Old 23rd December 2006, 21:03   #16
chilled_fire's Avatar
Originally Posted by yogesh sarkar View Post
chilled_fire it all depends on how much kms you have used your motorcycle and even than how much abuse the suspension has taken. If the travel of suspension has increased and it gets a bit wobbly try to change the suspension setting to harder and see if it helps. Also I got my pulsars suspension changed after three years, it costs Rs. 600-650 for the new rear suspension in Delhi.
Thanks Yogesh for the information .
yeah you are right sometimes it gets abit wobly.
but is it possible to fit gas shocks in the old pulsar , my garage wala said that the gas shock suspensions of new pulsar have angle difference so they are abit long .
any gyan ?
chilled_fire is offline   Reply With Quote
Old 24th December 2006, 00:23   #17
yogesh sarkar's Avatar
Thanked: 21 Times
Your mechanic is right, in any case the normal suspension can take abuse much better than then gas ones. Even though ride quality of gas shocks might be a bit better.
My advice, get the original suspensions.
yogesh sarkar is offline   Reply With Quote
Old 24th December 2006, 11:54   #18
Yeah will get the orignals... thanks for the advice yogesh !
Old 25th December 2006, 17:02   #19
well i got the T adjusted...and this coupled with the frony tyre change has got the bike to normal handling!! i am finally content with the handling of the bike!
Wraith is offline   Reply With Quote
Problem with my CBZ's reflectors, Please help !!! praJEEP Motorbikes 13 15th April 2008 12:22
Help Needed..Modifications for CBZ!!! piyushjain80 Motorbikes 1 6th November 2006 20:08
Help on modifying a cbz in hyderabad juzlemmein Motorbikes 1 11th October 2006 23:34
The CBZ vs The Pulsar 180 Wraith Motorbikes 53 7th July 2005 11:41
performance suggestions for CBZ MadMax Motorbikes 6 19th June 2004 09:55
