Old 21st October 2007, 01:10   #31
rider60's Avatar
Thanked: 47 Times
well now i have a unicorn version 2, i fitted karizma alloys on it modding the front disk calipers have the pics and i NOW HAVE THE CORRECT INFO TO GIVE YOU GUYS.
I HAVE THEM IN THE FOLLOWING THREAD
http://www.team-bhp.com/forum/motorb...r-views-5.html
FOR FURTHER QUERIES PM ME!
rider60 is offline   Reply With Quote
Old 21st October 2007, 16:30   #32
sathyaprakash's Avatar
Thanked: 44 Times
I own a unicorn and i changed the rear to a MRF 100/90, now i want the honourable Bhpians to clear my long lasting doubt whether an 110/90 can be fitted without changing the 1. swingarm 2. without removing the chain gaurd, bcz there has been a lot of people saying 100/90 is the max and others saying 110/90 is the max without modifications, which is true pls clear this big DOUBT .
sathyaprakash is offline   Reply With Quote
Old 22nd October 2007, 00:32   #33
rider60's Avatar
Thanked: 47 Times
sathyaprakash you can fit the 100/90 tyre with out modding the swing arm or removing the chain cover. but if you wish to go for the 110/90 tyre then you may need to remove the chain cover but the swing arm modding is is nor necessary. on the V1 & V2 unicorns the max tyre size that can be fitted with out modding the swing arm is 120/80 but if the tyre is not properly aligned then its sides may rub the swingarm slightly!
well i have 120/80-18 mrf zapper Q on my uni but since my bike is version 2 unicorn it rubbed the swingarm during double riding so i changed my swingarm to a version 3 unicorn that costs 750bucks and 150 bucks fixing charges! and now i am fine with even the double riding!
for pics check my gallery!
Old 22nd October 2007, 13:23   #34
chintan15's Avatar
Hey Sam ,
I'v been riding my Unicorn since more than a year, had no problem with the front tyre but i was not too happy with the rear stock MRF (zapper) provided by HONDA (especially in wet conditions) so i replaced it with MRF Nylogrip 3.50 x 18. Some might feel that it has a dated design but i m sure RD & enfield owner will agree that they provide excellent grip.
Your friend can opt for 3.25 x 18 Nylogrip also, which Yamaha used to fit on their RX's.
I am again on my stock zapper as the nylogrip was used to its fullest.. Planning to replace it with 3.25 this time (I think it will be a bit more smooth than 3.50 ) but a bit worried abt the smaller section, wht if it wont corner as well as the 3.50.
chintan15 is offline   Reply With Quote
Old 22nd October 2007, 19:50   #35
Thanked: 44 Times
memebers of this forum pls confirm whether its is 100/90 or 110/90 which is the MAX allowed in the honda UNICORN rear without any mod or removal of chain cover. Pls confirm this bcz there is lot of confusion regarding the MAX one can fit without mod.
Old 22nd October 2007, 22:54   #36
rider60's Avatar
Thanked: 47 Times
for sure its 100/90 that can be fixed without any mods whatsoever! Mr.satyaprakash!
Old 23rd October 2007, 18:53   #37
Thanked: 44 Times
rider60> thks for ur contribution, can an Ist version uni which came WITHOUT the alloys be changed to the uni3 swingarm and add the 110/90 rear tyre without removing the CHAIN COVER? pls clarify thks in advance.
Old 23rd October 2007, 20:35   #38
rider60's Avatar
Thanked: 47 Times
you dont need to change the swingarm for a 110/90 tyre but will have to remove the chain cover just confirmed that today!
if you are going for a tyre above 110/90-18 that is 120/80-18 tyre then you will have to change the swingarm to the v3 uni's like i did on my bike checkout this thread for the photos! and also remove the chain cover its a must!
http://www.team-bhp.com/forum/indian...ture-1175.html.
this is my T-BHP Garage.
Old 12th February 2008, 15:42   #39
moralfibre's Avatar
Thanked: 6,533 Times
Guys I just upgraded the rear tyre on my Unicorn from MRF Zapper 3.00 x 18. I chose the Michelin M45 3.25x18 and it fitted well. I feel the need for a slightly wider rim.
Deal:
The upgrade happened at Darshan Tyres in Kothrud - Pune. Now, Darshan tyres also has a branch on F.C. Road where they quoted Rs. 1800/- for the tyre + the tube would be charged extra (this is their main branch IIRC). I visited their Kothrud outlet just to take a chance on pricing and guess what, I got the same tyre with a new Dunlop tube for Rs. 1550/-. Thats a deal. I wonder why the difference in pricing between two branches of the same company.
Riding Experience:
I went for a short spin to Pirangut ghats which is about 10 kms from my house. The tyre size upgrade is a welcome change. I could easily lean out with much better confidence on the newer and wider rubber holding the bike in hang all along the corner. Loved it for the short spin I had. I am sure I could go further down the lean and faster with this tyre but I need to get used to the change in dynamics. Once I do I'll let you guys know
Enjoy the pics:
Old 12th February 2008, 21:15   #40
Mpower's Avatar
Thanked: 1,687 Times
Did you just change the rear. What are you running up front?
Old 12th February 2008, 21:41   #41
Michelin was available for INR 850 few years ago when it was available officially!! I had it on my Shaolin. Can't believe prices have gone up so much...how much does MRF Zapper cost now?
manish7 is offline   Reply With Quote
Old 12th February 2008, 21:54   #42
moralfibre's Avatar
Just changed the rear. I wanted to do the front as well but most of the fellow bikers whom I took advice from did not approve. It is a 2.75x18 stock MRF Zapper but has a center line tread unlike the rear which had no grip whatsoever in straight line.
Manish, I remember but that was about 3 years ago at least. Property prices have gone up, petrol prices have gone up, tyre prices have gone up as well. The tyre I purchased had a $59 sticker on it. This is imported and is purchased from an official Michelin dealer. I got a bill for the product as well. They have assured a warranty against manufacturing defect.
The rim width is an issue here. I am using a 1.85 wide rim. I think I'll fit the one from the Pulsar 180 which is 2.75 wide. Will it give a wider contact patch? I think a wider rim will lead to fouling of the tyre with the chain cover as there is very low clearance available there. Lets see how it goes.
Old 13th February 2008, 00:14   #43
vabs78's Avatar
Thanked: 11 Times
If you are looking for grip you should change the front also and go for Michelin, there is a lot of difference between MRF and Michelin. Upgrade the front to 3"x18 and you will see considerable difference in handling.
I think I'll fit the one from the Pulsar 180 which is 2.75 wide. Will it give a wider contact patch? I think a wider rim will lead to fouling of the tyre with the chain cover .
You will get a wider contact patch for sure, but thats not the only factor. The tyre should also fit properly on those rims. It should work out, as I have seen a pulsars with M45 (not sure what size, though).
vabs78 is offline   Reply With Quote
Old 13th February 2008, 09:21   #44
Ajaybiz's Avatar
Thanked: 148 Times
Nice choice specially the size and make but bit costly as i bought 4.00x18(close to stock 90/100) for my CBZ for 1600 in Bangalore, but not happy with its broarder size, lost bit of pickup.
Next i am going to try Pirelli Speed Demon for my RD.
Ajaybiz is offline   Reply With Quote
Old 13th February 2008, 12:33   #45
Yeah, but Bike prices haven't gone up!! Just that I am just surprised and wondering if it's the fair price...so asked about contemporary tyre prices!
fixing big tyres on unicorn pictorial explanation samybravo Motorbikes 3 23rd August 2015 14:46
Honda CB Unicorn/Unicorn Dazzler - Technical Specifications & Feature List bluevolt Motorbikes 0 25th September 2011 15:35
RTR/Unicorn or Avenger - which one? Edit: Bought Unicorn - Dealer woes manish7 Motorbikes 34 24th April 2008 11:53
Directional Tyres / Asymmetrical Tyres ? SCH Tyre & Alloy wheel Section 32 14th March 2005 01:34
