Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 14th February 2007, 16:05   #1 (permalink)
Infractions: 0/2 (8)
Thumbs up Karizma Cold Start Problem
Hi Guys,
I have recently bought a second hand karizma(August 2005), the bike is in excellent condition and the ride is also smooth.
There is one problem.. the bike does not start that easily if the engine is cold(starting in early morning).. even the choke doesnt help much.. i think there might be some trick to get it to start when the engine is cold .. is it????
Any help would be appreciated..!!
jazzy_2cool is online now   Reply With Quote
Old 14th February 2007, 20:01   #2 (permalink)
hemi's Avatar
Check
1)Spark plug
2)Idle rpm,i guess it must be 1krpm,check your manual.
3)Clogged carb
4)Choke working or not
hemi is offline   Reply With Quote
Old 14th February 2007, 21:17   #3 (permalink)
Thanks man.. will check all these things.
Old 14th February 2007, 22:00   #4 (permalink)
Infractions: 0/1 (4)
probably your choke may not be working..but have u notice any bad throttle response? clean ur carb and check up with the spark plug. and just a advice even though you start your bike in the morin just switch on the choke and dont rev ur bike for few seconds. Even after you start off in the morin riding your bike and if you finding jerking... make sure you keep ur rev's below 4k and if you ind a open road take it to high rev and after that there shouldnt be a problem.
__________________
My Bpm's and Rpm's go the way i want them to ! --- DJ
nosfreak is offline   Reply With Quote
Old 15th February 2007, 14:26   #5 (permalink)
Hi There..
I am sure that the choke is working because if i start the bike with the choke on.. the rpm is much higher than normal.. idle rpm is around 1.1 k
Will get the carb and the spark plug checked..
Many Thanks
Old 15th February 2007, 15:22   #6 (permalink)
suren181's Avatar
Default Iridiums
Check if you can get Iridium spark plugs after you get your carb checked. It would definitely respond much better during cold starts and will definitely change your ride.
suren181 is offline   Reply With Quote
Old 15th February 2007, 17:11   #7 (permalink)
superavi's Avatar
I've had the same problem. The bike starts only with Choke, but the moment you put off the choke, it's off again.
I put on the choke, take the bike out and ride normally. After about a min, I put the choke off, and it's good as new.
Superavi
superavi is offline   Reply With Quote
Old 15th February 2007, 18:41   #8 (permalink)
Jaggu's Avatar
get carb cleaned, air filter ditto, set mixture proper oh yeah check and clean/replace plugs this is a common thing with most 4 stroke bikes, especially when cold
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 15th February 2007, 19:46   #9 (permalink)
The Wolf's Avatar
This seems to be a problem with several Karizma's... Though me and my friend gave our best shot at correcting this problem with one of the best bike tuners in blore the problem still persists. Setting proper plug gap is the best we could arrive at to reduce the lag time during cold starts, thats it, nothing else has really helped at all!!!
We are still working on it relentlessly, will keep this thread alive till we find a solution.
__________________
I cried coz I had no turbo, till I met a man who had no VTEC!!!
The Wolf is offline   Reply With Quote
Old 15th February 2007, 19:54   #10 (permalink)
Jaggu's Avatar
forgot to mention, float level of carbs, if the float pins are worn replace them with OE
__________________
Old 16th February 2007, 00:52   #11 (permalink)
you mean to say the sprak plug gap...? "we could arrive at to reduce the lag time during cold starts," and how does it work at cold starts?
__________________
Old 16th February 2007, 01:00   #12 (permalink)
The Wolf's Avatar
I dont quite know how to explain scientifically but reducing the spark plug gap slightly lesser than company specification will arguably show a mild difference. May be coz of a stronger and shorter discharge!!!
__________________
Old 16th February 2007, 01:57   #13 (permalink)
But i have noticed that the bike doesnt respond to full throttle when u lessin down the gap of the spark plug. In others words the bike does it cut off @ a certain rpm and just to confirm this is the stock spark plugs from the company itself.....
__________________
Old 16th February 2007, 15:05   #14 (permalink)
Thanks guys... will get these things checked tomorrow(saturday) hopefully it should take care of it..!!!
Many Thanks Again.
Jazzy
Thread Tools
Ikon Shudders and mis-fires on cold start Kary Technical Stuff 24 4th October 2008 12:41
Switching on Your AC in Cold Start esteem_lover Technical Stuff 172 25th June 2008 12:44
Esteem 2001 White smoke on Cold start Slick Technical Stuff 9 3rd April 2008 02:16
Scorpio morning-start problem at high altitudes anupmathur Technical Stuff 2 7th September 2007 07:26
How many KMs after cold start the car will feel better sreenivass Technical Stuff 16 6th July 2007 01:16
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462
