Old 25th November 2013, 09:56   #106
sridhu's Avatar
Thanked: 888 Times
Default Re: My Flamberge (KTM Duke 390) Ownership report - A middle aged man's perspective
Sorry - forgot to include a pic of the folks who went.
Here it is:
My Flamberge (KTM Duke 390) Ownership report - A middle aged man's perspective-img_7326-copy.jpg
sridhu is online now   (2) Thanks Reply With Quote
Old 25th November 2013, 13:24   #107
ebonho's Avatar
Thanked: 3,178 Times
Originally Posted by sridhu View Post
What happened was that we were riding in a group & the rest were on Bullets. The lead guy decided 60 kmph was he safe speed. We did this for about 1 hour until better sense prevailed and 2 of us opened up to more normal speeds. To give you an indication, we took 5 hours from Nelamangala to b On the way back I took 3 hours to reach home in HSR, an additional 50 km more, with one 15 minute stop. The to trip averaged about 30kmpl & the return a more normal 26.
Next time don't listen to the Bullet boys. Its just their devious way to keep you in sight.
450 kms on one tankful? Are you sure? That's around 50 kmpl bro assuming around 9 liters of usable fuel.
At 60 kmph in 6th the 390 experiences distinct chain snatch.
ebonho is offline   Reply With Quote
Old 25th November 2013, 13:29   #108
sridhu's Avatar
Thanked: 888 Times
@ebonho - that is just a failed joke! THe MID was showing 42 kmpl FE. Hence the 450. The actual full tank FE was 31 kmpl.
It was quite painful to do 60 kmph on the 390. Was such a relief when I opened it up!
Old 25th November 2013, 13:44   #109
ebonho's Avatar
Riding normally, while touring, from tankful my 200 hits low fuel at around 270-280 kms.
Similar conditions, my test 390 would hit low fuel at around 200 kms.
So if you got around 270 odd kms from tankful on your 390, when riding normally, thats a lot. What speeds were you doing?
Old 25th November 2013, 13:59   #110
sridhu's Avatar
Thanked: 888 Times
On the return, I was between 95-105. Filled about 9.2 Lt when I got back.
sridhu is online now   (1) Thanks Reply With Quote
Old 25th November 2013, 14:11   #111
ebonho's Avatar
That's good to know bro. So at 95-105, how many kilometers did you get for those 9.2 liters consumed?
My average range of 200 kms between fills was at higher speeds, so this would be good info to have for econo touring and stretching the 390's range when needed.
Old 25th November 2013, 14:21   #112
VW2010's Avatar
Thanked: 2,040 Times
If it helps my enthusiastic city riding always gives me close to 240kms when i fill around 9.5L brimfull.
This riding involves lots of traffic and fair bit of open roads when i hit 100 in 4th and be around 90-100 in 6th post that. Means good bit of acceleration and using 5th and 6th to maintain a decent 90-100.
The ride is mostly around 4th and 5th and still the last 6-7 refills have been around 240 easilly.
My guess is around 240 at 100kmph on highways. We are planning a ride this saturday the first for my 390 for a longer distance. Will confirm my expectation.
VW2010 is online now   (2) Thanks Reply With Quote
Old 25th November 2013, 14:43   #113
ebonho's Avatar
That sounds about right. I usually fill a lot earlier (i.e. within 10-15 kms of getting the low fuel warning) so most of my fills are 8.25-8.5 liters.
Once when I stretched it to 9.5 liters (like you), I got around 230 kms. But that was higher speeds, on the way back to Pune from Nagar (refueled at Shirdi, on the way back to Pune).
Old 25th November 2013, 15:10   #114
sridhu's Avatar
Thanked: 888 Times
Oh sorry; Did about 250km before the fill up.
Old 25th November 2013, 17:34   #115
GreaseMonk's Avatar
Thanked: 85 Times
Just got back from a trip to Bangalore. Surprisingly, I managed a range of 270 KM on one tank. When I filled up, it took 10 litres, so I was dangerously close to emptying the thing. On the way back though, I only managed about 240 KM at which point I needed to fill 9.5 L which is more in line with my expectations of the bike's range.
GreaseMonk is offline   (2) Thanks Reply With Quote
Old 26th November 2013, 09:30   #116
FlyingSpur's Avatar
Thanked: 1,331 Times
Alright everyone, when does your low fuel warning come on? And I mean while riding, not when parked (that causes some false warnings). I get it at about 170 km.
FlyingSpur is offline   Reply With Quote
Old 26th November 2013, 12:45   #117
Freewheelin_KD's Avatar
Thanked: 68 Times
Depends on how and where you ride FlyingSpur. I have had low fuel warning come up from as low as 156 kms on the trip during initial running-in to 200 kms on trip during the last 200 kms of running-in. Now it has stabilized to around 220-230 kms post running-in. This is on 80% highway riding with the remaining 20% on small single/two lane back roads. That 170 km you are getting must be for pure city riding?
Freewheelin_KD is offline   Reply With Quote
Old 26th November 2013, 12:51   #118
FlyingSpur's Avatar
My morning commute is a pure 6th gear, 10 km well-surfaced highway ride. My evening commute on the exact road is a pure 2nd / 3rd gear ride in crawling traffic. The bike stands at about 550 km, and I haven't crossed 7k even once, but rarely I do make the 0-7k RPM climb quickly. Also the fact that this thing doesn't like crawling in lower RPMs means one must constantly ride in a lower gear.
Old 26th November 2013, 13:16   #119
sridhu's Avatar
Thanked: 888 Times
Havent really noticed but I think I get the low fuel light around 210-220km
sridhu is online now   Reply With Quote
Old 26th November 2013, 13:17   #120
Thanked: 68 Times
This type of riding is what I presume to be hitting your range most. Also, I have observed that post first start of the day, it takes around 10 kms for the bike's fuel consumption to average out to mid 20s. Prior to that it shows around 10-15 kmpl, probably due to it running richer initially.
The KTM Duke 390 Ownership Experience Thread parrys Motorbikes 6101 22nd November 2017 17:35
Duke of Ram - My Orange Flame, KTM Duke 390. EDIT : Sold! hillram Motorbikes 65 13th May 2016 07:21
Bullet Thunderbird TBTS 500 versus KTM Duke 390? sridhu Motorbikes 174 29th November 2015 17:53
India made KTM Duke 390 & RC 390 to be sold in the USA Tushar Motorbikes 1 7th January 2015 13:59
KTM Duke 390 - 375cc, 45 PS, 150 kg djay99 Motorbikes 620 25th June 2013 12:45
