Old 26th July 2016, 14:31   #31
dkaile's Avatar
Thanked: 3,351 Times
Default Re: Royal Enfield Himalayan Ownership Thread - Bagheera comes home
Originally Posted by torqueunlimited View Post
I've switched to the mirrors of the new Avenger and they make a HUGE difference.
Do they come in black? Some photos please...
dkaile is online now   Reply With Quote
Old 26th July 2016, 14:43   #32
man_of_steel's Avatar
Thanked: 1,046 Times
The new avenger has blacked out mirrors.
man_of_steel is online now   (1) Thanks Reply With Quote
Old 26th July 2016, 14:45   #33
ku69rd's Avatar
Thanked: 1,191 Times
Dheeraj,
Check out the Bajaj Avenger Street mirrors, they are blacked out and looks appropriate for the Himalaya.
The bajaj V15 also has a similar styled but slightly smaller ones and come in plastic back instead of the metal ones like the Street mirrors.
Image Courtesy: http://www.bikesindia.org/uploads/im...-220-style.jpg
The cost of Avenger Street mirrors are around 780 for a pair in Namma Bengaluru
ku69rd is online now   (1) Thanks Reply With Quote
Old 26th July 2016, 16:02   #34
drive_angry's Avatar
Thanked: 105 Times
Originally Posted by Jude300 View Post
The field of view is really good. Makes a world of difference compared to the stock mirrors.
Attachment 1533676
Attachment 1533677
Attachment 1533678
Congrats brother, This bike is really comfortable esp for a 6"2' like me but the puny engine and unrefined engine from RE doesn't do justice to the bike.
IMHO, the rear of the bike most attractive, with those rugged tires, reminds me of a motocross dirt bike.
Check out the RE Himalayan with Akrapovic exhaust, who knows could be your next mod. It sounds mean for a single cylinder.
Source: Rushlane
http://www.rushlane.com/royal-enfiel...-12200703.html
Just wondering, have you given bar end mirrors a try? they look sporty and cool. Wish you many happy miles on your new acquisition.
drive_angry
drive_angry is offline   Reply With Quote
Old 16th September 2016, 02:34   #35
Jude300's Avatar
Thanked: 289 Times
It's been a while since I posted something about Bagheera. I was busy with work and life and so it has been.
Bagheera is doing great and as I have always said I am mighty impressed.
1900 km Update:
+ There are no creeks or lose nuts or bolts. All parts are intact.
+ Ride is comfortable and the sweet spot is at the 90s.
+ Mileage is around 31 - 33kmpl
- When the engine warns up well especially in heavy traffic, the great shifts become very hard and noisy. Shifting between first and second gear is a real pain. Finding neutral becomes hard too leaving you frustrated to the core. Even though i have my rubber gear cover on, my leather shoes have torn where it comes to contact while shifting gears.
- very mild oil seepage around the RHS engine cover.
- the front mudguard is narrow and it does not protect from water splashing from the front wheel. It send out a heavy splash of water and wets the shoes badly.
- I had changed to the continental GT rear view mirrors. They have started vibrate a bit.
Other niggles faced:
This happened thrice. The bike stalls while on the run as the power cuts off and the instrument cluster turns off. In a few seconds the instrument cluster comes back to life. Got the wrong checked after it haplotypes for the second time and the mechanic said all was fine. It occurred again yesterday and I took it to the service center to check. They have spoken with the territory service manager and have asked me to bring the bike for a thorough inspection next week.
Royal Enfield Himalayan Ownership Thread - Bagheera comes home-1473973460640.jpg
Jude300 is offline   (1) Thanks Reply With Quote
Old 16th September 2016, 07:39   #36
ArizonaJim's Avatar
Thanked: 1,854 Times
Does your motorcycle have a "safety side stand switch" which prevents the engine from running if the side stand is down?
I ask because the regular Royal Enfields sold in the USA have this switch.
It is notorious for causing short power losses which cause the engine to stumble.
Some of us try to adjust its position so that it takes more than a few jiggles of the side stand to shut off the power.
Others, like me, totally disconnected it by unplugging the wire from the switch to the main wiring harness.
While trying to ride my RE with the sidestand down is dangerous, I consider it less dangerous than having the engine quit while I'm near drivers in their cages (auto's).
ArizonaJim is offline   (2) Thanks Reply With Quote
Old 16th September 2016, 08:34   #37
Thanked: 117 Times
Afaik, they are more of an indicator. They don't prevent the engine from running if the side stand is down.
I have started the motorcycle many times on the side stand.
maker_of_things is offline   Reply With Quote
Old 16th September 2016, 08:58   #38
Jude300's Avatar
Thanked: 289 Times
Does your motorcycle have a "safety side stand switch" which prevents the engine from running if the side stand is down?.
No, as maker of things has stated, is just an indication. My suspicion is that there could be some loose connections in the instrument cluster.
I missed to mention this. Last Saturday evening the headlight didn't turn on while on low beam. I had to ride with the high beam on but I was pretty sure that the low beam couldn't have gone kaput so quickly. I was playing with the high and low beam switch and suddenly the low beam burns. I have mentioned this to the service center as well. Will post updates after the check up next week.
Jude300 is offline   Reply With Quote
Old 16th September 2016, 10:00   #39
airfoil's Avatar
Thanked: 64 Times
And finally, that's my garage.
Attachment 1514567
Nice crisp review.
This is sorta off topic:
That is a t.i.g.h.t. fit for the Ford Ecosport. I'm curious to find out how you park it each time without it kissing the wall.
airfoil is offline   Reply With Quote
Old 16th September 2016, 10:34   #40
Jude300's Avatar
Thanked: 289 Times
Ha ha. Many asked the same q. It's practice. Also I am damn slow when I park and that helps. I have rarely kissed the wall gently but it doesn't hurt the car as I am dead slow and it's the number plate that comes in contact with the wall.
Old 16th September 2016, 12:18   #41
Jude300's Avatar
Thanked: 289 Times
Some stuff that I have bought for Bagheera.
BTWIN 500 cable bike lock:
MRP: ₹1500
SALE PRICE: ₹400
Shop: Decathlon, Poonamallee, Chennai
We have CCTV setup in our flat now but I feel it's better to have additional safety to secure our stuff especially when away from town.
Saw this lock in decathlon for a mouth watering price. It's heavy and really strong but has been discontinued now I guess as it's too heavy to carry around. But for me it was not a problem as I wanted it for use while parked at home and not to carry out around. I don't use it daily but when I go out of station. Being black it's not visible unless you look closely. I use the lock to chain the rear wheel to the frame and it hides nicely below the battery compartment. It's 1 metre long and very thick.
Royal Enfield Himalayan Ownership Thread - Bagheera comes home-1474007936760.jpg
Royal Enfield Himalayan Ownership Thread - Bagheera comes home-1474007955368.jpg
Royal Enfield Himalayan Ownership Thread - Bagheera comes home-1474007978039.jpg
Hydration pouch:
BTWIN BLADER 500
CAPACITY: 2 LTRS
MRP: ₹1500
SALE PRICE: ₹800
Bought this hydration pouch to quench my thirst on the drive. I didn't go for the one with the bag as I have a small bag which I guess will help. Have not used it yet and hence cant comment.
Royal Enfield Himalayan Ownership Thread - Bagheera comes home-1474008387184.jpg
Royal Enfield Himalayan Ownership Thread - Bagheera comes home-1474008407835.jpg
Old 16th September 2016, 12:26   #42
CGB
Thanked: 165 Times
Jude, Hello to you! The issue which you are facing is the same i faced with my Duke 390. Please check the wire harness from Engine Kill switch that connects to fuse box. Mine had a loose connection of which the bike shuts down and starts by itself due to loose contact.
I am kilkattalai and wish to meet you soon in person.
CGB is offline   Reply With Quote
Old 16th September 2016, 12:30   #43
Jude300's Avatar
Thanked: 289 Times
Thanks CGB for the info. I ll ask the service guys to check that.
Sure we can meet some time. I come to work to Kandanchavadi. I'll pm you my mobile
Old 16th September 2016, 12:52   #44
Red Liner's Avatar
Thanked: 599 Times
That hydration bag you have is super value for the coin. The pipe's great, you can smoke that water down like a cuban. Pouring water in with that clip style sealer is a cinch. And absolutely no leaks.
Red Liner is offline   (1) Thanks Reply With Quote
Old 16th September 2016, 16:27   #45
Thanked: 117 Times
Have you been doing much riding in the rains? I faced a similar issue on my older classic 500, it used to turn off when I switched to high beam and then wouldn't turn on again at all. I looked at the fuses turned out one of them controlling the lights had been fused. I replaced, and it happened again. I then checked the headlight socket. The bulb turned out to be the culprit as its sockets were corroded.
I'd suggest you take a look at the major sockets and connectors and fuses as well. Some people did face the issue of their Himalayan shutting down randomly, which was resolved by replacing the main fuse.
Royal Enfield Himalayan - Initial Ownership Report arulpeem Motorbikes 101 17th May 2017 14:08
The Royal Enfield Himalayan Test-Ride Thread Jude300 Motorbikes 626 7th May 2017 17:50
The Royal Enfield Himalayan, now launched! Tushar Motorbikes 837 20th March 2016 20:58
Royal Enfield Himalayan Odyssey 2010 - Registrations Open praveen_sathaye Motorbikes 2 6th April 2010 17:54
