Old 25th May 2017, 21:43   #31
PrasannaDhana's Avatar
Thanked: 3,370 Times
Default re: Rs. 2273 per BHP! Prassy's pre-worshipped KTM Duke 390. EDIT: Now Sold
Originally Posted by VijayAnand1 View Post
Lovely, Prasanna. It was a joy indeed sifting through threads and then reading your 42 year old virgin story.
Cheers!
VJ
Thanks! By the way it is not 42 years story I am just 30 the bike was near 42000 km when i bought it.
Originally Posted by Urban_Nomad View Post
Awesome footage! I liked the lines you took - enter wide, finish tight
Its because of this that you were able to spot trouble in time and take evasive action
Look forward to more from you
Thanks mate!
Do subscribe to my channel "Prassy Rides". I post weekly videos over there.
Odo update: 44,400 km
2500 km in 23 days! Loving the 390 totally!
PrasannaDhana is offline   (1) Thanks Reply With Quote
Old 26th May 2017, 00:13   #32
Thanked: 56 Times
Thanks mate!
Cheers mate. 2500 kms in 23 days that translates to 125 kms a day, thats crazy stuff sir. I have a tbts 350 2014 model and i am ashamed to say that it has only run 7500kms. Will surely check out your channel.
How is the suspension of the Duke? How does it handle bad roads. I am in two minds whether should I stick to my tbts 350 or to buy a new bike that's easy to handle and nimble.
Regards.
Vikvkv is offline   (1) Thanks Reply With Quote
Old 26th May 2017, 18:52   #33
Urban_Nomad's Avatar
Thanked: 1,377 Times
BTW - Just noticed that your bike too has been hit with the infamous "intermittent zero" on the speedo while riding. Better get your stator coil checked before it leaves you stranded on one of your rides
Urban_Nomad is offline   (1) Thanks Reply With Quote
Old 27th May 2017, 08:07   #34
Yes, i think stator coil needs to be replaced. But it happens very rarely though and I dont experience any symptoms of a weak battery.
Btw,
Update: 44444 km on odo
Rs. 2273 per BHP! Prassy's pre-worshipped KTM Duke 390. EDIT: Now Sold-wp_20170527_07_38_54_pro.jpg
PrasannaDhana is offline   (2) Thanks Reply With Quote
Old 30th May 2017, 22:20   #35
Regards.
If you are after ride quality, you should hold on to your TBTS. While duke 390 is in a completely different league when it comes to performance and handling, it is not as comfortable as the TBTS on bad roads.
Old 2nd June 2017, 18:36   #36
Today's footage from my helmet to your screen.
PrasannaDhana is offline   (4) Thanks Reply With Quote
Old 2nd June 2017, 20:05   #37
b16h22's Avatar
Thanked: 115 Times
Btw,
Trust me mate. Get it checked and changed ASAP. You don't want to get stranded in an area with no phone coverage on a Sunday like i found out
The intermittent zero error can quickly lead to the failure without any warning
b16h22 is offline   (2) Thanks Reply With Quote
Old 2nd June 2017, 20:26   #38
Got it checked at the SVC. They checked the stator and told me it was good. Multimeter readings were also normal. I also read pre 2015 models had a defective speedo console which has nothing to do with stator.
I guess I may also have to find it the hard way like you, but then the svc will be facing hell.
Old 10th June 2017, 01:47   #39
Thanked: 124 Times
Dear Prasanna, I have seen the youtube videos, was very funny the way you shout. A few of the videos missed 1 idiot.
Ride safe bro, luck might run out on you. You are doing lunatic speeds on some of the segments. Consider a day at the track, I am sure you will be happy.
YaeJay is offline   Reply With Quote
Old 16th June 2017, 08:32   #40
Ok
Odo update: 45,160 km
Stator coil and battery were good. The ktm svc removed the accessory relay that wasnt being used. Now the intermittent zero doesnt happen.
Rs. 2273 per BHP! Prassy's pre-worshipped KTM Duke 390. EDIT: Now Sold-wp_20170612_07_52_58_pro.jpg
Old 19th June 2017, 14:02   #41
VijayAnand1's Avatar
Thanked: 109 Times
Post re: Rs. 2273 per BHP! Prassy's pre-worshipped KTM Duke 390. EDIT: Now Sold
Ok
Accessory relay? The reason I am asking this is because this is totally a new to me. What was actually removed, did you happen to see what exactly was removed? Or any idea as to how it looked?
Cheers!
VJ
VijayAnand1 is offline   Reply With Quote
Old 19th June 2017, 14:07   #42
VW2010's Avatar
Thanked: 2,124 Times
Just an additional relay which is basically the 4 or 5 pin one may be the previous owner added for some accessories. Fitting accessories is an art and many road side electricians do it like they dont care.
Do it with care its a wonderful way to get all your addons.
VW2010 is offline   (3) Thanks Reply With Quote
Old 4th July 2017, 07:54   #43
4000 km up in 70 days since purchase 57 km per day average.
Odo: 45900 km
I now have a fair idea about KTMs. They may not be as trouble free as a Honda, but they make you fall in love with them more and more with every minor niggle. By the way, tyre nearing the end of its life. Any suggestions? I am happy with Michelin PSR, but are they available in 160 sections? And will it be compatible?
Small niggles I have faced so far, which have been rectified:
1. Key slot loosening
2. Intermittent 0 on speedo
Yet to be rectified:
1. Slight oil leak near oil filter
2. Small crack on airbox (which i have taped as a temporary fix)
Anyways, once on the saddle, the 390 makes me forget all these small issues.
Rs. 2273 per BHP! Prassy's pre-worshipped KTM Duke 390. EDIT: Now Sold-phototastic04072017_579b1177d7cb42eea5d9b4e78e5327751.jpg
PrasannaDhana is offline   (5) Thanks Reply With Quote
Old 7th July 2017, 19:11   #44
Odo update: 46,000 km done!
Rs. 2273 per BHP! Prassy's pre-worshipped KTM Duke 390. EDIT: Now Sold-wp_20170707_15_02_13_pro.jpg
PrasannaDhana is offline   (3) Thanks Reply With Quote
Old 28th August 2017, 19:37   #45
Update:
Been a while since i updated this thread.
Odo: 46,800 km
You could tell that i havent used the 390 much. Reason: Bald tyres! The michelin pilot street radials that were already on the bike was 32000 km old!!! I came to know about it from the previous owner and i was shocked. I couldnt make up my mind to ride with bald tyres.
Tyre choices:
Michelin PSR
Pirelli Diablo Rosso II
Michelin PSR I trust them with my life because I had quite a lot of fun on PSR on my CBR 250R. I also liked Pirelli as it was the best i had on my ZMR, the Pirelli Sport Demon! Finalised on Michelin PSRs as I found it superb on my CBR250R. It still looked and felt new even after 15000 km of usage on my CBR. Michelin radials are extremely long lasting. 25-30k km is easy peasy!
Speed Rating : 210 kmph
Availability: Front 110/70 R17 was easily available at Trichy.
Rear 150/60 R17, no one seemed to have Michelin Radials. All were continentals/MRFs. I did not want to compromise on grip as I push it hard while riding.
I was not in a mood to risk buying in amazon/flipkart as i was skeptical of their originality. So i visited Michelin India official site and it directed to "Trails of India" site. Placed order, It took 15 days for it to reach me.
But i would strongly recommend that site. Tyre came packed in two layers of bubble wrap, no chance for damage!
Cost: Rear 6045 + Front 4400
Labour at KTM ASC: 600
Now that my darling has new wheels, I wil start using it as daily driver. My kwid and Ciaz will be put to complete rest.
Cant wait to clock 50,000 km on the odo
Rs. 2273 per BHP! Prassy's pre-worshipped KTM Duke 390. EDIT: Now Sold-wp_20170828_14_45_13_pro.jpg
Rs. 2273 per BHP! Prassy's pre-worshipped KTM Duke 390. EDIT: Now Sold-wp_20170828_14_45_27_pro-2.jpg
Rs. 2273 per BHP! Prassy's pre-worshipped KTM Duke 390. EDIT: Now Sold-wp_20170828_15_35_29_pro-2.jpg
Rs. 2273 per BHP! Prassy's pre-worshipped KTM Duke 390. EDIT: Now Sold-wp_20170828_17_02_47_pro.jpg
Impulsive Decision: From the Z800 to a pre-worshipped KTM Duke 390 v12 Motorbikes 33 6th March 2018 21:18
2017 KTM 390 Duke, 250 Duke and 200 Duke launched in India nishsingh Motorbikes 187 27th February 2018 10:48
Duke of Ram - My Orange Flame, KTM Duke 390. EDIT : Sold! hillram Motorbikes 65 13th May 2016 07:21
Slipper clutch update available for old KTM RC 390 and 390 Duke Omkar Motorbikes 0 10th May 2016 17:14
India made KTM Duke 390 & RC 390 to be sold in the USA Tushar Motorbikes 1 7th January 2015 13:59
