Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 30th January 2007, 11:41   #1 (permalink)
Default pulsar150 dtsi ug3 problem
hey guys! i have bought a new pulsar 150dtsi ug3. just completed my 100kms running.this is my first ever bike, the last i own is bajaj chetak. i wanna clarify some problem
1. tke kick is very hard. i am not able to kick-start my bike.
2. when i am on 3rd gear and at 35kph the engine sounds like an enfield
i.e. dug... dug... dug... tipe of firing
3. to return from 1st to neutral is a problem.
sujit007 is offline   Reply With Quote
Old 30th January 2007, 13:49   #2 (permalink)
revtech's Avatar
just try kick starting it everyday.it just needs practice and will eventually losen out too...if you notice when your engine is hot it will be easier to kickstart it.it just requires some practice but while kicking remmeber not to accelerate.
thats cause at that speed in that gear you must be accelerating full so theres a slight strain on the engine.try shifting down to second and accelerating quickly you will not notice this. or alternately be at a higher speed and try this in 3rd itself.also dont only look at speed also see your rpm.its its below 3.5 - 4 you may come across this but above that will be perfect.
finding neutral may be a problem for a few people who are not used to the 1 down all up config so that too will just need a little getting used to.just move the bike front and bike while tryin it will slot into neutral easier.
__________________
Revin Beyond Limits !!
revtech is offline   Reply With Quote
Old 30th January 2007, 14:40   #3 (permalink)
Switching from two stroke, direct drive to 4 stroke chain drive requires some change in acceleration technique. Your third gear knocking problem is (as revtech said) due to opening the throttle too much at too low an RPM. The Chetak would have simply stalled, 4 strokers are more forgiving.
Finding neutral in Bajaj's is a little difficult and the problem will stay with you.My Pulsar Classic 180 was a real pain sometimes.
Hey Sujit007, I have fond memories of trying to find neutral on my 150Bajaj scooter with both hands----so, the Bajaj legacy continues.
Vicki_Rau is offline   Reply With Quote
Old 30th January 2007, 15:18   #4 (permalink)
hemi's Avatar
1)use self start
2)If it is knocking,can't help.typical bajaj trademark.
3)If you are new to 1 down/4 up pattern,you need to get used to it.
hemi is offline   Reply With Quote
Old 31st January 2007, 12:00   #5 (permalink)
thank you guys for your tips. maybe i'll have to practice a lot.
Old 31st January 2007, 13:24   #6 (permalink)
benbsb29's Avatar
Am actually missing the new gear pattern. Luved that.
My Classic 150 came with the all-down pattern which is kinda boring.
Just a thought, the new alloys with the Classic looks... Stunning !!
__________________
"You can discover what your enemy fears most by observing the means he uses to frighten you." - Eric Hoffer
benbsb29 is online now   Reply With Quote
Thread Tools
Pulsar150 to Karizma cnureddy.b Motorbikes 2 12th December 2008 14:33
PULSAR150 UG III What tyres?? sumitkalindi Motorbikes 7 8th November 2007 01:45
pulsar150dtsi ug3 problem sujit007 Motorbikes 4 27th March 2007 22:45
Hero Honda CBZ Xtreme or Pulsar 150 UG3 abhi1881 Motorbikes 47 23rd January 2007 17:44
upgraded version version of unicorn or pulsar150 dtsi sujit007 Motorbikes 6 5th January 2007 09:34
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
