Old 24th September 2015, 23:17   #31
pathik810's Avatar
Default Re: Enfield: Upgrade from BS26 to BS29 carburetor?
A) Would look at the float level.
But considering it is a homebrew, would look at two other things: Is the carb level? And in normal idling, is the butterfly position controlled by the idling screw, or by the throttle cable , which is shifting position when using the front brake lever.
Talking about the two things you have mentioned, can you please elaborate what "Is the carb level?" means? Couldn't figure it out exactly.
For the 2nd thing, the butterfly position is controlled by the idling screw and the throttle cable is entirely free and it is not shifting position rigidly while I use my front brake or even if I turn my handle bar left or right at extreme. However the problem which I am facing does not only happens when I pull the front brake and shake my bike but it also happens when I am just sitting and just bounce my self a bit while sitting, or say when I keep the rear wheel of the bike at a higher level on a step or something. Also, when I decelerate the bike just by using the rear brakes or both the brakes. In short it is happening when the front portion of the bike is leaned downwards.
pathik810 is offline   Reply With Quote
Old 25th September 2015, 11:14   #32
Thanked: 659 Times
Sutripta means that you need to check whether the carb is horizontal. If the carb is tilted, the jet may be only partially submerged in the float bowl. When the fuel sloshes around because of braking, tilting, acceleration, etc., the jet may no longer be submerged in fuel causing fuel starvation. Two things to do are to first ensure that the carb is mounted horizontally and then to check the float height.
Motard_Blr is offline   (1) Thanks Reply With Quote
Old 25th September 2015, 21:48   #33
Thanked: 2,394 Times
Infractions: 0/1 (4)
As Motard blr has explained.
Sutripta
Old 23rd May 2018, 12:32   #34
pathik810's Avatar
Hello Everyone,
Kindly excuse since I have been away from this project. Basically I could not succeed in installing the BS33 carburettor because it proved to be over sized for my 350 CC AVL. Faced a lot of minor issues like uneven idle, jamming of un burnt fuel in the intake manifold, black smoke from exhaust and really low fuel efficiency, lower than I expected. I tried different combinations of the pilot and main jets as well but it did not work.
Finally I ended up fixing the BS 29 carburettor with stock jets. Dint had to change any thing after that. It is running perfectly till date with increased gear shifting range with low vibrations and increased acceleration. Also, it did not make any great impact on the milage as well.
And yes, with the increased shifting range, I have to take care for not revving it too high because as a side effect, oil seals start leaking.
Thank you!
pathik810 is offline   (1) Thanks Reply With Quote
esteem engine (carburetor) needed asap nitroxx Shifting gears 1 12th April 2015 16:22
Need help for my old zen carburetor satish_tns Technical Stuff 4 26th August 2009 23:52
My Experience of using Carburetor Spacer finetuning Technical Stuff 13 15th September 2008 17:08
Help Carburetor....Bullet 500>>or<<RD 350 malvechaitanya Motorbikes 9 31st August 2008 14:50
Difference Between MPFI/Carburetor LPG Kit ? gameonrwind Modifications & Accessories 4 6th March 2008 14:52
