Old 14th February 2008, 10:48   #46
vabs78's Avatar
Thanked: 11 Times
Originally Posted by Ajaybiz View Post
Nice choice specially the size and make but bit costly as i bought 4.00x18(close to stock 90/100) for my CBZ for 1600 in Bangalore, but not happy with its broarder size, lost bit of pickup.
Next i am going to try Pirelli Speed Demon for my RD.
Pirelli SD is a good choice if you want grip. But the it is quiet heavy, you need a powerful machine to get best out of it. May work out well on a RD(if its in good condition).
vabs78 is offline   Reply With Quote
Old 14th February 2008, 11:31   #47
dhaval's Avatar
Have got 100/90-18 Dunlop Geo-Cruiser on the rear for my Pulsar, which is due for change now.Have been using it for the past 5 years now, and found to be doing its job quiet well. So planning to go for the same tyre again.
IMO Dunlops will do a good job on the Unicorn aswell.
dhaval is offline   Reply With Quote
Old 14th February 2008, 12:00   #48
TomRider's Avatar
@Ajay..
From were did you get the M45 for 1600/-? Can you please give the address? I asked in Iyengar tyres in Indiranagar. He was asking 2,100/-
TomRider is offline   Reply With Quote
Old 14th February 2008, 13:08   #49
Ajaybiz's Avatar
Thanked: 141 Times
Same shop but parllel to JC road just in front of Garuda Automobiles.
Which size you are looking for.
Better try Pirellie as m not much happy with Michs.
My upcoming bike will be sure wearing Pirellies.
Ajaybiz is offline   Reply With Quote
Old 14th February 2008, 14:11   #50
Technocrat's Avatar
Thanked: 2,589 Times
Congrats the Michelin's have been a favorite of lot of people, thats good price you got the tire+tube combo. You might notice a slight improvement in mileage too, also you will realize the real benefits of this tire during rains
Well I had the Pirelli SD on my ZMA & they were fabulous just that they are on heavier side both price & weight wise
Old 14th February 2008, 14:36   #51
TomRider's Avatar
Thanks!
I am looking a 3.50X18...
Dont want to compromise on performance with the 4.00.
What are the sizes available for Pirelli SD?
Old 19th February 2008, 15:46   #52
motomaverick's Avatar
Thanked: 868 Times
Originally Posted by TomRider View Post
Thanks!
@tom....Pirelli SD will be too big for the apache...its 110/90. Even Michelin m45 4.00 is big. The third point is 3.5 m45 is really not avaialble. U might get 3.25....Try KRP.
Old 5th January 2009, 19:49   #53
Thanked: 73 Times
Sorry to pull up an old thread, but I wanted to know which brand is available for tubeless tyres for a Unicorn. mine is a new unicorn with alloys. I do not want to take the chain cover off, so I guess I am looking for a 100/90-18 tyre dimension, but a tubeless one. I have been searching for sometime now, but I have not found it anywhere.
Thanks for any info.
Prajwal
prajwalkashyap is offline   Reply With Quote
Old 5th January 2009, 20:28   #54
Technocrat's Avatar
Please go through following thread for some options on Tubeless tyres
Tubeless Tyres For Karizma (Tubeless tyres for Karizma)
Old 11th February 2015, 12:44   #55
rr_zen's Avatar
Thanked: 268 Times
Default Re: Tyres for Unicorn
Bumping up a 6 year old thread here. I have a 10 yr old gen 1 Unicorn - kick-start version with non-alloy wheels. The running has been very low and the odo reads 13.7k km till date. I have a couple of queries and seek the Unicorn gurus to throw light on them.
1. The stock rear tyre is 3.00 - 18 MRF Zapper. While I did read that 100/90 - 18 is a direct fit on the bike, wanted to know if it would be the same with non-alloy wheels. I hope no modification is required here.
2. If I were to change the rear tyre, should I be changing the front one as well ? Not sure what the size on the current gen Unicorn is for that. The stock one on my bike is 2.75-18 and is a Zapper
3. Does it make sense to upgrade to OE alloys (apart from the cosmetic one) without any modifications? What are the prices of the Unicorn OE alloys?
4. Of late, I have been noticing that the rear wheel tends to wobble esp. at speeds above 60-70 kmph and that gives me a jittery feeling. What could be causing this ? My guesses are - the tyre (which could have had uneven wear and tear), or the stay bush, or any bend in the wheel.
Thanks in advance.
rr_zen is offline   Reply With Quote
Old 11th February 2015, 13:22   #56
theexperthand's Avatar
Thanked: 1,242 Times
You can put 100/90-18 without any modification on non alloy wheels - been there, done that. But good news is that Michelin is available in both 2.75X18 (front) and 3.00X18 (rear) format, so you can pick that also.
In your case, absolutely. 10 Year is too long.
Other than cosmetic reasons, I do not know if there are any other benefits.
Check the wheel and get it trued if required to remove any bend in the wheel. Also, check the wheel bearing and the rubber bushes.
--Anoop
theexperthand is offline   (1) Thanks Reply With Quote
Old 11th February 2015, 13:27   #57
rr_zen's Avatar
Thanked: 268 Times
My understanding is that 100/90-18 is a wider tyre than 3.00/18. Would prefer the 100/90 for the additional width and better grip.
Old 11th February 2015, 13:40   #58
Yes to both That is why I changed from 3.00X10 to 100/90-18.
Was merely suggesting that Michelin still makes it in both sizes (3.00X18 as well as 100/90X18), so you can have your pick.
My pick still is 100/90-18 for the additional grip.
--Anoop
Old 11th February 2015, 14:24   #59
rr_zen's Avatar
Thanked: 268 Times
--Anoop
Thanks. Any idea how much a 100/90-18 Michelin tyre would cost? Also, I guess it is ok to live with 2.75-18 at the front while making the change to the rear tyre.
Old 11th February 2015, 14:53   #60
Gansan's Avatar
Thanked: 913 Times
@rrzen
For old rims, better opt for tube type tyres.
Change tyre/tube for both wheels at the same time, since both are old.
Changing to alloys from spoke wheels may not be a simple swap. I wanted it done for my Splendor, but my mechanic said the fork may need alterations. So I dropped it. Check out with your mechanic.
Lastly, get both your wheels trued at the time of changing the tyres. That may solve the wobbling.
Gansan is online now   Reply With Quote
fixing big tyres on unicorn pictorial explanation samybravo Motorbikes 3 23rd August 2015 14:46
Honda CB Unicorn/Unicorn Dazzler - Technical Specifications & Feature List bluevolt Motorbikes 0 25th September 2011 15:35
RTR/Unicorn or Avenger - which one? Edit: Bought Unicorn - Dealer woes manish7 Motorbikes 34 24th April 2008 11:53
Directional Tyres / Asymmetrical Tyres ? SCH Tyre & Alloy wheel Section 32 14th March 2005 01:34
