Old 1st June 2017, 09:09   #1
dZired's Avatar
Thanked: 7,563 Times
Default TVS Motor introduces Sync Brake System in Wego and Jupiter
TVS Motor has introduced its new Sync Brake System (SBS) technology on two of its gearless scooters - Wego and Jupiter. All variants of the two scooters are now equipped with this new technology.
The Sync Brake System essentially provides appropriate proportioning of braking power to the front and rear wheels. As a result, even if the rider pulls just the rear brake lever, the front brakes are applied automatically. The company claims that this can help in distributing the braking power evenly, thus making the braking more controllable and effective.
The SBS technology works on a relay lever that is responsible for co-applying brakes in quick succession. The input force applied on the brake lever is distributed to both wheels through a control mechanism called THE MULTIPLIER, which avoids any division in braking force due to the distribution. TVS also claims that, in addition to enhancing rider safety, the SBS technology can also help in improving the life of tyres and brake liners.
Manufacturers like Honda and Hero are already offering similar technologies in their scooter range, under the Combi-Braking System (CBS) and Integrated Braking System (IBS) names, respectively.
Link to Team-BHP News
dZired is offline   (6) Thanks Reply With Quote
Old 1st June 2017, 13:03   #2
Rehaan's Avatar
Thanked: 25,037 Times
Default Re: TVS Motor introduces Sync Brake System in Wego and Jupiter
This is good, especially for newbie riders and emergency braking situations.
However, how reliable are these combined systems when the brakes are unevenly worn out, or other such situations?
Rehaan is offline   (2) Thanks Reply With Quote
Old 1st June 2017, 13:41   #3
Thanked: 440 Times
Can someone who rides these machines clarify on these points.
If brake force is optimally distributed to Front and Back then whats the need for 2 levers? Can we just have 1 lever on the left side?
Does the brake distribution ration change based on which lever the rider has pulled? Like biased to Rear in case of left brake ?
freedom is offline   Reply With Quote
Old 1st June 2017, 14:14   #4
Rehaan's Avatar
I'm guessing it's something like a brake balance bar:
image source
Source
Rehaan is offline   (3) Thanks Reply With Quote
Old 1st June 2017, 15:03   #5
Accius's Avatar
Thanked: 24 Times
Can someone confirm if this sync brake system is available on disc brake variants of Jupiter and Wego. A nearby dealer denies SBS on disc brake variants. Also colour variants are limited to just two on ZX disc variants of Jupiter.
Accius is offline   (1) Thanks Reply With Quote
Old 1st June 2017, 17:43   #6
alpha1's Avatar
Thanked: 1,035 Times
Surprised to see this, my wife bought a Jupiter in March, and it already has "sync braking".
The lever on the right side operates the front brakes ALONE.
The lever on the left side operates the front as well as rear in a predefined ratio of force split
Last edited by Gannu_1 : 2nd June 2017 at 06:59. Reason: Quoting freedom's post. Posting a member's URL here doesn't give them a notification.
alpha1 is offline   (4) Thanks Reply With Quote
Old 1st June 2017, 19:42   #7
Mr.Boss's Avatar
Thanked: 2,535 Times
SBS / CBS / IBS is applicable on either All drum or all disc configuration only. Combination of disc and drum is little complicated and generally manufacturers don't go for the same.
Mr.Boss is offline   (3) Thanks Reply With Quote
Old 1st June 2017, 20:54   #8
Thanked: 2,394 Times
Infractions: 0/1 (4)
Hardly any more complicated than a disc/ disc setup. Requires one extra mechanical linkage for the rear drum.
Main reason I think is incremental cost (to benefit): Rear M/C, 3 pot caliper in front etc, and yet a rear drum.
Sutripta
Sutripta is offline   (3) Thanks Reply With Quote
Old 1st June 2017, 21:43   #9
Mr.Boss's Avatar
Mechanical linkage from where? Front being a disc brake with hydraulic circuit, it is little complicated to get a mechanical linkage for the rear drum.
Mr.Boss is offline   Reply With Quote
Old 1st June 2017, 21:46   #10
tharian's Avatar
Thanked: 3,163 Times
Makes sense since most of the riders do not use the front brakes at all and use just the rear brake lever.
tharian is online now   Reply With Quote
Old 2nd June 2017, 02:10   #11
Thanked: 166 Times
I wonder if HMSI will find this to be a direct ripoff of their CBS system and maybe take TVS to court much like how Bajaj did with the Dual spark ignition system case that ruled in their favor.
Nithesh_M is offline   Reply With Quote
Old 2nd June 2017, 19:31   #12
Rear also applies front. Not the other way around. And only slightly more complex to implement on a front disc/ rear drum setup than on a disc/ disc setup.
Any bike (whether drum/ drum or disc/ disc) where application of front brakes also apply the rear brakes?
Sutripta
TVS Wego, Review and Comparison with it's rivals. thesign Motorbikes 66 13th February 2018 23:12
TVS Jupiter spied with disc brake and fuel-injection Tushar Motorbikes 18 9th October 2017 11:59
SCOOP! New TVS Scooter spotted testing. Update: TVS Jupiter Launched Redline6800 Motorbikes 32 18th May 2015 21:54
Honda Activa vs TVS Wego. We went with the Wego. drdeepudev Motorbikes 58 24th November 2014 12:03
TVS Wego: Test Drive and Intial Ownership review vidyasagar Motorbikes 9 16th July 2013 16:02
