Old 20th June 2006, 21:21   #46
revtech's Avatar
Thanked: 35 Times
today i reved upto 6000 rpm and i felt quite a bit of vibration.....i mean i could feel it on my legs from the foot pegs ...is this normall. and i was jus wondering how much will it vibrate when i rev upto 8500 rpm.
@niksin...thanx dude
Rev
revtech is online now   Reply With Quote
Old 21st June 2006, 05:07   #47
revtech's Avatar
Thanked: 35 Times
Originally Posted by 2fast4u
theres no point in ripping now. he had to do that when it was around 500km range.
what do you mean by i should have started at 500 km. whats the reason.but i did occasionally accelerate to a higher speed while riding and then again slowed down to the regular cruising speed.
Rev
Old 21st June 2006, 12:08   #48
Technocrat's Avatar
Thanked: 2,589 Times
Dot worry thats th resonance frequency happen on my ZMA too, basically ata particular rpm the bike vibrates the most, but there is no vibration below & above this rpm, also this will become less over a period of time (might not go totally) but thats fine. I Repeat start ripping your bike else it will be a slow couch & mileage only bike wrt to other 180s
Old 21st June 2006, 12:52   #49
revtech's Avatar
Thanked: 35 Times
hahhaha okay will do that from today.The max speed ive done is 70 so i wont directly rip.i will gradually increase the speed.whats your say on this.
i mean slowly touch 80 then after a while 90 etc..
Rev
Old 21st June 2006, 13:41   #50
Technocrat's Avatar
I had touched 125kph after first 720 kms & like I said its still on stock clutch plates after 29k kms
Rest is for you to decide
Old 22nd June 2006, 01:23   #51
revtech's Avatar
Thanked: 35 Times
dude i dont know if its psycologicaal or what but after reading all this i tried to accelerate and it felt as if the acceleration sucked compared to other pulsars.
so is it true that if i didnt rev before 1500 kms that my bike wont perform.honestly i dont believe any of that stuff but youu said its no use now and all so i was wondering...
Rev
Old 22nd June 2006, 09:57   #52
Technocrat's Avatar
Even I cant prove it technically but one of the guy in pune who had bought ZMA around teh same time I did & while I was getting not more than 36kpl this fella was getting 50 :o & we did notice that his bike was slow.
Anyways after my pulsar I used Breake in technique on my ZMA than runin i.e. after 500 kms I started taking her by 10-15 kph more by every 100 kms.
Just do gradual speeding, as for you dont worry start ripping her & get rid of her bad habit of good mileage
Old 23rd June 2006, 07:55   #53
revtech's Avatar
Thanked: 35 Times
let me know what the pro biking service centre in pune says about the oil as soon as possible.
Thanx Technocrat
Rev
Old 23rd June 2006, 10:12   #54
i've a P180.The service guys were putting 20w40 oil all the time and i notice that the oil was just evaporating from it... i dint know that the oil will run dry that fast and i drove a long distance w/o oil, my engine got seriously screwed.i've changed to 20w50 .. now its running perfect... never try 20w40 on p180..castrol gtx is 20w50.
kphilip is offline   Reply With Quote
Old 23rd June 2006, 12:30   #55
jkdas's Avatar
Thanked: 1,436 Times
I was even billed for 20W40 at a Probiking near Kadavanthara. When I enquired tehy said its a spell mistake and its indeed 20W50
Old 25th June 2006, 21:41   #56
revtech's Avatar
Thanked: 35 Times
just changed my oil.filled Elf moto4.when that guy removed the old oil it was dirty brown.is this normal ??
Old 25th June 2006, 22:22   #57
jkdas's Avatar
Yes, its very normal. Whst was teh price for teh oil?
Old 26th June 2006, 02:53   #58
revtech's Avatar
Thanked: 35 Times
got it for Rs 123.i didnt expect it to be that brown because i just recently started riding hard.andway now its changed so chapter closed.but i still need to find an oil whihc is 20W50.
Rev
Old 26th June 2006, 08:19   #59
jkdas's Avatar
Rev
As I had said in anotehr post, try to get Fusch oil, its an import but heard its good and has all teh wierd JASO etc certifications. Or Mak one from BP or so. Else, if you can eat a bajaj engineer's head and do post what he has to say abt using Castrol GTX or similar 20W50 oil.
Old 26th June 2006, 11:59   #60
Technocrat's Avatar
Yes it was Fuches Silkolene & it matches the P180 requirement to the 'T' used it for around 10-12k on my P180. Its a good engine oil better than what BAL used to put but then I found Power 1 to be better.
@revtech: Sorry Dude still havent check with pro biking here :( will let you know as & when I know
Bajaj PULSAR 180 DTSi @ 50 Months and 30k kms- Detailed Report CrAzY dRiVeR Motorbikes 85 13th December 2011 08:50
Pulsar 150 Vs Pulsar 180 !!! EDIT: Its the 180 NOTORIOUS Motorbikes 34 24th June 2010 17:49
Pulsar 180 UG3and Apache 180-for a new bike? EDIT - Its the RTR 180 deepclutch Motorbikes 76 26th November 2009 00:34
Which bike to buy? Pulsar 180 DTSi or CBZ? abhijit Motorbikes 44 4th January 2006 02:10
Baleno vs SLK vs Accent GTX vs Pulsar 180 DTSi v1p3r Street Experiences 6 16th July 2005 22:36
