Old 17th April 2012, 11:19   #301
sreerajunnithan's Avatar
Default re: The Royal Enfield Mechanics Thread: All mechanics requirements and queries here
I just figured out that i started this thread!!! Well, a lot of things happed after i purchased Machismo 350, To keep it short I sold Machismo to fund my Jeep So i did not have a bike from 2008. Guess who is coming home? 2009 CI Standard with 10K on clock. I know this bike from last 2 years, It was covered and the owner is in US. They had NO intention to sell it. Finally after a lot of drama, he would be mine today
sreerajunnithan is offline   Reply With Quote
Old 17th April 2012, 12:35   #302
starter's Avatar
Thanked: 269 Times
That is kewl Sree!
A '09 std ci with 10k on clock is quite tough to get these days.. Congrats!
Cheers,
Deepak
starter is offline   Reply With Quote
Old 20th April 2012, 06:47   #303
madhkris's Avatar
Thanked: 70 Times
...... I go to a guy called Riyaz at Chamrajpet for all my work for the past 4 years.....
Hi Dev,
Does this person work on Machismo 500 as well? Can you share his location and phone no? Am staying nearby (Vijayanagar)
madhkris is offline   Reply With Quote
Old 20th April 2012, 07:47   #304
starter's Avatar
Thanked: 269 Times
Deepak,
I m planning to go there day after tomorrow sometime in the morning around 11AM.
And what happened Dev? Would it be possible or not?
Sorry, i couldn't join you. I had to be at work that day.
Cheers,
Deepak
Old 21st April 2012, 22:04   #305
Thanked: 76 Times
I am posting this query on behalf of my friend. He owns a Thunderbird 350. Whenever the clutch of the bike is half engaged or is completely disengaged in the 1st and 2nd gear the bike tends to move forward even though there is no throttle input. It does not happen while starting the bike but occurs after it has been used for about say 10-15 minutes. I do not know as to what is the technical term used to describe this. I have observed this happening in a few cars, diesel SUVs and trucks that I have driven and was told that it is normal for them. However is this normal for a bike? If not then what should be done, why is this happening and what is the technical term used to describe this?
Bookkeeper is offline   Reply With Quote
Old 23rd April 2012, 08:27   #306
jeeva's Avatar
Thanked: 527 Times
Ask your friend not to ride with half clutch first.
Perhaps, the engine rpm is on the high side and the clutch plates need to be checked/replaced.
Clutch cable, Clutch housing (basket- I am not sure about the twin-spark models) also can be looked into, perhaps its not allowing free engage/disengage of the clutch.
jeeva is offline   (2) Thanks Reply With Quote
Old 23rd April 2012, 11:18   #307
Thanked: 76 Times
Thanks for your reply. He was not riding the clutch. We experienced this during bumper to bumper traffic so there is no option but to keep the clutch partially engaged. I have heard that clutch must only be replaced when rather than the engine rpm dropping when the clutch is engaged, it instead shoots up.
Old 23rd April 2012, 13:58   #308
jeeva's Avatar
Thanked: 527 Times
The vehicle speed should increase proportionally as the engine rpm increases. If it doesn't, it means that the clutch is not working as it is intended to.
In your friend's case, the clutch is not disengaging completely. Reason could vary from worn out clutch plates or tension-less clutch springs or something as trivial as adjusting the play in the clutch cable.
Old 23rd April 2012, 20:53   #309
Thanked: 76 Times
I will definitely ask my friend to get the clutch inspected. Is this what is termed as clutch creep? This may be off topic but in my original post I had stated that I have also experienced the same in various other vehicles that I have driven, so does this mean that they too had trouble with the clutch or is it that this is not a normal thing to occur in a bike?
Old 24th April 2012, 04:20   #310
ArizonaJim's Avatar
Thanked: 2,003 Times
In my opinion, with the clutch lever fully pulled in to the handgrip the motorcycle should not creep forward.
Likewise, if the motorcycle is up on the center stand and in gear with the engine running the wheel may remain turning if the clutch is pulled in but if one were to grasp the rear tire it should stop turning.
If the motorcycle creeps with the clutch lever pulled fully in it indicates that either the clutch cable needs to be adjusted (giving less free play at the clutch lever when it is released) or the clutch plates have become warped.
The proper amount of "slop" or "looseness" at the clutch lever for a UCE model when it is released should be about 2-3mm. If we are speaking of one of the older models the looseness should be 3-4mm.
If there is more free looseness than these values the cable should be adjusted.
Shortly after buying my Royal Enfield UCE EFI I was reminded by many of the people who own them that although the engine had been redesigned it still had some of the older engine characteristics.
One of these characteristics was the clutch is still like almost all of the older British motorcycles were and it is not designed to be held in for long periods of time when waiting at a traffic light.
It was highly recommended that if I needed to wait at a traffic light, the transmission should be clicked into neutral and the clutch lever released.
Then, when the light changed I could pull in the clutch lever and click the transmission into first gear to proceed.
According to these people, holding the clutch lever in for long periods of time can cause wear on the release bearing and what is worse, the dragging of the clutch pads on the clutch disks can overheat the disks.
Overheating the disks can cause them to warp.
Another thing that can cause excess heat in the clutch disks on the older non-UCE engines is to ride the motorcycle with low oil levels in the left hand primary drive case. The clutches in the Bullets are known as "wet" clutches because they must constantly have oil to lubricate them. A lack of oil will overheat the clutch disks and pads very rapidly causing pad wear and disk warpage.
If the clutch is slipping, that is to say, if the motorcycle engine speed increases without the motorcycles speed increasing that can be caused by worn out clutch pads, weak clutch springs or a incorrectly adjusted clutch cable.
ArizonaJim is offline   (2) Thanks Reply With Quote
Old 24th April 2012, 21:27   #311
Thanked: 76 Times
Thanks ArizonaJim for your detailed explanation. Strange thing is that my friend took his bike to the authorised service center and the folks there told him it is normal for bike to creep forward with clutch half engaged/fully disengaged in 1st gear or 2nd gear. I witnessed this today again on a Bolero where it began to lurch forward once the clutch is half depressed and once you shift to 2nd gear then again it moves effortlessly upto speed of 10-15 kmph. Here again the driver claimed it is normal for creep to occur in half engaged clutch.
Old 25th April 2012, 03:54   #312
ArizonaJim's Avatar
Perhaps it was my misunderstanding but I assumed we were talking about a fully disengaged clutch causing the motorcycle to creep.
Obviously somewhere between having the clutch lever fully pulled in and totally released there is a place where the clutch plates are lightly rubbing against the clutch pads and a small amount of power will be transmitted from the engine to the transmission.
This controlled slipping is great for starting from a stopped condition.
The "half depressed" condition you mention is that location so, yes, with the clutch lever held in a half depressed position the motorcycle will creep forward.
It is wise not to ride long distances while the clutch is slipping in this manner though because as I mentioned above, it will wear out the clutch pads and possibly damage the clutch plates by causing excessive heat.
ArizonaJim is offline   (1) Thanks Reply With Quote
Old 12th May 2012, 18:09   #313
Thanked: 60 Times
A new Royal Enfield workshop spotted on the KR Puram Whitefield road at Bangalore about one Km from the Hanging bridge. Any reviews ?
Appears to be a medium, size facility with a number of bikes parked there on saturday morning.
adnaps is offline   Reply With Quote
Old 12th May 2012, 19:04   #314
phamilyman's Avatar
Thanked: 3,454 Times
so here is a real resource for the delhi bullet guys (most of whom would know him anyways):
Jitender, 9810550243
INDIABIKETOUR - New Delhi, India - Bike tour and Renting
He even gives bikes on rent and support for all rallys and suchlike stuff. (couple of times for Enfield officially as well)
The best part about him is that you just tell what you need, then come back later, or just hang around there, chitchat, have chai, paranthas and things will happen painlessly. He even takes time out to sort out niggles - a rarity in today's world.
Old 26th July 2012, 11:02   #315
Thanked: 16 Times
I hate coming back here , but alas no luck yet. Bike is running fine as of now with zero niggles except for a conked speedo cable.
This weekend I will head to Dream Machines and have a word with Jaffer as per RVD's advice. Lets see how it goes.
hi,
Did you have any luck in finding a good mech in North Bangalore area? I recently moved from Chennai, and am on the hunt for a good mechanic for regular service and a couple of minor niggles. Do share your experience with the mechs you tried out in this area.
ZedMae is offline   Reply With Quote
All T-BHP Royal Enfield Owners- Your Bike Pics here Please ram.west Motorbikes 1494 7th July 2017 17:31
