Old 28th January 2009, 09:32   #16
motomaverick's Avatar
Thanked: 869 Times
Originally Posted by fieroid View Post
no reverse effect. Only effect is improved performance
Threebond is a rubber based gasket paste. It will seal as much as a paper gasket if applied evenly.
Thanks for the info, any idea where we can get this Threebond paste in bangalore? Is it available in any auto accesories shop?
Old 28th January 2009, 14:00   #17
Sankar's Avatar
Thanked: 4,656 Times
Try at any two wheeler spare dealer. It's not that hard to get. Yamaha showroom may also have it.
Last edited by Technocrat : 29th January 2009 at 16:57. Reason: Moved posts to new thread & removed references
Old 28th January 2009, 16:29   #18
fieroid's Avatar
Thanked: 287 Times
Threebond is available at any 2-wheeler spares shop.
fieroid is offline   Reply With Quote
Old 29th January 2009, 09:39   #19
Thanked: 869 Times
How does reducing the thickness or the paper gasket from the cylinder head increase the bhp by 1.5. I guess this power is measured at the crank?
Old 29th January 2009, 09:40   #20
Thanked: 869 Times
Instead of 'My karizma mods & Ideas' now the thread looks like 'Our Karizma mods & ideas'... ;-) Carry on with the discusions guys!
Well could not help it as there was no dedicated thread for Karizma mods
Old 29th January 2009, 14:57   #21
By removing the cylinder base gasket ,and applying 3 bond in its place ,you reduce the piston head clearence by 0.5 mm(the thicknesss of the base gasket),increasing compression and increasing power/
cheeers
venugopal is offline   Reply With Quote
Old 29th January 2009, 17:36   #22
its.me.ankur's Avatar
So does this also hold true for any bike any make like Bajaj/Tvs/Yam/Honda etc??
its.me.ankur is offline   Reply With Quote
Old 29th January 2009, 19:46   #23
fieroid's Avatar
Thanked: 287 Times
All engines will benefit from higher compression. However just check if you have the right tolerance to play with. In all cases you can blindly go for a 0.5mm reduction on all bikes, from a CD100 till a Karizma.
Venu has made it clear above.
Old 30th January 2009, 14:12   #24
thanks for clearing my doubt would try that out on my P-150 dtsi, how much increase can I expect in my Pulsar 0.5 BHP-1 BHP??
Old 1st February 2009, 20:22   #25
scorpian's Avatar
Thanked: 235 Times
Infractions: 0/1 (5)
Am confused...which gasket are we talking about,the one thats on top(the portion where the valves etc are)or the one thats at the base where the block meets the crankcase?
scorpian is offline   Reply With Quote
Old 1st February 2009, 21:12   #26
Sankar's Avatar
Base gasket, the one between between the block and the crankcase.
Old 2nd February 2009, 11:57   #27
yesterday i asked my mechanic about this mod(remove gasket with threebond). And he told me two things.
1. By removing gasket i can increase the compression ration but it also looses the timing chain as well. And this could cause the fast wear and tear of chain and chain tensioner as well.
2. Threebond is not a 100% replacement of gasket.
So my only concern is point 1, As everybody know how much a karizma's chain tensioner cost
sudhi_des is offline   Reply With Quote
Old 2nd February 2009, 16:28   #28
is there any after market front indicator for karizma ? i dont like yellow colour, plain will suite much better.
if its available in bangalore let us know please
how about changing the karizma handle bar and putting P220's ? will it be a direct fixing or any mods will be needed ?
smart2smart is offline   Reply With Quote
Old 2nd February 2009, 18:12   #29
Sankar's Avatar
1) Cam chain tensioner would take up that slack. Use new Karizma's chain tensioner.
2) If not threebond, you can use anabond silicone rtv sealant. Definitely a complete replacement for gasket.
Old 2nd February 2009, 20:19   #30
fieroid's Avatar
Thanked: 287 Times
Looks like your mechanic is more knowledgable than a motoGP engineer.
The 2 solutions are,
1. Yes, u will increase the compression and FYI the cam chain tensioner can accomodate upto nearly 2mm of extra slack easily.
2. Threebond is not a sealant? Threebond is used in sealing crankcase bottoms/cylinder head covers(which ideally require more sealing compared to a cylinder base....which does hardly any sealing job) and have very high heat resistance.
I'm just giving a few short cut tips to get some kicks out of your karizma.
My Karizma Mods & Ideas! Sankar Motorbikes 480 26th June 2017 14:24
Rumour: Hero Karizma, Karizma ZMR production stopped Aditya Motorbikes 45 21st November 2016 11:36
Hyderabad:Need Suggestions on various Mods for Karizma xxaarraa Motorbikes 52 19th January 2009 15:45
Karizma rear tyre upgrade. Need suggestions! Sankar Motorbikes 46 10th September 2008 09:04
