Old 24th December 2015, 21:51   #46
Mashblue's Avatar
Thanked: 272 Times
Originally Posted by hothatchaway View Post
After almost a year....is there merit in changing the oil at around the 200 kms mark (and of course again at the mandatory 1k/1 month schedule) to help the engine run in better? Also who do we think is the best Yamaha service outfit in Bangalore?
Running in a new motorcycle is infact the last stage of motorcycle production, it should be done carefully. Basically you just avoid full throttle during the initial 1k kms, dont think too much of the revs if taken to higher revs smoothly then there shall be no harm. But the worst thing for a new engine will be "lugging", avoid that.
I remember taking it too mild on the running in of my previous ride, later on it did not like high revs at all. It just develops a character, hope you get it and congratulations and wishing happy ownership. :thumbup:
Mashblue is offline   Reply With Quote
Old 25th December 2015, 22:18   #47
hothatchaway's Avatar
Thanked: 563 Times
Default Re: Yamaha R15 V2 vs KTM RC 200
Originally Posted by Sojogator View Post
Congrats mate on the "bullet" proof little super bike I am sure you will have more fun than you could ever imagine.
Originally Posted by barcalad View Post
Many congratulations, mate.
Originally Posted by Mashblue View Post
Thanks guys, your suggestions helped a lot, look forward to riding with you guys after the engine runs in
Should I clean and lube the chain at the 500 km mark or let the SVC do it in the first service? Any pointers on how do I do this considering the R15 does not have a centre stand?
Any recommendations on headlamps which dont void warranty? The stock ones are crap.
hothatchaway is offline   Reply With Quote
Old 25th December 2015, 23:58   #48
autocrat's Avatar
Thanked: 538 Times
Yes stock headlights on most bikes are crap. You might want to start with upgrading the bulbs, with stock wiring.
If you feel that's not good enough, you can either go in for a projector setup with good quality ballasts, HID bulbs and projectors, or you can upgrade the wiring, fit a relay, switch to ceramic holders and use 60/55 bulbs. (The stock wiring in my FZ is supporting 60/55 bulb without a relay, however better not take a chance).
Please do not fit HIDs without projectors.
autocrat is offline   Reply With Quote
Old 26th December 2015, 02:14   #49
Thanked: 454 Times
The chain clean plus lube thing after 500 km is not written in stone. Lube the chain and see how it looks and feels. When you can see the chain feels dry, lube it. When you see the chain going dirty/dark, clean and lube it. If its dry weather, a lube every 500kms and a clean every 1000/1500 kms does the job. During rains however, you might even have to lube it after one ride if you happen to ride through deep waters and frequency of cleaning also has to increase.
You will know when she needs the lube as you ride her more
Yes the lights are not enough but do not upgrade anything but a dfferent bulb of same rating, to keep warranty intact. I simply made it a point to not ride outside cities after dark and if I do then i go at the speeds the low beam allowed me to go (not more than 60 kmph for sure), keeps things safer too.
Sojogator is offline   Reply With Quote
Old 26th December 2015, 11:36   #50
barcalad's Avatar
Thanked: 1,161 Times
Religiously, mate. When I first bought my ride, I was very callous in self-maintaining the bike until bhpian man_of_steel knocked some sense into me and told me the intricacies of maintaining my bike well. This was when my odo was barely a ton. Since then, I lube my chain every 450-500 kms and adjust the slack. You won't believe the change in performance a well lubed/adjusted chain gives. The result? My chain lasted for 15k kms, 3k more than it does for many D390s. So yes, religiously and regularly maintaining you chain is a MUST because it's a very CRUCIAL component of your bike.
You can buy any of the various paddock stands available in the market. I believe IndiMotard, Bangalore makes and stocks their own, which are relatively cheap and well built than other in the market. Check with them.
Don't go for a headlamp upgrade just right now. If you want a change, go for better headlamp bulbs. I changed mine to Xtreme Vision and also got the throw/focus adjusted in pitch darkness and it has worked wonders. My headlamps work awesome now and I have dropped the idea of aux lamps altogether!
barcalad is offline   Reply With Quote
Replacing Tyres 195/60 R15 With 215/75 R15 in Ford Fusion singhisking Modifications & Accessories 14 11th January 2016 22:23
KTM Duke 200 launched @ an introductory price of Rs. 1,17,500/- (Ex-Showroom Delhi) MurtazaGhiya Motorbikes 222 13th November 2013 18:53
Scoop: KTM Duke 200 caught testing in India! Scorcher Motorbikes 130 24th January 2012 14:34
KTM 200 launched @ Malaysia jkdas Motorbikes 21 8th December 2011 17:39
Best 150 - 200 cc Motorcycle for my son? EDIT - Bought Yamaha R15 shishya Motorbikes 44 23rd January 2011 17:24
