Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 5th December 2006, 21:06   #1 (permalink)
abdriver2000's Avatar
Default Oil Leak on my bike
Hi Friends,
I have been noticing an oil spill on the floor for past 2 days where I park my bike. The spill is hardly noticeable, about 1-2 drops only. It seems to be leaking from the base of the bike.
Is it anything to worry about? I have seen bikes leaking gallons of oil and still running fine. Is this something to do with the age of the bike?
My bike is a March 2003 Kawasaki Bajaj Caliber 115, 53000 kms on the odo, everything stock, treated with TL&C every 2500kms.
Thanks,
abdriver2000
abdriver2000 is offline   Reply With Quote
Old 6th December 2006, 03:52   #2 (permalink)
Yusha's Avatar
Get the neutral switch checked in the next service. The most likely place from where the oil is leaking.
__________________
Not a shred of evidence exists in favor of the idea that life is serious.
Yusha is offline   Reply With Quote
Old 6th December 2006, 06:15   #3 (permalink)
Maybe an oil seal has blown. get it checked at mech's.
SunnyBoi is offline   Reply With Quote
Old 6th December 2006, 08:22   #4 (permalink)
quadra's Avatar
I had faced the same issue with my bike. The place from where the engine oil is taken out from [ when its changed ] that has a rubber ring that prevents oil from leaking. Get the rubber changed ASAP. The bike cannot run without engine oil.
quadra is offline   Reply With Quote
Old 6th December 2006, 09:56   #5 (permalink)
kph
kph's Avatar
Competition for bullet...
__________________
ridelogs.blogspot.com
kph is offline   Reply With Quote
Old 6th December 2006, 11:24   #6 (permalink)
yogesh sarkar's Avatar
It might be from the chain, check the oil drain nut and see if it is wet.
yogesh sarkar is offline   Reply With Quote
Old 6th December 2006, 20:44   #7 (permalink)
im still facing that on my bike... i have checked several times the oil seed but actually its fine. what i notice that near my front rear sprocket cover is the grease and a lil oil leak .. i thihnk u must just wanna check that area.
nosfreak is offline   Reply With Quote
Old 7th December 2006, 10:27   #8 (permalink)
I have checked the oil drain nut and the front sprocket. These don't seem to be the issues.
Old 7th December 2006, 11:17   #9 (permalink)
katalyst's Avatar
Like Yusha said, get your neutral switch /gear lever checked. One of your oils seals must have gone bust - could be due to physical force or due to chemical reaction...
__________________
1984 Yamaha RD350
2000 Mitsubishi Lancer GLXI
katalyst is offline   Reply With Quote
Old 7th December 2006, 18:59   #10 (permalink)
ThE_DoN's Avatar
Oil seal leakage OR Gasket leakage OR simply put Chain oil (if so then heck your side stand for oil)
ThE_DoN is offline   Reply With Quote
Thread Tools
ARTICLE: Synthetic oil vs Mineral oil GTO On modifying a car 1013 14th July 2008 12:05
Strange water leak in my Palio pawan_pullarwar Technical Stuff 22 11th May 2008 06:07
brake oil leak and Fiat parts sreenivass Technical Stuff 8 23rd January 2007 09:08
How does one find a vaccum leak in a carburettor? techn0l0gist Technical Stuff 1 13th January 2007 23:54
Power Steering oil Leak dev Technical Stuff 9 24th May 2006 14:45
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429
