Old 2nd April 2007, 19:27   #31
ananthkamath's Avatar
Thanked: 46 Times
Is that a shorter header pipe or am I seeing things?
ananthkamath is offline   Reply With Quote
Old 3rd April 2007, 13:03   #32
Thanked: 3,508 Times
Yes, that's a shorter header. Temporary setup with stock muffler, will change over to a megaphone later.
The test run was satisfactory the torque is visible all over the powerband and pulling it means i can make the gearing taller. Another thing i noticed is that the i'm holding the handle steady but the bike's tail is going like a snake's tail at max velocity. Or more like the *** shakes you see in the hip-hop vidoes. The frame has to be trued, there's a slight bend in the downtube.
Apparently the 180 jet is a bit richer even with the needle at the leanest position so when i hold open the throttle at wot the bike flutters and when i close back the throttle the power picks up.
In the last pic Jk had posted you can see the head leaking after the ride. The acceleration was pretty strong initially, when the head was not leaking, and on the level ground i was leading jk for a while, but then later i lost the power a bit and on the downhill section he overtook me. But after that the power never came back like the first time.
With a foolproof head leak stopping technique, better manifold, better carburation and higher compression things could definitely improve.
Old 7th September 2007, 14:03   #33
Hi Guys
Nice Effort
But Did You change the timing and other CDI related things ??
srikanthgr1 is offline   Reply With Quote
Old 26th May 2008, 10:22   #34
Ahhh so long since the early days. Got a lot more to update regarding the Bull. She's running beautifully now. Done a recent Trivandrum Cochi trip on the Bull and the performance was too good, got a real nice fuel average too.
Old 29th May 2008, 20:39   #35
srijit's Avatar
Hi Sankar, please forgive my naive query, but why isnt there a decompression lever on your bike? Did your mods remove the need for one?
ps: that is one ripping sound your bike has
srijit is offline   Reply With Quote
Old 29th May 2008, 20:43   #36
Srijit, the space usually reserved for the decompressor is now occupied by a second spark plug (bosch super 4). Hence there is no space for a decompressor and thus no decompressor lever either.
Old 30th May 2008, 09:59   #37
srijit's Avatar
So how do you get the engine to turn over? By kicking slowly/softly till the needle is in the green?
Or has that characteristic changed?
Old 30th May 2008, 10:26   #38
The only way to get it turn over is to kick it hard. If the Amp needle is in the centre then it will turn over without any major force on the kickstarter and it will start. If the ammeter needle is in the negative you have to kick it really hard to make it turn over and start.
When I had the valves and the seat redone last year the compression was so high that i could stand on the kicker when the ammeter was in negative. And the only way to decompress and thus start was to put the bike in 1st gear and slightly roll it backwards (sitting on the saddle). The bike would make a loud "phisssh" sound and the ammeter needle would be in the center.
The compression ratio is higher than a stock bull coz of the shaved head and the block. I tried running without a headgasket before on my old block and it was lapped to perfection, and it was partially succesful. But the compression was too high and eventually it self destructed. Now i'm using ultra thin custom copper headgasket, the advantage is that it doesnt leak and i can use layers which will help seal the combustion chamber perfectly and there won't be any compression leak. The only thing the copper gaskets seal is oil from the push rod tube and the outer part of the cylinder. In most std bullets the copper gasket seals the compression to an extent, which is okay with the normal compression but not with high compression.
And now the bike is running a revised cam timing. The effects are slightly lower initial pickup and really good top end. I have also added a megaphone exhaust (similar to the goldie pipe but not a goldie type), the megaphone does make it's presence felt and there sure is a gain. Does 80+ in second gear This is waaay better than before.
Old 30th May 2008, 15:28   #39
Hello!
What kind of Mileage do you get in the city/highway after all these mods?
-Ashwin
spyking is offline   Reply With Quote
Old 30th May 2008, 16:09   #40
Originally Posted by spyking View Post
Hello!
-Ashwin
Thats the fun part!! I get around 26 to 27 if i rip on the highways. And generally inside the city i get around 30-32 as i don't get the chance to open up completely.
The highway figures i have quoted from my recent trip to Cochi.
This is due to the increased efficiency.
Old 30th May 2008, 17:11   #41
srijit's Avatar
He he, thanks for the info Sankar. Maybe next time I can take it for a spin...
Old 23rd April 2009, 17:07   #42
pedrolourenco's Avatar
Thanked: 448 Times
Infractions: 0/1 (4)
I saw a similar modification on one of the Enfield communities on Orkut. The guy had connected the decomp cable somewhere near the tappet cover. A similar arrangement is used in the AVL engine. Maybe you should try it out.
pedrolourenco is offline   Reply With Quote
Old 23rd April 2009, 20:12   #43
jkdas's Avatar
Thanked: 1,389 Times
What was the orkutian's name/id?
Sankar sold his bike and anyway, his bike didnt have a decomp lever.
Old 24th April 2009, 21:37   #44
Thanked: 448 Times
It was quite a while ago. Let me search. Just wondering if I'm allowed to post the link here if I find it.
@jkdas
You can check these threads out
http://www.orkut.co.in/CommMsgs.aspx...4993&kw=Decomp
http://www.orkut.co.in/Album.aspx?ui...aid=1218440560
Someone has done a twinspark conversion with the decomp modification.
Mods please delete the next post.
__________________
Last edited by pedrolourenco : 24th April 2009 at 21:56. Reason: Posted a new post by mistake
Old 24th April 2009, 21:54   #45
Thanked: 448 Times
@jkdas
Royal Enfield Thunderbird with Twin Spark madbullram Motorbikes 125 17th July 2013 12:46
Red Bull Racing Cans: Chance to visit the Red Bull Racing HQ in Milton Keynes varun_patra Indian Motorsport 0 22nd July 2011 15:51
Thunderbird Twin Spark Modifications NikhilSorot Motorbikes 5 7th January 2009 23:02
Totally Psyched Out! Steeroid Modifications & Accessories 61 12th June 2007 21:48
