote
Old 25th February 2017, 20:01   #5949
b16h22's Avatar
Thanked: 113 Times
Check the stator coil. It might probably on it's way out. If found faulty, replace it asap or it'll simply fail and the motorcycle will not start in the middle of a ride as i've found out
b16h22 is offline   Reply With Quote
Old 25th February 2017, 20:11   #5950
Rohitj92's Avatar
Thanked: 61 Times
It happened with me today, after filling fuel, the bike refused to start. Pushed it for some time,tried starting again and luckily it started. Now will be taking it directly to the service centre on Monday, planning to use my old buddy(honda unicorn) till then. And will the stator coil be replaced under warranty ?
Old 25th February 2017, 20:18   #5951
Thanked: 143 Times
Failed stator coil is the reason for your low battery issue. You can confirm it by checking the voltage across battery, if the voltage level decreases even when the bike is revved, then the stator coil is not giving out enough voltage to charge it.
nitninja is offline   Reply With Quote
Old 25th February 2017, 20:33   #5952
Rohitj92's Avatar
Thanked: 61 Times
Yes when the local battery guy checked the battery voltage, it wasn't increasing at all when revved, so will the stator coil be replaced under warranty ?
Old 26th February 2017, 03:15   #5953
ArizonaJim's Avatar
Thanked: 2,006 Times
I don't know why a stator coil would fail unless it has some unsupported wiring connecting it to the wiring harness. It's just some coils of insulated wires which don't move.
The voltage regulator and rectifier (RR) on the other hand relies on diodes to do its job and it gets quite hot in the process. ( Alternating current produced by the alternator goes into it and direct current comes out of it. It throws away half of the current as heat in the process of doing this.)
Heat and diodes don't get along well and a failure of the RR resulting in no power getting to the battery and the rest of the motorcycles wiring is fairly common on many motorcycles.
If I had this problem and a mechanic told me he replaced my alternator stator I would be suspicious.
If he said he replaced the regulator/rectifier I would grumble and pay the bill.
ArizonaJim is offline   (1) Thanks Reply With Quote
Old 26th February 2017, 11:34   #5954
Thanked: 143 Times
As arizonajim said, could be the rectifier/regulator too. Particular batch of duke had weak stator coils, so i suspected it. Stator coil or rectifier, replacement will be done for free, if the bike is under warranty.
Old 5th March 2017, 23:40   #5955
VijayAnand1's Avatar
Thanked: 101 Times
Post Re: The KTM Duke 390 Ownership Experience Thread
Originally Posted by marcussantiago View Post
However, I've got a different problem. I'm getting a buzzing / rattling noise coming from somewhere in the front of the bike. Taken it to KTM twice and they can't find the source, nothing is loose anywhere that they can find, they even took apart the headlight / instrument cluster to look for anything loose. Performance of the bike and everything else is fine, it's just an incredibly irritating sound. Anyone else experience this?
The ratting or buzzing that you hear from the front end is from the fuel tank cap. I had this issue in my bike. The culprit is that at around 4 to 5k RPM, especially, when you decel, the resonance causes vibrations which is mild but annoying. I found that it was caused by the fuel tank lid key flap. One solution is to use a small round neydymium magnet and place it underneath the keyflap so that it sticks to the lid, and doesn't move an inch, and it worked like a charm. No vibes whatsoever.
Originally Posted by Rahul4 View Post
Hello guys,
I am a proud owner of KTM RC 390.
Model : 2016
Odo :7000 kms
Services undergone : 2 (free services)
The bike runs perfectly good. But I have been having annoying problems lately like
1. Fairing vibrations : There are vibrations below 4000rpm in the first
2. Engine Heat: I drive in the peak hours traffic a lot and the radiator fan runs almost all the time. Never in had the engine heat level reached to the last 2 bars. But these days the engine heat indicator frequently reaches till the last 1 bar. I have checked the coolant level and the fan runs normally. Should I get the coolant flushed and replaced or is there any other way my engine can run cool?
3. Strange buzz noise from the chain section only at certain RPM's (3000 to 4000) in the 1st, 2nd and 3rd gears. I have tried to locate the origin of the sound but in vain. When I showed it to SVC guys, they couldn't identify the source either. It started just a few days after the second service. Has anybody experienced the same strange noise? Please help me out in this.
-Rahul
Buzzing and annoying mild frequency vibrations have always pestered the 390. One thing is the chain slapping against the chain runners/guides in the swingarm and providing a slapping sound. This is mostly due to loose chain. Too tight a chain and you run excess slack making "katakakak" sound when the bike is in motion.
As posted above, observe if the sound is coming from the front, if yes try the fuel cap mod. Lots of parts like connectors tap against the inside of the tank and produce a wide variety of buzzing sounds.
Since we are dealing with the RC, I just noticed, the battery lid of the RC 390 is notoriously prone to producing rattling sound. One solution is to use a good quality high tension spring to the lock mechanism, arrests the sound 100%
Loose spring means loose clamping action and it results in the infamous battery cover vibrations.
With respect to chain slackness.
What I would suggest is undo the slackness, clean your front sprocket. IF YOU haven't checked/cleaned the front sprocket, it's a good idea to check it out. Lots of crud and grime gets gooed up and do affect the chain motion.
Loosen > clean > relslack > check your chain guides/runners, replace if necessary > lube after a small ride. Keep us posted.
Cheers!
VJ
VijayAnand1 is offline   (2) Thanks Reply With Quote
KTM Duke 390 - Accessories Thread sridhu Motorbikes 118 22nd December 2017 17:19
Duke of Ram - My Orange Flame, KTM Duke 390. EDIT : Sold! hillram Motorbikes 65 13th May 2016 07:21
India made KTM Duke 390 & RC 390 to be sold in the USA Tushar Motorbikes 1 7th January 2015 13:59
My Flamberge (KTM Duke 390) Ownership report - A middle aged man's perspective sridhu Motorbikes 165 1st April 2014 07:46
KTM Duke 390 - 375cc, 45 PS, 150 kg djay99 Motorbikes 620 25th June 2013 12:45
