Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 25th March 2007, 23:16   #1 (permalink)
Rajeev29's Avatar
Default Strange Sound from Yamaha RXZ Gearbox - Need Help!
Guys this is rajeev. Remember??? i need your help regarding my yamaha rxz. i am marking a strange CRRRRRRRRRRRR sound from the gear box of my yamaha rxz.pls tell me what is the sound and how to get rid of it. i am very tense. mail4ajo can you help me plzzz. what i have to check to stop the sound?
Thank You All In Advance
Rajeev29 is offline   Reply With Quote
Old 26th March 2007, 02:36   #2 (permalink)
yogesh sarkar's Avatar
Are you sure its coming from the gear box or the chain sprocket? My suggestion is to put you bike on the stand and let it idle with choke on, then change gears and try to identify where exactly the noise is coming from.
If it is coming from the gear box then over to your mechanic, if its from the chain sprocket check front and rear sprocket for wear and also check if the chain is too loose.
yogesh sarkar is offline   Reply With Quote
Old 26th March 2007, 02:41   #3 (permalink)
hi Rajeev , how did you pin point the source of noise ?? it could be an engine bearing noise too , could you please describe it in more detail ? do you hear it while you rev it in neutral or when you engage the gear?
spookey is offline   Reply With Quote
Old 26th March 2007, 03:08   #4 (permalink)
V-16's Avatar
methinks it could be a chain problem. My friend had a similar sound ( it does sound deceptively similar to a gearbox related noise) coming from his yamaha and it turned out to be a chain related noise. His chain was too loose but it was not as loud as the gear related sound would have been. Hope urs is related to the chain too.
__________________
SINGH IS KING!!!!
V-16 is offline   Reply With Quote
Old 26th March 2007, 23:01   #5 (permalink)
Rajeev29's Avatar
thanx for your reply guys.the sound is from the housing, i think. today i visited the mech of yamaha service station. he suggested me to adjust the 2t flow more flow of 2t. he also suggested not to worry. guys i need your valuable suggestion.
Thread Tools
Need Help for porting Yamaha RXZ ~ H O N D A ~ Motorbikes 42 10th March 2008 16:48
Strange sound from the AC blower amit_mechengg Technical Stuff 8 16th January 2008 18:29
Moded Yamaha RXZ for Sale pdev29 Shifting gears 3 6th June 2006 16:51
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
