Old 19th December 2006, 23:47   #1
Default Help with CBZ
I have a 2000 CBZ which has suddendly developed a strange problem...the front end sways/wobbles when the speed goes above 80 kmph...
I havent dropped or banged the bike anywhere....it has just started happening out of the blue...got the bike serviced from FortPoint at Mahim...but the guys there say there is no problem at all....
But i am sure abt wat i am feeling...anyways which is the best HH service centre in mumbai??
Wraith is offline   Reply With Quote
Old 20th December 2006, 00:21   #2
Nikhilb2008's Avatar
Thanked: 6,605 Times
Hey.... you are here also
Anyway, is there a Castrol Bike zone in Mumbai ?? I took my bike (Pulsar) to Castrol Bike Zone and they took it for a test ride and when that chap came back, he said the front forks need to be overhauled. And this was before I had given him my list of problems.
Was pretty impressed compared to the usual Bajaj fellows.
Anyway, he charged 750/- for that but my bike was superb after that. They changed the front fork bearings, oil, etc...etc...
Old 20th December 2006, 00:52   #3
Wraith,
Better get your front tyre checked, I had this problem in my CBZ then I complained to Hero Honda They Replaced My Tyre Which Had done some 1200Kms for Rs.50, After That I Didn't have any wobbling.
Thanks,
Mega
mega5918 is offline   Reply With Quote
Old 20th December 2006, 01:13   #4
Thanked: 21 Times
check your rims or forks whether if it is bent.... generally thats the cause for the wobbling.
nosfreak is offline   Reply With Quote
Old 20th December 2006, 01:31   #5
yogesh sarkar's Avatar
Thanked: 21 Times
Get wheel alignment done and the problem will disappear.
yogesh sarkar is offline   Reply With Quote
Old 20th December 2006, 10:30   #6
well i have given the Bike at prakash automotive...the mechanic who took a test ride said there is a slight problem and they will look into it...
keeping my fingers crossed till then...
Old 20th December 2006, 21:38   #7
problem in your chain i think.
coolakku is offline   Reply With Quote
Old 21st December 2006, 22:31   #8
got the front tyre replaced...the problem had kinda disappeared but is back again after riding abt 20-30kms!!
i dont have a clue of wat to do now!
Old 21st December 2006, 23:27   #9
abdriver2000's Avatar
Thanked: 24 Times
Check the bearings of your Tee-joint. Get a friendly neighborhood mechanic to do it. Most service centers screw up minor jobs.
abdriver2000 is offline   Reply With Quote
Old 22nd December 2006, 08:37   #10
Wraith,
Then Get your Front Fork and the bearings on the frond fork checked and last but not the least check the telescope suspension on the front for any misalignments (Height variations).
Thanks,
Mega
Old 22nd December 2006, 09:23   #11
SunnyBoi's Avatar
Thanked: 2,832 Times
^^ yup do that asap.
BTW try leaving the handlebar at say, 40KMPH and see whether the bike veerns to any side...
Most of the times that phenomenon happens coz of too much oil in the front forks. They become super stiff, instead of absorbing the bumps, they start jumping...try to get 5ml of oil decreased from both forks. remember : 5ml, not 1ml more, not 1ml less.
SunnyBoi is offline   Reply With Quote
Old 22nd December 2006, 10:50   #12
Thanked: 21 Times
did you get the wheel alignment done?
Old 22nd December 2006, 13:35   #13
benbsb29's Avatar
Thanked: 4,276 Times
I guess u wud need to get ur wheels aligned, which should solve the issue.
Old 23rd December 2006, 10:51   #14
chilled_fire's Avatar
Default rear suspension
Hey guys !!
I don not know whether this is the right thread to ask this quetion.
Just want to know what is the life of bikes rear suspension ?
i own a pulsar and its 3 yrears old now.
the rear suspension looks all compressed now as compared to other bikes also when somebody is sitting back the ride seems a bit low on the back end .
If anybody has any information about this please letme know .
chilled_fire is offline   Reply With Quote
Old 23rd December 2006, 16:03   #15
Thanked: 21 Times
chilled_fire it all depends on how much kms you have used your motorcycle and even than how much abuse the suspension has taken. If the travel of suspension has increased and it gets a bit wobbly try to change the suspension setting to harder and see if it helps. Also I got my pulsars suspension changed after three years, it costs Rs. 600-650 for the new rear suspension in Delhi.
Problem with my CBZ's reflectors, Please help !!! praJEEP Motorbikes 13 15th April 2008 12:22
Help Needed..Modifications for CBZ!!! piyushjain80 Motorbikes 1 6th November 2006 20:08
Help on modifying a cbz in hyderabad juzlemmein Motorbikes 1 11th October 2006 23:34
The CBZ vs The Pulsar 180 Wraith Motorbikes 53 7th July 2005 11:41
performance suggestions for CBZ MadMax Motorbikes 6 19th June 2004 09:55
