Old 3rd March 2014, 11:50   #196
Thanked: 14,320 Times
Originally Posted by Majumdarda View Post
One thing that I have observed is that these rubber blocks tends to fall off quite easily and the fitting is also not tight enough. At least on Amun-Ra, some are missing.
Is this something very serious?
Lol. I thought they mean nothing and just some decoration so removed it off the day I took delivery. I have been using my Karizma since 4 years with 23K on odometer. No issues faced till date so technical guys should say what use it really has.
Anurag.
Old 3rd March 2014, 15:39   #197
Jimmy_u's Avatar
Thanked: 78 Times
Default Re: Royal Enfield Bullet 500 : "Amun-Ra"
Last night, was my first night ride on the Mumbai Pune old highway, covering a distance of approximate 100 kilometers (Lonavala Up and Down). There was another rider with me too and we had a great time, atop the Tiger Point, at around 9:30 PM.
This is one Ride I would want to be a part of Sir, do let me know next time if its a weekday,I could plan to join, my weekends are occupied now as we have recently been blessed with a baby girl.
Cheers and happy riding
Jimit
Jimmy_u is offline   Reply With Quote
Old 3rd March 2014, 21:56   #198
Thanked: 2,374 Times
Infractions: 0/1 (4)
AFAIK and IIRC the rubber blocks that are placed between the fins help by two ways:
1) They dampen the high pitch sound produced by the engine and lesser vibration (resonance).
+1
The cooling fins 'ring'. The rubber blocks prevent/ lessen it.
2) Air moving over the fins will pass straight without much heat carryibg but the rubber blocks can create turbulence hence sone extra heat can be removed along with the air that swirls around.
Unlikely.
Sutripta
Old 3rd March 2014, 22:45   #199
Sir,
If those rubber blocks have a use on the vehicle then why are they so flimsy and fall off within a few days of purchase?
Why aren't they fixed there to improve their working efficiency and life?
Anurag.
Old 4th March 2014, 01:24   #200
ArizonaJim's Avatar
Thanked: 2,089 Times
Majumdarda:
Don't worry about the missing rubber dampers.
As was mentioned, they are there to dampen out high frequency vibrations.
When I got my fuel injected 500cc UCE Royal Enfield I didn't like the look of the dampers. They seemed to clutter up a otherwise nice looking engine.
Being an design engineer who spent a lot of my life dealing with jet and turbine engines, I've seen the results of high cycle fatigue failures so I studied the fins on the UCE. They seemed to have adequate connecting ribs between them to dampen out any destructive vibrations so my worry diminished.
Because the summer time temperatures can reach over 115 degrees F (46.1 degrees C) cooling is a concern here.
It seemed like the rubber dampers were covering up a substantial amount of surface area on the engines cooling fins and covered fins do not cool the engine.
With this, and my dislike of the look of the dampers in mind, I removed them all shortly after getting my motorcycle.
In 2 3/4 years and over 13,000 miles (21,000 km) of riding I have never had a problem with high frequency noise, fins cracking from HCF or the engine overheating.
ArizonaJim is offline   (3) Thanks Reply With Quote
Old 4th March 2014, 20:56   #201
These have a use, just not important. Just like say the ferrite bead on electronic cables. Equipment normally works just fine without these also.
Things falling off REs I can understand, but ZMAs? Strange. Overenthusiastic cleaning?
Sutripta
Old 4th March 2014, 21:27   #202
Lol. I removed then the day I got the bike home after delivery.
Will Harley's and Triumph too have these rubber blocks placed in between?
Anurag.
Old 4th March 2014, 22:14   #203
Thanked: 49 Times
The salesman in the showroom in Gurgaon either had no clue as to it's function (he said it's to prevent in-transit damage) or we're overestimating their function. Former sounds more logical.
Firstly congratulations on the baby girl. Hope she has a long, healthy happy life.
OT: Your signature here says Esteem 'diesel'. wasn't aware of it.
P.S. is offline   Reply With Quote
Old 5th March 2014, 10:45   #204
Majumdarda's Avatar
Thanked: 425 Times
Amun-Ra was registered under my name of 4th of October 2013 and yesterday was 4th of March 2014.
Exactly in 5 months I have covered 5000 kilometers on the odo. This was a moment worth capturing (even while going to office, stopping the vehicle on a narrow stretch of road, with the traffic police jeep just behind me )
Thank you Amun-Ra.
@ Jimmy, These short rides are just scheduled on the go, with no pre-planning etc. The next time I am going, I would off-course be sending you a text. But my personal advise, is do not waste time. Do not be dependent on others in such short rides. It is just 100 km both ways, so there is no need of worry. Take some time out, (say three hours), fill up the tank and then go to Tiger point post 8 PM. The stars will be there to welcome you, if not anyone else.
Ride safe.
Best regards,
Majumdarda is offline   (3) Thanks Reply With Quote
Old 5th March 2014, 22:06   #205
Not for the liquid cooled ones, I'm sure!
It is to prevent high frequency vibrations. The cooling fins have the same form as the prongs of a tuning fork.
Of course it's possible that some manufacturers have copied it (tick a checkbox) without actually engineering anything.
Sutripta
Old 9th March 2014, 02:54   #206
Mpower's Avatar
Thanked: 1,686 Times
Whys that? Fin is a fin whether its on Air or LC !
Old 9th March 2014, 18:21   #207
I just saw the rubber blocks placed in the HD bikes that are liquid cooled.
Anurag.
Old 9th March 2014, 20:29   #208
Functional fin <> cosmetic fin.
Going by
extreme case of form over function.
@Anurag, any pictures. Which one, Street or VRod?
Sutripta
Old 9th March 2014, 21:47   #209
Sutripta
No pictures buddy! The HD 750, I remember seeing had black blocks in between the silver fins.
Shall try for pictures to get things clear.
OT:
We are going off topic here. Let's continue this on a new thread before the MODS/owner revolts.
Anurag.
Old 11th March 2014, 19:08   #210
Mpower's Avatar
Going by
I realize that but what is different about the geometry of a cosmetic fin? maybe you dont need to worry about thermal mass/sizing or air flow path, but it still has a natural frequency and will resonate.
BTW all the so called cosmetic fins also offer some some amount of cooling effect. If you didn't plan for it then you will end up overcooling
Royal Enfield - Shooting the Bullet - 500 Power trammway Motorbikes 101 11th April 2016 23:20
The story of another Green Bullet in my life - My Enfield Bullet 500 arjithin Motorbikes 35 20th February 2016 20:26
Royal Enfield Desert Storm 500 - The Remembrance of a War Era, My Bullet! Mighty_Lothar Motorbikes 15 18th December 2014 10:30
Royal Enfield Bullet 500 - NEW model coming. EDIT : Launched @ 1.53 Lakhs grplr02 Motorbikes 128 11th June 2014 15:21
