Old 6th September 2006, 13:12   #1
hi guys,i have a pulsar 180 old model 2002,since last few months i am facing a problem my bike does not go above 115@km ,first i used top easily top till 127@km , i dont understand the problem even the bajaj service center mechanics can guess the problem,i checked each and every thing the carb is ok,spark plug is new,clutch is ok the piston,piston ring crank bearings,chain sprocket silencer tyres each and evey thing is perfect then wat is the problem.no mechanic can guess it out i dont know wats the prob guys pleas help me out with the solution.thanks a lot.
rallyrider is offline   Reply With Quote
Old 6th September 2006, 13:30   #2
naveendhyani's Avatar
Thanked: 7 Times
there is a usual drop in performance after a couple of years. just like the bike peaks its performance around 10k mark. this is what i have felt with my CBZ over 6 years time.
though only more experienced members can either tell whether its correct or not.
naveendhyani is offline   Reply With Quote
Old 6th September 2006, 15:54   #3
Hey, 2002 model and 127kmph till a few months ago. Thats great. I lost the engine smoothness, especially while picking up after 35k on the ODO.
There is no doubt, this is one point found badly wanting in Bajaj vehicles as compared to a Honda, who are reknown for the refinement of their engines.
Vicki_Rau is offline   Reply With Quote
Old 6th September 2006, 16:31   #4
Default thanks
thanks vicki but is this ok means now my bike wont be able to touch 125 again but ya some times means very rarely when i get a long run very rare i touch abt 122km.
Old 6th September 2006, 17:02   #5
black12rr's Avatar
Thanked: 274 Times
It might be that you are acullay doing that much. The seepdo and worm might have worn out and giving a wrong speed.
Also look for chain set and did you go in for 17 inch wheels and check the tyres also.
black12rr is offline   Reply With Quote
Old 7th September 2006, 02:57   #6
rohitbagai's Avatar
Thanked: 226 Times
Get the compression checked by the service center. ..Also what is the maintenance history of the bike?...also you can check the air filter and clean it or even change if its worn out. check the the petrol filter too
rohitbagai is offline   Reply With Quote
Old 7th September 2006, 03:23   #7
ssjr0498's Avatar
Thanked: 120 Times
Bro,
just by saying that ur clutches are ok.. they need not necessarily be ok... get them checked and replaced, after that what engine oil are u using!!, plus get ur tappets checked.. if they are too tight then the bike wont hit its top speed.. like wise if it is too loose u'll have problems..
What petrol are u feeding ur bike..
There are many a things that can cause this problem..chk these first.
My CBZ is 7 yr old and i still can manage a cool 117kmph (gtec reading).
Shrey
ssjr0498 is offline   Reply With Quote
Old 15th September 2006, 10:21   #8
M77
M77's Avatar
Thanked: 9 Times
Have you gained weight lately?
M77 is offline   Reply With Quote
Old 15th September 2006, 12:06   #9
Have you done the Decarbonizing that also has impact on the top speed of the bike. I too have P180 2002 Model after the decarbonizing and cluch plate replacement. My bike has become very smooth. And One Highway now I goes near to 120Kmph....
And for Petrol, I never use Speed. Coz i have seen the performance of bike goes down with Speed oil.
Xfade is offline   Reply With Quote
Old 17th September 2006, 11:53   #10
BunnyPunia's Avatar
Thanked: 220 Times
This aint true, specially for moden day machines.
Regarding the Pulsar problem, does it smoke in the morning? Are tyres rotating freely when put on the main stand? When was the fuel and air filter last replaced? When was the carb last tuned? They are many many factors which are responsible for a bike loosing its steam over a period of time..
BunnyPunia is offline   Reply With Quote
Old 12th October 2007, 15:00   #11
redrage's Avatar
Thanked: 60 Times
OT: I am experiencing the same problem in my ZMA, bike used to clock 135-140 approx on the speedo, now it struggles to touch 125. I need help badly, by the way is this got to do anything with the cam tensioner of the bike?
redrage is offline   Reply With Quote
Old 10th October 2008, 00:05   #12
pulsarmaniac's Avatar
Thanked: 9 Times
looks like noone is interested in this thread anymore.mods please close this thread...
pulsarmaniac is offline   Reply With Quote
Pulsar 220 (new) or the Apache RTR 180 - EDIT - Bought Pulsar 220 M abhayshanu Motorbikes 203 1st March 2011 14:27
Pulsar 150 Vs Pulsar 180 !!! EDIT: Its the 180 NOTORIOUS Motorbikes 34 24th June 2010 17:49
Pulsar 180 UG3and Apache 180-for a new bike? EDIT - Its the RTR 180 deepclutch Motorbikes 76 26th November 2009 00:34
What Is The Top Speed On A Pulsar 180 SCARLET Motorbikes 10 1st May 2005 19:14
