Old 11th October 2013, 12:06   #841
sushrutha's Avatar
Thanked: 325 Times
Default re: The KTM Duke 390 Ownership Experience Thread
KTM Mekhri circle has received around 30 dukes, so bikes will be delivered in the coming week.
Thankfully, i'll be getting the bike (Which I had booked for my relative, which I'll have it for a month or so) on comming week (Probably by Wed.)
Old 11th October 2013, 14:05   #842
Thanked: 306 Times
One of my friend who had booked in june end has got his 390 yesterday.
zulfi hansi is offline   Reply With Quote
Old 11th October 2013, 14:26   #843
junaid12345678's Avatar
Thanked: 81 Times
Originally Posted by SanthoshK View Post
Any suggestions on how to break in the 390? Stick to the manufacturer's guidelines? What about motoman method? It attracts lots of attention in various forums. Any experience of views?
Regarding the run-in I would recommend to stick to the manufacturer's guidelines as they know their machines better than us. Just ride sanely and keep the rpms fluctuating and try to avoid cruising on highways for long time. Riding through city works well for running in a new engine. BTW, are you among the first six who will be getting their bikes this week?
junaid12345678 is offline   Reply With Quote
Old 11th October 2013, 17:17   #844
VW2010's Avatar
Thanked: 2,124 Times
Their recommendation is ride below a speed till 1000kms..And suddenly the engine is run in. How is that possible. How come a bike becomes eligible for high rev's and speed suddenly after 1000kms per say.
Simply advice once someone gave me was, ride how ever you want to inside the city. Just means rev hard, ride hard for you get very short stretch to do this and that helps in running in the engine.
VW2010 is offline   Reply With Quote
Old 11th October 2013, 17:50   #845
Thanked: 81 Times
No manufacturer in the world is willing to say the exact run-in procedure. If your bike runs well for more than a decade then you will probably won't buy another for long. So sales will fall for the manufacturers. So they can only afford just 1000 kms of run-in. All engines continues its running in process till up to 4k kms if taken good care and adopted the proper method of run-in. Well built engines such as Harleys take much longer to complete the run-in because the engine refuses to accept wear and tear that easily.
So it takes longer for the pistons and seals to seat in. And like most other bikes the D390 too takes about 4000 kms to render a 100 percent ran-in engine. I can say this from my personal experience. After I bought by CBZ xtreme I babied her for more than 4k kms by not going above 40 km/hr. Now the bike is 5 years old and odo shows 53k kms and still beats a brand new pulsar 150 in acceleration without much effort. All my friends who had various bikes sold theirs before 3 years because of significant loss in performance. All of them just ripped their bikes after first service, thinking that the run-in is over. This easily proves that the running in is not a sudden process nor it gets completed in just one thousand kms. The second service is the best time to start pushing your bike to higher speeds. So its better to take good care of the engine and riding smoothly by respecting and exploring the bike a couple of months or even four because its a ticket for years of grin on your face.
Old 11th October 2013, 18:44   #846
Thanked: 1,292 Times
Had been to KTM Mekhri circle today. Their deliveries stand at 39 including the 5 which is being readied for today.
The RC reached yesterday through post and I was taken aback when I saw the model as Duke200 instead of 390. However all other details including the chassis nr. Engine nr. were correct. The showroom has taken back my RC with the promise of getting it corrected.
unk9ja is offline   Reply With Quote
Old 12th October 2013, 10:00   #847
ebonho's Avatar
Thanked: 3,182 Times
This goes against all known conventional wisdom of how the run-in/break-in process works. Be it the more conservative conventional style or the more radical Motoman style.
ebonho is offline   (1) Thanks Reply With Quote
Old 12th October 2013, 11:00   #848
VW2010's Avatar
@dr
The way I see it.... 4k kms @40kmph.... that's forever for me. Except the first ride to home the conventional wisdom took over. It's just that I cannot accept sudden change in speed based on 1000...2000 kms.
Old 12th October 2013, 11:09   #849
Bazinga's Avatar
Thanked: 65 Times
KTM-Bundgarden got an additional load of 15 bikes this week. I think Duke is slowest in terms of delivery in hometown Pune :(
No commitments on delivery date. Sometime end of this month I guess for me.
p.s. 40KMPH limit for 4000KMS to run in?? I would die before that
Bazinga is offline   (2) Thanks Reply With Quote
Old 12th October 2013, 11:14   #850
ebonho's Avatar
@dr
You know, the concept of the first 50 odd kms being critical for loading-unloading of the rings against the fresh hone to the point where the rings and the peaks break in against each other and form the perfect seal, as well as heat cycling etc. - all these are written more from the point of view of freshly (re)built engines. The first few high rpm pulls by the mechanic after first start-up more often than not itself do 80% of the ring seal work.
For factory fresh bikes, especially "Ready To Race" quality KTM motors, most if not all of this is already done fresh off the assembly line, where the bikes are pulled to redline far more violently than any owner would ever do. Even the really violent ones!
I'm not an expert on running in, and have more than my share of failures on fresh builds on my Bullets (more thanks to wrong/too tight clearances and metallurgy and machining than my own fault - but then, that's me talking), but overall what I find best while running in a new bike, is to go more by sound and feel. Keep listening to the engine note. Be perceptible to how "tight" or "free" the motor feels as it warms up and as you progress into your ride.
The motor tells you when its not well. It also tells you when it is ready (or not). The mistake most of us do is push through that feel and let our minds and what we read on the Net and books take over. Plus the huge muddle of differing advice. And push when we should not. Or baby excessively when the engine is crying out for increasing load.
Another trick I learnt from a close friend is to wear half cut gloves when breaking in the motor and at intervals bending down to the side and using your fingers to feel the crankcase and gauge the temperature. Of course that is bike specific and differs from bike to bike, model to model, but when you ride Bullets for 10+ years, you definitely know what an overheating timing cover feels like!
ebonho is offline   (5) Thanks Reply With Quote
Old 12th October 2013, 12:42   #851
VW2010's Avatar
@dr
The concept of hear and feel to me applies more to bull. I know my bull is pleading for forgiveness and I know when it let's me rip. As you said 10 yes on a bull let's you ride by sound and feel.
The same applies to the high revvers but your reference for trouble moves up. Meaning this 390 or any such high rev machines needs to revved track hard to even get there.
I know days when I simply have let my bull take a breather before I continued.
I am no expert either on running in. Just the sheer power this 2l machine can deliver I am just letting it Rev with whatever apace I get in city where you canbhardly rev it above 7-8k rpm.
Lugging is one thing people should avoid in this bike.
And I agree that these engines are run in in factory for setting the seals and the initial rule dealers apply is more on safety aspect hoping you will learn about the bike before you thrash.
Old 12th October 2013, 13:31   #852
Thanked: 127 Times
I got the delivery yesterday. This is a mad mad motorcycle. Worth every single penny. Its tough to sit at home and type this when you have something like this sitting in your parking
heavy_foot is offline   (1) Thanks Reply With Quote
Old 12th October 2013, 14:08   #853
Thanked: 13 Times
Got my 390 yesterday. Above anything, I like the versatility of the bike most. Suits any mood or riding style. Thanks a lot Doc for the advice. I would have gone for an RE, otherwise. Regarding running in, I am neither babying it nor ripping it. It's riding as usual. Hope I will cross the run in threshold soon.
SanthoshK is offline   Reply With Quote
Old 12th October 2013, 15:10   #854
VW2010's Avatar
How about welcoming a new 390
Aks_karthik - Congrats,
VW2010 is offline   (1) Thanks Reply With Quote
Old 12th October 2013, 15:42   #855
aks_karthik's Avatar
Thanked: 232 Times
Finally got my KTM Duke 390 today.
I feel I am younger by 10.
Thanx VW2010 for giving company on Delivery.
aks_karthik is offline   Reply With Quote
KTM Duke 390 - Accessories Thread sridhu Motorbikes 119 17th April 2018 13:02
Duke of Ram - My Orange Flame, KTM Duke 390. EDIT : Sold! hillram Motorbikes 65 13th May 2016 07:21
India made KTM Duke 390 & RC 390 to be sold in the USA Tushar Motorbikes 1 7th January 2015 13:59
My Flamberge (KTM Duke 390) Ownership report - A middle aged man's perspective sridhu Motorbikes 165 1st April 2014 07:46
KTM Duke 390 - 375cc, 45 PS, 150 kg djay99 Motorbikes 620 25th June 2013 12:45
