Old 23rd August 2006, 12:51   #1
Hello ppl
i have a pulsar 180 v1. My bike seems to be sluggish post 100kmph ACT other p180's. And the top speed is just abt 125kmph at 9000rpm. My friend's 180 does a 135 @ 9500(tried and tested by me).
What could be the matter? My bike's just run 10,000kms.
Pls help guys
member is offline   Reply With Quote
Old 23rd August 2006, 13:29   #2
veyron1's Avatar
Thanked: 38 Times
Does the exhaust emit a whistling sound? Do the tappets make excessive noise?
veyron1 is offline   Reply With Quote
Old 23rd August 2006, 13:50   #3
zenx's Avatar
Thanked: 75 Times
Pulsar, 135 ?
Speedo error.
zenx is offline   Reply With Quote
Old 23rd August 2006, 18:09   #4
No, not a whisteling sound per se, but at higher rpms makes a strained kindof sound, as if outta breath
And yes the tappets do make excessive noise(but only at high rpms)
another problem is that the bike hits the revlimiter at just 9000rpm in all gears except the 1st.(where it hits at 8000rpm). Is this the case wid other pulsars too?
Old 23rd August 2006, 18:15   #5
Originally Posted by zenx
Pulsar, 135 ?
Speedo error.
yeah, obviously
bikes do have a lot of error in speedos post 100kmph esp pulsars and karizmas
Old 23rd August 2006, 18:48   #6
veyron1's Avatar
Thanked: 38 Times
Karizma speedos are not as erratic as the Pulsars'. Yeah, I had the same prob. in my 180 DTSi once. At 1100 kms or so. Was trying to max out, and misfired at about 8.5K RPM, in 4th. Blew a hole in the perforated pipes inside the exhaust cannister. Got the CDI, exhaust, and piston rings changed under warranty. When checked, the compression was slightly lower than usual, and the throttle sensor on the carb was erratic.
Of course, the Bajaj mechs are nincompoops, and I had to get it done in front of me. Heck, I had to even point out the flaws. Oh yeah, got the tappets done up too. Smooth after 4500 kms, and the engine opened up quite nicely after the 8000 km mark.
Old 23rd August 2006, 22:51   #7
But then, under what pretext did u change the CDI? Coz the service guys dont know anything. What did u tell them, that they let u change the cdi and all?
I told them my prob, and they looked at me up to down like i was some alien. They said pulsars are not meant for 100+kmph. Morons
Pulsar 220 (new) or the Apache RTR 180 - EDIT - Bought Pulsar 220 M abhayshanu Motorbikes 203 1st March 2011 14:27
Pulsar 150 Vs Pulsar 180 !!! EDIT: Its the 180 NOTORIOUS Motorbikes 34 24th June 2010 17:49
Pulsar 180 UG3and Apache 180-for a new bike? EDIT - Its the RTR 180 deepclutch Motorbikes 76 26th November 2009 00:34
Sluggish Accent CRDI after engine rebuild. clipto333 Technical Stuff 30 10th March 2008 23:44
The steering starts shivering after 100kmph.. Vic Technical Stuff 17 1st April 2007 17:56
