Old 19th October 2016, 15:41   #46
vrvarier's Avatar
Thanked: 31 Times
Default Re: Electrified! My Royal Enfield Electra
Originally Posted by adityadeva View Post
First calculation of average fuel consumption
The Deep green got filled up for Rs. 500 @ Rs. 62.12 per litre with the Odo reading 9 kms. Around 8.xx litres went into the tank which had just around 1.5 litres in it.
In reserve the tank consumes 2.5 litres, so out of 8 litres 1 litre went to reserve.
The next reserve came at 383 kilometres.
So total kilometres run on 7 litres of petrol = 383 - 9=374
Average fuel consumption = 374 7 = 53 kms /litre.
Seems good enough, anyways it's above 50 even if the initial petrol in the tank was 2 litres.
tomorrow the deep green will go for first service
Hi, Belated wishes on your ride.
Do you have any latest figures on the mileage? 53 was an awesome figure. I always heard it to be in the twenties.
regards,
V.
vrvarier is offline   Reply With Quote
Old 20th October 2016, 19:04   #47
adityadeva's Avatar
Thanked: 89 Times
regards,
V.
I've been using an app called drivvo to keep tab of the entire expenses (including servicing) . Here's a screen shot which shows the average fuel consumption from the date of purchase.
Hope this suffices.
Electrified! My Royal Enfield Electra-screenshot_20161020192844523_br.com.ctncardoso.ctncar.png
adityadeva is offline   (2) Thanks Reply With Quote
Old 16th September 2017, 12:30   #48
naturaldisaster's Avatar
Thanked: 99 Times
Hi. How has your experience been with your Electra? Have you noticed the motor getting smoother as the mileage piles up? I have a 2011 Electra and since i do a lot of highway riding, she is used to highway speeds. In fact she is quite smooth even at 80kph.
Btw. I feel that the 35w headlight is just not good enough. Have you made any lighting changes? Thanks.
naturaldisaster is offline   Reply With Quote
Old 17th September 2017, 05:42   #49
adityadeva's Avatar
Thanked: 89 Times
Yes the engine is definitely smoother now. I had met with an accident, so now my rides are mostly confined to city now a days.
I did change the bulb to 60/55w halogen h4. I had some extra bulbs from my last car. The bulb was a straight fit and lights are definitely better now. I had seen in youtube that one guy got a 35w h4 led with cooling fan from Ali express. The light was quite bright and didn't have a black spot, the beam was spectacular . I was interested, but now with the present beam, I'm in no hurry till I fully recover from after effects of my fall from the bike.
adityadeva is offline   (1) Thanks Reply With Quote
Old 19th September 2017, 16:58   #50
Thanked: 99 Times
Thanks for the reply. And get well soon! Bike accidents can be scary indeed.
Also, is it OK to use the 55w bulb on this bike? Heard the power draw is too high and you need to make changes to the alternator for long term reliability.
Old 19th September 2017, 20:09   #51
adityadeva's Avatar
Thanked: 89 Times
to the best of my knowledge all the three variants use same alternator, except that standard uses a heavier crank. batteries are different, 8 AH battery of electra should handle 55w. i'll update if I face any issues
adityadeva is offline   Reply With Quote
Old 21st September 2017, 11:51   #52
Thanked: 99 Times
Thanks. I was speaking a technically adept friend who said that the best way to reduce draw on headlight wiring is to use a relay for power switching but drawing power directly from the battery. I am quite positive that the battery can handle it (since my bike has 35w headlight + 40w of LED aux lamps, 75w on wiring harness after the switch and i face no issues yet.)
Will see how i can manage the wiring without any cutting to get best reliability and let you know too.
Royal Enfield 350 Electra: Restoration & Upgrades ilangop Motorbikes 41 7th March 2016 09:14
Need opinions on Shell Helix 20W - 50 Oil for the Royal Enfield Bullet Electra 4S ron_9191 Motorbikes 14 3rd November 2013 15:01
Long Ride , Royal Enfield 350 CC Electra 4 S - Bangalore to Harihara thimappa Route / Travel Queries 3 18th May 2009 02:35
What are the different ways to reduce weight on a Royal Enfield Electra 5S JayPrashanth Motorbikes 17 31st October 2008 21:03
