Old 29th June 2017, 17:45   #16
Thanked: 32 Times
Default Re: The 2017 Yamaha R15 V3. EDIT: Unveiled in Indonesia
I had a brief chat with one of the Marketing Manager (Kerala) during the recent Yamaha Bash in Bangalore and they have received the V3 version (just one bike from Indonesia). He had test ridden the bike in some restricted track and he said the bike power slides through the gears. He also confirmed that the Indian version will have some significant change in height due to road conditions, might expect some changes in the FI and finally, Indian version will go through some detune : Frustrati
rvd8732 is offline   Reply With Quote
Old 29th June 2017, 19:43   #17
Yusha's Avatar
Thanked: 37 Times
I fail to understand why do they have to detune the bike? The fuel quality isn't that bad in India and as far as weather and other factors are concerned, they are probably the same as in Indonesia.
This is
Yusha is offline   Reply With Quote
Old 29th June 2017, 21:31   #18
Thanked: 32 Times
This is
Yes, agreed with you. When we have mental KTM then why not blistering R15. I just remember something he was discussing FI specifically. I might be wrong but the Indonesian version has about 21 tiny injectors and Indian version might have only 16 . Also, he mentioned something about the electronic unit (can't recall what he called it) which will not be available for the Indian version.
Old 31st October 2017, 15:40   #19
Vignesh_N/A's Avatar
Thanked: 126 Times
R15 V3 spied in Delhi
source: maxabout
Vignesh_N/A is online now   (1) Thanks Reply With Quote
Old 1st November 2017, 21:48   #20
bkc
bkc's Avatar
Thanked: 103 Times
I might be wrong but the Indonesian version has about 21 tiny injectors and Indian version might have only 16 electronic unit (can't recall what he called it) which will not be available for the Indian version.
21 and 16 May be injector pound capacity? and the electronic unit you say is the o2 sensor for closed loop.
Do not detune.
bkc is online now   Reply With Quote
Old 27th November 2017, 20:19   #21
OSH
OSH's Avatar
Thanked: 410 Times
The Yamaha YZF R15 v3.0 is now spotted in India.
The 2017 Yamaha R15 V3. EDIT: Unveiled in Indonesia-imageresizer.jpg
The observations of Autocar India are quoted below.
Split headlamps (LED in international markets, India spec is unconfirmed) separated by a large intake make up the face while the side gets sharp bodywork. The fairing has been redesigned, with the fuel tank now at 11 litres as against the v2.0’s 12 litres. And, unlike its predecessor that had an analogue tachometer, the v3.0's instrument cluster is now fully digital. At the rear, the R1/R6-style hollowed out tail section is sure to find many fans and the pillion seat is noticeably lower than the R15 v2, something which should also find appreciation.
The new R15 v3.0 is running conventional front forks instead of the more premium upside-down ones seen on the international-spec bike. The bike spied was also using MRF tyres and not the IRC ones seen on the Indonesian-spec bike. The spy image also clearly shows that the bike lacks ABS, but so does the international model. This tells us that Yamaha is most likely going to launch the motorcycle before April 2018, because, according to the upcoming regulations, it is mandatory for manufacturers to equip all bike models above 125cc with ABS, for the launches planned on or after April 1, 2018. Existing models will, however, have a deadline of April 1, 2019, to get equipped with the feature.
In the spy shot, the new bike’s engine appears to be different to that of the current R15. This means that we are likely to get the new 155cc single-cylinder, liquid-cooled, fuel-injected engine from the international spec bike. However, this motor features Yamaha's Variable Valve Actuation (VVA) system which helps it make 19.3hp and 14.7Nm of torque. Graphics along the side read "VVA Variable Valve Actuation', which puts to rest previous speculation of whether Yamaha would launch the engine as is, or with a simpler (read lower cost) version without the VVA system.
Expect a launch within a month or two, with the Yamaha YZF R15 v3.0 to be priced slightly higher than the v2.0, which currently sells for Rs 1.18 lakh (ex-showroom, Mumbai).
Source : Autocar India
OSH is offline   Reply With Quote
Old 11th December 2017, 13:40   #22
manaljain's Avatar
Thanked: 238 Times
New Yamaha R15 V3 arrives at dealer – Launch in January 2018
It is spotted for the first time with road ready stickers and dual tone matte red and grey livery.
From the spy images, it is clear that the India-spec R15 V3 gets regular front forks, and not the upside-down (USD) forks which are on sale with international-spec R15 V3. It also misses out on the ABS. Then there is the same V2 like front fender, instead of the broader and more sportier fender of the V3. Tyres are from MRF, instead of the IRC tyres which we have seen on the international spec V3. Foot pegs are same as V2, and not the aluminium assembly. Even the slipper clutch is not expected to be featured.
Source: http://www.rushlane.com
The 2017 Yamaha R15 V3. EDIT: Unveiled in Indonesia-newyamahar15v3dealer.jpg
manaljain is online now   Reply With Quote
Old 2nd January 2018, 10:46   #23
manaljain's Avatar
Thanked: 238 Times
Yamaha YZF-R15 V3 To Launch In India On January 8, 2018
Unofficial bookings for Yamaha R15 V3 are already open at certain dealerships while price is expected to get a marginal bump. R15 V3 is expected to be price around INR 1.25 Lakh (ex-showroom).
Old 11th January 2018, 09:59   #24
nikhn's Avatar
Thanked: 59 Times
Any updates on the release date? It was expected to launch on 8th January and there seems to be no sight of the bike anywhere on the Yamaha website as well.
nikhn is online now   Reply With Quote
Yamaha teases new naked motorcycle. EDIT: FZ25 launched at Rs. 1.20 lakh dZired Motorbikes 340 7th January 2018 11:26
2017 Yamaha YZF-R6 unveiled at AIMExpo theredliner Superbikes & Imports 0 14th October 2016 23:05
Yamaha R25 launched in Indonesia. EDIT: Launch imminent in India! _raVan_ Motorbikes 35 14th December 2014 10:23
Honda CB150R Streetfire Unveiled In Indonesia neerajpv87 Motorbikes 14 7th March 2013 21:16
Yamaha Vixion: Naked Version of the R15 unveiled in Indonesia jkdas Motorbikes 1 2nd November 2012 19:02
