Old 5th April 2012, 10:55   #286
Thar4x4's Avatar
Thanked: 626 Times
Default re: The Royal Enfield Mechanics Thread: All mechanics requirements and queries here
I am facing some issue about bike skidding/wobbling while turning at around 80 Km/h also rear tyre skids like bicycle in urgent breaking, any suggestion for tyres? Also I am thinking of fixing front disc break, have anyone used it on STD 350 CI?
Thar4x4 is offline   Reply With Quote
Old 5th April 2012, 11:03   #287
lohithrao's Avatar
Thanked: 161 Times
How is the rear tyre condition? i guess it has stock "MRF"?, i switched to "18" for the rear for the same reason. either TVS Jumbo or Ceat would work well.
Front discs is very effective, also check both the wheels for wobbling and the wheel bearings.
lohithrao is offline   (1) Thanks Reply With Quote
Old 5th April 2012, 13:49   #288
Thar4x4's Avatar
Thanked: 626 Times
Thanks, what is advantage in shifting to 18'' other than variety of tyres availability .
Old 5th April 2012, 14:24   #289
Visaster's Avatar
Thanked: 199 Times
Day before yesterday I saw this awesome looking Modified bullet in Chennai.
The bike was neat almost stock looking.
Could not get a closer look but it seemed like he was low seated, bigger front and back tires, brake light and number plate on the side, up-bent thumping silencer, T shaped handle bar, tank had electra written (may be it looked a little bigger.
I fell in love with the bike and the exhaust note.
How can one get to reduce the height of the bike?
What is the biggest sized tyre you can plonk on an electra without much problem?
What companies provide best alloys for a bullet?
Is the back mudguard of electra different than the CL ?
Visaster is offline   Reply With Quote
Old 5th April 2012, 14:31   #290
lohithrao's Avatar
Thanked: 161 Times
I felt the tyre options where only the "positive" about 18, however with the tyre chane i feel lot more confident.
Old 8th April 2012, 01:11   #291
Leepower's Avatar
Thanked: 70 Times
I need to change my 1978 Bull's front forks -- tubes and the whole inner thing. A reputed Bull mech is quoting 6K for the front forks. Any clue about the actual cost???
Leepower is offline   Reply With Quote
Old 10th April 2012, 17:14   #292
avkurian's Avatar
Thanked: 25 Times
Default Query on switch assembly
Hello all,
I have an '09 Standard 350 and am in the process of slowly converting it to a 1950's RE look. Simple things like the headlight peak, the rigid kick-start lever etc are done, and am currently getting the front number plate fitted on the mudguard. I also want to change the decompression mechanism to the metal lever that is below the clutch.
An issue that I have come across is that the entire switch assembly now needs to change. I have discussed a couple of options with my mech (Saleem & Noor in Indiranagar), but we're yet to find the solution.
As of now, what we are considering is the Jawa style assembly on the left, with only dim/dip and horn, with the indicator controls on the right, and the park/headlight controls somehow built into the ignition. The mech seems confident it can be done without changing the ignition system, but I'm not so sure.
Honestly, I wouldn't mind removing the indicators entirely, if the switch can be used for headlight on/off, and it will probably give it a truer period look too. Any feedback on whether cops would have an issue with that?
Look forward to hearing about any experiences/thoughts on this.
Cheers!
avkurian is offline   Reply With Quote
Old 15th April 2012, 00:28   #293
n.devdath's Avatar
Thanked: 1,310 Times
I have a 2007 Electra and am interested to convert it to a standard (in terms of looks) and I believe the first and the most expensive step is to change the front shock absorbers and their upper tubes.
Can someone, who knows the approximate costs of the same let me know. I have a good regular mechanic at Blore but if there is someone else worth recommending, I m all ears.
Old 15th April 2012, 13:10   #294
vinaydas's Avatar
Thanked: 81 Times
The shocks are the same on all variants, The "Tube" costs around 300-400 bucks. You will need a new numberplate board also.
vinaydas is offline   Reply With Quote
Old 15th April 2012, 13:41   #295
starter's Avatar
Thanked: 250 Times
Dear Dev,
Could you kindly let me know who is your mechanic and where do you plan to get this done?
I also have a 2006 Electra 4S and i would love to change some of the stuff to that of a standard, especially the mud guards and stuff.
I am tired of removing rust from some of these chrome stuff.
Thanks,
Deepak
starter is online now   Reply With Quote
Old 15th April 2012, 15:31   #296
n.devdath's Avatar
Thanks Vinay, that sounds simple to me. So, will the changing the upper tubes also enable me to change the front mudguard? That is my main intention. And yes, my Electra is a DB version.
Secondly, I understand that the rear mudguard is a straight fit. Am I correct?
Originally Posted by starter View Post
Dear Dev,
Hey Deepak, long time. How is your Gypsy doing? I go to a guy called Riyaz at Chamrajpet for all my work for the past 4 years. Do let me know when you are interested and we can go there together.
n.devdath is offline   (2) Thanks Reply With Quote
Old 15th April 2012, 19:33   #297
vinaydas's Avatar
Thanked: 81 Times
The rear mudguard on the standard is different i think. You may need a new stay for it.
Old 16th April 2012, 09:53   #298
lohithrao's Avatar
Thanked: 161 Times
Having a hard time finding a good mechanic in Mangalore, who knows to tune the "lightning", few i have tried are supposedly the old timers who should hav been good with old gen bikes but sadly its not the case!
Any pointers on mechs whoare good with tuning/timing? else i have to take it down to bangalore.
that said even in Bangalore, i think only Sunder(Brand store) was able to tune the bike perfectly!
lohithrao is offline   Reply With Quote
Old 16th April 2012, 20:34   #299
starter's Avatar
Thanked: 250 Times
Hey Dev,
Thanks! Gypsy is doing great!
I am game to join you when you are heading that direction.
Please let me know when you are planning to go there.
Thanks Dev.
Cheers,
Deepak
Old 16th April 2012, 20:36   #300
n.devdath's Avatar
Deepak,
I m planning to go there day after tomorrow sometime in the morning around 11AM.
All T-BHP Royal Enfield Owners- Your Bike Pics here Please ram.west Motorbikes 1490 19th May 2017 16:52
The Guitar Thread - Post all Queries,tabs and info here TributE Shifting gears 78 16th December 2016 15:30
Formal dressing and tailoring for all occassions (EDIT: Put all your queries here) manaa45 Shifting gears 71 17th February 2016 10:05
