Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 30th August 2006, 08:16   #1 (permalink)
Default Help needed from Bike Gurus ...
Recently the front wheel bearing of my bike was replaced at
service by Kalyani-Bajaj (Mekhri circle). I'm noticing a weird
problem with the front wheel now. When cold, there is no
apparent problem. However, after a few kms ride, the wheel
seems to stick, -- some screeching noise comes when I
manually rotate the wheel after stopping, and the rotation is
not as free as when cold (during ride it is diffcult to tell if
there is some problem) !
At Kalyani-Bajaj I was told there's nothing to worry, -- some
rubber bushing was coming in contact, and just needed
lubrication ! However, the problem persists. So I need to go
back to get it really fixed. But this time I'd like to go with
some basic clue to the possible problem(s). I can't guess it
myself, so I need help from bike gurus at TBHP. This was my
first service at Kalyani -Bajaj, and I got a feeling that in general,
the mechanics there are too inexperienced and/or incompetent.
Thanks in advance for your help.
meerkat is offline   Reply With Quote
Old 30th August 2006, 12:08   #2 (permalink)
the_trooper's Avatar
i m no guru, but sounds like your brake pads are rubbing against the disc.
check if the brake pads and disc assembly have been mounted properly.
the_trooper is offline   Reply With Quote
Old 30th August 2006, 13:51   #3 (permalink)
Thanks. I'd ask for this check-up. But why there should be any difference between
when the bike is cold, and right after it has run several kms ?
Old 30th August 2006, 14:11   #4 (permalink)
pdev29's Avatar
dude make sure that they have not tighten the front wheel very hard, try to loose it by say one round..(the front fork rod).. check for any type of friction..
pdev29 is offline   Reply With Quote
Old 30th August 2006, 17:14   #5 (permalink)
Well when you start hearing the rubbing noise, drive for a while(don't use the front brakes at all). Stop, and check for the disc heating up.
If it does, it's the disc brake.
Check for any markes on the tyre too.
Samy
urdudesamy is offline   Reply With Quote
Old 31st August 2006, 09:13   #6 (permalink)
Hi Meerkat,
I have just come out of a problem fix at the same place.
Dont waste your time with the supervisors and mechanics, they just want to push you through, hoping the problem gets fixed somehow or goes away. The supervisor there has no concept on what to focus on.
Go to the works manager (I think Mr Naik) and sit with him, preferable not in the morning and evening (when the rush is there).
My take is that maybe the bearing has not been seated properly, so after a little distance it heats up abnormally and therefore the increased friction.
Vicki_Rau is offline   Reply With Quote
Old 31st August 2006, 16:34   #7 (permalink)
Default Thanks
Thanks for your help, guys.
Hi Vicki, thanks for your valuable tip. I'll try to meet with Mr. Naik to get the
problem resolved.
Cheers.
Thread Tools
Audio Gurus: Help Needed Praneet71 Ask the Gurus 12 7th August 2007 11:04
Needed a second hand bike for around 40 k kooldude Shifting gears 0 16th April 2006 22:18
Imported bike needed cvinoth Motorbikes 11 17th December 2005 11:28
A BRAND NEW 600+ bike needed prav Motorbikes 6 29th March 2005 15:55
Needed a 600 Bike tabrez02 Shifting gears 14 23rd February 2005 18:36
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
