Old 26th November 2009, 15:59   #16
Jaggu's Avatar
Thanked: 8,694 Times
Vapor lock due to the tank cap? These used to happen to RX's but usually happens while running and not at cold starts.
Old 26th November 2009, 20:02   #17
Technocrat's Avatar
Thanked: 2,589 Times
Jaggu is right vapor lock happens due to heat & not cold & yes it very much happens on a Karizma. The only way out is to open the tank cap & close it.
Old 9th December 2009, 00:10   #18
andre1774's Avatar
Hi, i got a relatively new karizma with only 500km on the odo, initially i didnt have any problem, but after 2000kms i experienced a jerky ride, cold start and so on. then i started cleaning the carb, air filter, and finally broke the air screw, and replaced with new one , cold start persists, but what i found was, start with choke for few seconds and then it is ok. ride for few meters, it is fine.
andre1774 is offline   Reply With Quote
Old 19th May 2010, 18:07   #19
sportz_kruzer's Avatar
looks like a lean tune to me. try richening the mixture by a turn or two.
sportz_kruzer is offline   Reply With Quote
Ikon Shudders and mis-fires on cold start Kary Technical Stuff 28 16th May 2016 19:00
Cold start vs warm start, is there a difference? Shan2nu Technical Stuff 6 18th May 2010 18:32
How many KMs after cold start the car will feel better sreenivass Technical Stuff 30 13th November 2009 12:14
Switching on Your AC in Cold Start esteem_lover Technical Stuff 172 25th June 2008 12:44
Esteem 2001 White smoke on Cold start Slick Technical Stuff 9 3rd April 2008 02:16
