Old 4th July 2006, 06:42   #16
revtech's Avatar
Thanked: 35 Times
green devil what speed/rpm do you normally ride at.whats rpm to you shift gears at.as of now i shift before 5000 rpm hence get a good FE.a
also after installing the K&N did you upjet ?
Rev
revtech is offline   Reply With Quote
Old 30th July 2006, 14:06   #17
HOW TO GET GOOD FUEL EFF FROM UR pulsar 180 Dtsi
1) Kick start bike every morning with slight choke and idle around 2 min at 3k to 5 k rpm.
2) Drive less then 45 km/hr for first one - two km each day : Less than 50 km/hr for first 5000km
3) Minimum use of clutch.
4) Drive in high gears and low rpm
5) Dont over accelerate !
6) Use SPEED+ 2ml Iftex per litre of Fuel
7) A single user is prefferred !
8) For first 5000 km use the bike on good roads with less traffic.
WELL DO THIS only for first 5000 km and then see the bikes performance after that !!
prashant_1344 is offline   Reply With Quote
Old 31st July 2006, 11:54   #18
N.J
as for the paint peeling off, here in hyd, i went to rahul bajaj and they fixxed it for me, free of cost,
my underwent a punture and they used this spaner sorta thing to remove the tube from the wheel, that got scrathes on the wheel alloy. pliase be careful when doin that. the bajaj ppl fixed it for me
N.J is offline   Reply With Quote
Old 2nd August 2006, 10:44   #19
thunder's Avatar
Thanked: 11 Times
Angry Problem in pulsar
Hi Friends,
I have a Pulsar 180 DTSI (16.5 BHP),I have 2 question question regarding my problem.First recently I checked my engine oil level, it is low but enough for thr ride but after 30min I felt very adnormal burning smell from engine but even after when I was coming back to home I did not felt any acceleration or any engine problem , then what could be the issue?also it crossed 1700 km in same engine oil I soon I will chage it but I more concerned about the engine plz tell is it any symptom of engine damage.
Second I want the Xeneon or any other alternate for powerful light probably without changing whole wiring , is there any way out.Also with K& N filter which Jetter size is good for max power.
Pulsar 180
6 long trips!
Latest - Delhi-hemkunt shahib-Badrinath-Mana-Nanital-Delhi
Next-Kinnaur(3days in total)
objects seen in mirror r disappearing rapidly
thunder is offline   Reply With Quote
Old 8th August 2006, 03:58   #20
Thanked: 62 Times
Hay Thunder ,
I just replied to your other thread.
Well simple test is to check if the bike emmits smoke .. There should be no smoke from the exaust. In case you have a engine problem the Spark Plug will be black -- check that as if oil is being pulled up to the engine it will burn and blacken the plug apart from that the gears will be hard but the engine will be smooth for the first few KM before it overheats. If every thing else is fine get the bike checked by a good mechanic and tell him to check the Valve setting -- company service guys tighten them too much to make it sound smooth also check the timing.
It can be as small as a spark plug gone bad tryu changing it ..
Originally Posted by thunder
Hi Friends,
Pulsar 180
6 long trips!
bhogalrajnish is offline   Reply With Quote
Old 10th August 2006, 12:23   #21
dodge's Avatar
jkdas whose busa is tat i think i saw t same in ekm.. in chitoor road
dodge is offline   Reply With Quote
Old 13th August 2006, 17:48   #22
deepak_vroom's Avatar
Why do you have to buy a P180 then.. Sum 100 0r 125cc wil do if u are so very milage conscious... Wts the use in buyin bikes like Zma n P18 if u are not using the full power...????
deepak_vroom is offline   Reply With Quote
Old 3rd September 2006, 14:38   #23
gonecase_01's Avatar
Default Tyres for pulsar dtsi???
hey guys
just a small query
has anyone heard about the pulsar tyres by a company called ralco
i heard that they are almost as good as michelin or pirrili.
i mean by the price they quote roughly half of that of michelin.
p.s. i have the old pulsar with 18inch wheel
gonecase_01 is offline   Reply With Quote
Old 3rd September 2006, 14:54   #24
Rudra Sen's Avatar
Thanked: 4,292 Times
Mods note: Thread merged.
Old 8th September 2006, 03:49   #25
balenopower's Avatar
Thanked: 228 Times
in't this threas named "Tyres for pulsar dtsi??? ". M reading everything apart from tyres here .. Lol .. a little off topic isn't it
balenopower is offline   Reply With Quote
Old 8th September 2006, 13:11   #26
revtech's Avatar
Thanked: 35 Times
i agree only the last post before the change was made relates to tyres.everything before that is just a genral discussion on the new pulsar.
i wonder why it was changed ?
Old 8th October 2006, 00:01   #27
i have a pulsar 180dts v2 and the paint started peeling of from the engine at 9000 km,the guys at bajaj repainted the full engine block under waranty and the bike has now crossed 15000 km without any paint peeling out
use castrol power 1
motophsycho is offline   Reply With Quote
Old 11th June 2007, 12:48   #28
hey guys still no reply for the tyre part...
my tyre has gone flat now , planning to get pirelli 100/90r18 or the new mrf design in 100/90/r18...
guys suggestions please....
Old 11th June 2007, 14:32   #29
noidaboy's Avatar
Thanked: 260 Times
i think pirreli is a better option..
noidaboy is offline   Reply With Quote
Bajaj Pulsar 150 DTSi Series 2- Test Drive islero Motorbikes 17 22nd July 2016 10:02
Pulsar 180 dtsi 700 Km Review revtech Motorbikes 117 20th January 2007 21:21
Which bike to buy? Pulsar 180 DTSi or CBZ? abhijit Motorbikes 44 4th January 2006 02:10
Baleno vs SLK vs Accent GTX vs Pulsar 180 DTSi v1p3r Street Experiences 6 16th July 2005 22:36
Pulsar 150 DTSi or Unicorn?????? 1000bhp Motorbikes 5 28th February 2005 21:21
