| Motorbikes Everything related to the two-wheeled breed. |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian Join Date: Mar 2006 Location: New Delhi
| Hi, can somebody suggest me some performance mods for my Bullet machismo 1999 model?? like filters, exhausts etc. Basically, I dont want to compromise on FE, rather expect it to be better.
__________________ SINGH IS KINNNNNNNG.. |
| | #3 (permalink) | |
| Senior - BHPian | Quote:
99model Machismo.. is it a AVL or a CI? Dude, get a better pod filter like a K&N/UNI/HP, the original filter is pretty restrictive. Then if it has the looong muffler replace it with a short one, the ones old bullets came with, or even better go for a goldstar silencer. But never ever fit a rocket silencer. If there's a cat con in the header pipe remove it. Upjet the carburator. If you want FE as well do all of the above plus what JK said LOL Plus put CT100 crank,piston,bore in the bullet... | |
| | #4 (permalink) | |
| Quote:
my machismo has the same engine as Std 350, no changes except the chrome. As for silencer, replacing one with std one was the first thing that i did....thump u see!! Now what is upjet the caburretor?
__________________ SINGH IS KINNNNNNNG.. | |
| | #5 (permalink) |
| Senior - BHPian | A K&N (model RC1060) would cost around 1500, a UNI would be a bit cheaper than that and the HP is the cheapest at 700. All three are imported, the HP doesn't have the cotton sandwich like the K&N but the filter size is almost same as the RC1060. The filtration of the HP would be bad (in turn wear out the engine faster) coz it doesn't have the cotton sandwich. Fitting a filter shouldn't hamper the fuel efficiency, but you should upjet (meaning-putting a larger mainjet) and that could lower the fuel efficiency but only marginally. But FE depends a lot on the riding. Your Machismo (if it has the Mikarb carburator) should be having 90 size mains, after the filter you should go for 95/97. You/your mech should decide on how bigger mains to use, the plug color should be light to medium brown after some good full throttle ride. It shouldn't be white (which indicates lean mixture) or black (rich mixture). |
| | #6 (permalink) |
| BHPian Join Date: Jan 2007 Location: Pune
| You can try giving it the 'boric' treatment. Put some boric powder (can get it from any grocery/hardware shop) in the engine oil. Make it 2-5% by weight (5gms, or 1 tsp per 100 ml of engine oil). It isn't a direct performance enhancer, but it'll definitely reduce the friction and improve the FE and smoothness. If you are afraid, try 2% first, and you can always undo it by changing the engine oil. For more info, search this website with "boric powder oil" keyword. Still want more? Try mixing some acetone in petrol/diesel. |
| | #7 (permalink) |
| BHPian Join Date: Mar 2007 Location: thiruvananthapuram
| Once upon a time i used t be die hard fan of bullet. Then my friend told me that his friend got a carb from japan which increased the power as well as mileage( 48kms). He was also telling about new spark plugs. |
| | #8 (permalink) | |
increased power and mileage? emm and thers no once upon a time bullet fan either you are still or your never was
__________________ "She may not look like much, but she's got it where it counts, kid." | |
| | #10 (permalink) |
| BHPian Join Date: Jul 2006 Location: New Delhi
| Dude, ignore my ignorance but I thin the AVL got introduced in later half of 2000- beginning of 2001. I bought my A350 in March 2001 and it was one of the first ones being solf by a BIG dealer in Delhi.I may be wrong though. Thoughts? Also, I am sure you are aware that the AVL engine is noisier vis-avis a normal one. Its been 6 yrs and 15,000 kms. Suggesitons to improve the sound. I have the short silencer (stock) - I think the long one came with the regular Machismo (non AVL) at that time and later got stretched further on the new model. Will really appreciate any inputs/suggestions! |
| | #12 (permalink) | |
| BHPian Join Date: Apr 2007 Location: pune
| Quote:
Unless the carb radically improves the burning efficieny and does some magic on the transmission losses, you cannot get more power and more fuel efficiency simulataneously. | |
| | #14 (permalink) |
| BHPian | first of all, free flow exhaust (simple remove rear part of exhaust). 2nd enrich fuel/air mixture otherwise chances are that you might end up with cease engine or blown gasket (my brother did that). no matter what you do FE will go down. otherwise changes won't be noticeable.
__________________ "Holla ain't no stoppin' me Copywritten so, don't copy me" |
| Thread Tools | |
Similar Threads | ||||
| mods and performance mods for unicorn please give your views | rider60 | Motorbikes | 116 | 5th September 2008 21:23 |
| Performance mods for bullet !!! | ac 427 | Motorbikes | 9 | 22nd September 2007 15:02 |
| some bullet mods plz. | panky12345 | Motorbikes | 6 | 5th June 2006 09:41 |
| performance mods | chandan | Modifications & Accessories | 10 | 17th December 2005 14:48 |
| Mods for a Bullet.. | shravan316 | Motorbikes | 27 | 28th October 2004 15:25 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
