Old 2nd November 2015, 16:27   #1
Mr.Boss's Avatar
Thanked: 2,541 Times
Cool Building a 'Pocket Bike' out of a TVS Scooty ES
I'm in the process of making pocket bike out of Scooty ES for a 12 year old kid. Idea started some 4 years back and I could make it happen now.
Disclaimer:
- This bike will not be taken to public roads.
Base Vehicle Details:
Make : TVS
Model : Scooty ES
Year : 2000
Why Scooty ES?
Scooty ES is the cheapest and safe best. People suggested to get Kinetic Honda or Bajaj Sunny which are available at scrap rates. Those samples I came across were already at their end of life, few rust buckets with bits and pieces of broken plastic around. The subject Scooty is single owner, well maintained and mechanically fit with valid documents. Without a second choice got her and started stripping.
Modifications Planned:
- Length & Height reduction
- Single Seat
- Exhaust routing under the seat
- Fuel tank in the front (Bike like)
- Limiting Top speed (Yet to finalize how to control)
Posting few snaps now. Let me update the progress every evening.
Base vehicle
After 30 mins
Started chopping the unwanted bits & pieces
Mr.Boss is offline   (22) Thanks Reply With Quote
Old 3rd November 2015, 09:07   #2
Mr.Boss's Avatar
Default re: Building a 'Pocket Bike' out of a TVS Scooty ES
Wheelbase reduced by 200 mm
Chopped the frame and welded
Exhaust routing to be modified. Stock silencer bend will harm the kid's leg
Mr.Boss is offline   (15) Thanks Reply With Quote
Old 3rd November 2015, 11:26   #3
jeepster's Avatar
Thanked: 1,036 Times
Nice idea sir ji!!
One suggestion: please add speed governor of some sort. (doing 60kmh is not good)ke design
Do consider reverse trike design, it will be much safer for the kid.
rgds,
Nikhil
jeepster is offline   (10) Thanks Reply With Quote
Old 3rd November 2015, 11:38   #4
Mr.Boss's Avatar
Originally Posted by jeepster View Post
Nice idea sir ji!!
Thanks Nikhil. I'm currently working on the speed governor (yet to finalize)
3 Wheeled proposal looks good and confident inspiring, may be I will keep it for future project.
Mr.Boss is offline   Reply With Quote
Old 3rd November 2015, 14:07   #5
Mr.Boss's Avatar
Proposed Exhaust routing
Mr.Boss is offline   (6) Thanks Reply With Quote
Old 3rd November 2015, 15:10   #6
Rehaan's Avatar
Thanked: 25,043 Times
Cool project, and lucky kid!
One concern with this particular part of the modification is altering the bike's front fork rake. Even small changes here can create very different behaviours due to the altered geometry. Not sure how aware you are of this, but I suggest you do some reading on the topic to be safe.
I had once changed the front fork on my mountain bike to a slightly taller one with more travel and a different offset. As a result, my bike became a little more twitchy (which is fine), but the crazy part was that if I turned my handlebars more than a certain amount, the front wheel would have a tendency to buckle, turning around to almost face me -- which resulted in me flying off my bike several times, at the most unexpected & slow moments.
Just mentioning this so that you're aware and can check out the bike thoroughly before handing it over.
Rehaan is offline   (6) Thanks Reply With Quote
Old 3rd November 2015, 16:13   #7
Jaggu's Avatar
Thanked: 8,692 Times
Default Re: Building a 'Pocket Bike' out of a TVS Scooty ES
Interesting project you got there.
What are you plans for the suspension or planning to keep the stock ones?
Also like Rehaan mentioned, with reduction in wheel base the rake and trail dimensions have now changed quite a bit. Hope this was kept in mind?
If it is for a 12 year old, i would first focus on safety and stability more than the speed. Ideally lock it to 35-40 kmph by restricting the carb slides.
Jaggu is offline   (4) Thanks Reply With Quote
Old 3rd November 2015, 16:36   #8
Mr.Boss's Avatar
Thank you Rehaan & Jaggu for the suggestions.
Rake & Trail remains unaltered. Double checked by measuring with an inclinometer.
Stock Suspension will remain as of now. In future I may upgrade to better telescopic forks in the front. I'll take any suggestions on this subject for future upgrade (I understand the stock setup will spoil the fun)
Mr.Boss is offline   (1) Thanks Reply With Quote
Old 3rd November 2015, 16:47   #9
Thanked: 49 Times
@Mr.Boss,
Warning: Shorter wheelbase will increase the rear wheel displacement angle, which in turn reduces the directional stability. Moreover, load transfer during acceleration and breaking will be higher. Chopping the frame is going to affect CG too. Sorry, but I am not sure you should be doing these modifications, especially when the modded vehicle is to be used by a 12 year old. I hope you do extensive testing.
rselva is offline   (2) Thanks Reply With Quote
Old 3rd November 2015, 16:51   #10
Jaggu's Avatar
Yes its got minimal travel so wont be great on broken stuff, but smoother surface would be just fine. Also the brakes are ok only for speeds under 40, above that they take quite a while in scooty.
Replacing the front will be a more complex task, the new TVS vigo is the one's that comes to mind that would be kind of within limits for this project.
Jaggu is offline   (2) Thanks Reply With Quote
Old 4th November 2015, 18:02   #11
psurelia's Avatar
Thanked: 447 Times
Cool project! I am totally hooked to it. It's really interesting to see how the project shapes up day by day. Do you have a vision of how the bike is going to be? I would really love to see a cute little chopper
psurelia is offline   (1) Thanks Reply With Quote
Old 5th November 2015, 12:50   #12
pugram's Avatar
Thanked: 36 Times
Nice work !!
I have a feeling the end product might resemble the "Bobby" bike from Rajdhoot.
All the best.
pugram is offline   (1) Thanks Reply With Quote
Old 9th November 2015, 12:34   #13
Mr.Boss's Avatar
Infected by Viral fever for past 1 week and I'm getting recovered now. Sadly I will be travelling abroad in a couple of days and this project will be put on hold for another 4 months
A mix of Chopper and Bobby
Kid loved Thunder Bird and this bike will have the design hues of the same.
Old 9th November 2015, 16:10   #14
Thanked: 57 Times
https://en.m.wikipedia.org/wiki/Pit_bike
proton is offline   (1) Thanks Reply With Quote
Old 1st March 2017, 23:06   #15
Mr.Boss's Avatar
It is over 1.5 years and the project is left untouched doe to several reasons and commitments. I'm finding difficulties in getting leisure time or an appointment from my beloved mechanic (for this particular work) to resume the job. Left with only 2 options now
- Get it done before this summer (that's the time frame given by home minster to clear the space)
or
- Trade off
If I couldn't succeed with option 1, let me know if someone could take-up this project.
TVS Scooty Pep+ vincentt Motorbikes 17 10th June 2013 16:19
TVS Scooty Streak - Engine Opened at 6500 Km !! idea Motorbikes 9 3rd November 2010 22:00
TVS Scooty TEENZ (Electric) ...I bought it herculesksp Motorbikes 12 12th July 2010 10:22
Work Shop Manual for TVS Scooty ES prasannamukund Technical Stuff 0 8th March 2009 23:04
Pocket Bikes and Pocket Bike racing Edmund Motorbikes 28 13th December 2008 17:25
