Old 8th June 2015, 12:05   #1
bikertillidie's Avatar
Thanked: 649 Times
Default Royal Enfield UCE500: EFI to Carburettor Conversion
Commenced work on converting my UCE500 Classic from EFI to a carburettor based set-up.
Items procured -
(a) BS32 carburettor meant for Pulsar 220
It comes with 15 & 115 sized jets (pilot & main respectively) by default
(b) Jets sized 125 & 130 as replacement main jets for the BS32 carburettor
(c) Accelerator cable for the classic 350 (to replace the existing twin cable set-up of the Classic 500)
(d) Rubber flange for mounting the new carburettor
(e) Pentagon shaped flange for mounting a fuel tap from a thunderbird
(f) Fuel tap assembly from a classic 350
(g) Hex socket headed screws 2 * M6 x 1 x 14 (the ones procured were a bit longer)
The pentagon shaped flange had a few odd protrusions jutting out, which would have otherwise interfered with the frame & battery cover during fitment. Hence, they had to be sawed off. The burred edges were attended to with a file.
Here are a few pictures from yesterday afternoon.
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0076.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0078.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0081.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0082.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0083.jpg
The screws for mounting the fuel tap were a tad loger than required. Had to shorten them by about 10 mm.
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0084.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0085.jpg
The flange holding the injector and the throttle body were removed after disconnecting the choke & accelerator cables (and disconnecting all couplers).
To be continued this evening as well -
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0087.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0088.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0089.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0090.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0091.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0092.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0093.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0094.jpg
bikertillidie is online now   (18) Thanks Reply With Quote
Old 8th June 2015, 12:18   #2
rakesh_r's Avatar
Thanked: 702 Times
Default Re: The Royal Enfield 500 Classic thread!
@bikertillidie-excellent stuff. I too am pissed off with my 4 month old 3 k run DS with the jerking issue.
One query-Is the carb from the B500 and the p220 the same?If no why didn't you opt for the B500 carb?
rakesh_r is offline   (1) Thanks Reply With Quote
Old 8th June 2015, 12:38   #3
Thanked: 649 Times
Hi Rakesh,
The carbed version of the UCE bullet 500 uses a UCD33 carb.
Older LB500s used a BS29 carb, if I am not mistaken.
The primary reason I did not opt for the UCD33 carb is cost.
The BS32 carb from a pulsar 220 costs roughly half that of a UCD33 and I am hoping that with an up-rated main jet (cost 60 INR), it should provide roughly the same performance.
bikertillidie is online now   (4) Thanks Reply With Quote
Old 8th June 2015, 13:10   #4
ilangop's Avatar
Thanked: 581 Times
Neat work. Didn't expect that you will get into action so soon . Eagerly waiting for your road test report.
Is the carb flange from AVL thunderbird?
ilangop is offline   (3) Thanks Reply With Quote
Old 8th June 2015, 13:15   #5
Thanked: 649 Times
Ilango, many thanks !
I was inspired by your previous post
The carb flange is from a carbed version of the UCE 500 (going by the part number from the spare parts catalogue).
It may fit the thunderbird as well, but am not sure.
bikertillidie is online now   (3) Thanks Reply With Quote
Old 8th June 2015, 13:41   #6
ebonho's Avatar
Thanked: 3,179 Times
Seeing as you are a Puneite, I have a fair idea of the hoops you must have jumped through to do what you have done, hence my appreciation. In addition to the DIY as well of course.
Where exactly did you get the individual parts from?
ebonho is offline   (1) Thanks Reply With Quote
Old 8th June 2015, 13:48   #7
Thanked: 649 Times
Hi Ebonho,
Thanks!
Yes, I did do my usual rounds at authorised service centres.
The carb & replacement main jets were procured from Nanapeth.
Remaining spares were procured from a friendly RE spare parts distributor in the Hadapsar area, who also provides a fair discount off MRP pricing.
bikertillidie is online now   (1) Thanks Reply With Quote
Old 9th June 2015, 09:39   #8
Thanked: 649 Times
Reached home late last evening. Hence, could manage only the following -
  • The carb has been bolted on.
  • The accelerator cable was also replaced.
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0101.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0100.jpg
Attachment 1379939
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0099.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0097.jpg
I need to procure a few jubilee clips to mount a rubber bellow between the air filter intake & the carb.
I thought I had a few spare ones at home, but couldn't locate them last evening.
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0102.jpg
Checked out the potentiometer readings from the TPS. It varies from about 1.5 Kilo-ohms to approximately 4.5 Kilo-ohms.
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0103.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0105.jpg
Additional procurements needed
  • a few cable ties
  • relays
  • T connectors
  • switch for activating the choke
bikertillidie is online now   (9) Thanks Reply With Quote
Old 9th June 2015, 11:29   #9
ilangop's Avatar
Thanked: 581 Times
You will need a 20 - 25 pilot jet. Which you will understand why, once you try to tune the carb.
Hope you are aware of the tuning procedure for the fuel screw in BS carbs.
Still I am elaborating it for the novice here.
The pilot has to be chosen such that you can lean - rich - and over rich at idle at various positions of turning the fuel screw.
When the engine is warm, you have to start with the tightening the fuel screw till the engine rpm just drops.
As you unscrew the rpm tends to rise. While counting the no of turns, unscrew till the rpm falls again.
Now tighten it again by half the number of turns you had counted.
With #15 the engine will always run lean. (We experienced this is CI350 with BS32).
The #25 pilot from VM24 or #30 from VM28 will fit and solve your problem.
By looks the pilots looks little different in BS & VM carbs, but they do the job.
What have you got in your mind for the switch.
You may use the horn dipper switch of Rajdoot or else buy a switch from
www.aliexpress.com
ilangop is offline   (4) Thanks Reply With Quote
Old 9th June 2015, 13:41   #10
Thanked: 649 Times
Thanks.
I will check whether the pilot jets are available locally.
www.aliexpress.com
This is what I have picked up. Would look more appropriate on a vintage bike though ...
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0106.jpg
bikertillidie is online now   (2) Thanks Reply With Quote
Old 10th June 2015, 09:18   #11
Thanked: 649 Times
The bellow was fixed last evening. The switch has also been mounted on the handlebar. I have also started wiring up the relays.
Royal Enfield UCE500: EFI to Carburettor Conversion-1433908010316.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-1433908039013.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-1433908064059.jpg
Old 10th June 2015, 10:41   #12
ilangop's Avatar
Thanked: 581 Times
What is the relay doing there?
ilangop is offline   Reply With Quote
Old 10th June 2015, 13:51   #13
Thanked: 649 Times
The relays are meant to emulate the fuel pump and the injector. I don't want the MIL lamp to blink continously.
Old 10th June 2015, 23:05   #14
Thanked: 649 Times
At last, the conversion is complete. The bike feels like it's on steriods
Acceleration is crisp, there was no hesitation/jerking evident during a test ride a short while ago.
I attach a few pictures taken earlier -
Connectors for
(A) For the fuel pump
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0123.jpg
(B) For the injector
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0124.jpg
(C) For the solenoid operated choke
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0125.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0126.jpg
T connector & tubing from a nearby store which sells aquariums
This was used for tapping into a tube leading to the PCV valve.
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0131.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0132.jpg
0.3 mm drill bits to alter the size of the pilot jet (just in case)!
Thankfully, it wasn't necessary.
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0130.jpg
An adapter was prepared for the MAP sensor and proper sealing was ensured with silicone sealant.
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0133.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0134.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0135.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0137.jpg
The relays were tucked away inside the tool box.
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0143.jpg
All the wiring & connectors were wrapped with insulation tape and cable ties were used to tuck everything away neatly.
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0139.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0144.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0145.jpg
Notice that the MIL light turns on (when ignition is turned on) & then goes off after a few seconds.
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0140.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0141.jpg
Finally, the sooty spark plugs were cleaned and gaps readjusted.
At last, the bike was ready.
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0147.jpg
Royal Enfield UCE500: EFI to Carburettor Conversion-dsc_0148.jpg
bikertillidie is online now   (21) Thanks Reply With Quote
Old 16th June 2015, 11:04   #15
Thanked: 91,500 Times
Default Re: Royal Enfield UCE500: EFI to Carburettor Conversion
Bikertillidie, thanks for sharing! Have moved your EFI -> carburettor conversion posts to a new thread.
This one is going straight to the homepage
GTO is offline   (9) Thanks Reply With Quote
Fuel leak from the carburettor (Royal Enfield CI) 8090guy Motorbikes 9 24th October 2016 11:45
Royal Enfield UCE500 Engine gets a Forged 535cc Piston Kit from Hitchcock Motorcycles jkdas Motorbikes 0 11th April 2011 10:11
When did Royal Enfield become "Enfield"? pullin Motorbikes 1 25th June 2010 13:34
500cc Royal Enfield vs NEW 350cc Enfield scottoe Motorbikes 22 13th October 2009 16:47
Used 98 OHC 1.5 efi AT. Initial Comment jagspabla Test-Drives & Initial Ownership Reports 3 30th March 2008 19:29
