Old 10th April 2007, 17:58   #1
jobinjv's Avatar
Default Headlight Mod for enfield
I want to know if it is possible to dismantle the headlight assembly of the Bullet Electra in order to replace it with something like the Thunderbird headlight where only the head light is fixed and the display unit is a separate fitment.
Hope you all understood and second, will i be able to work the fuel part of the Thunderbird when i fix it on the standard type and is there any other mods too to be done for this.
wishing i get some replies.
jobinjv is offline   Reply With Quote
Old 11th April 2007, 17:40   #2
Sankar's Avatar
Thanked: 4,639 Times
Well you can do it. You got to remove the 'Casquette' (that whole part which holds everything, speedo, ammeter, lights) and replace that with a upper triple tree of the thunderbird. Then you need to get the thunderbird type headlamp housing, headlamp holder, meter assy (if needed).
We understood the first part but dint quite understand the fuel part
If you mean the fuel gauge then you need to modify the tank to fit the fuel level sending unit.
The tbird meter assy is around 2.5k
Old 11th April 2007, 20:36   #3
jobinjv's Avatar
@ sankar..
yeah dude thats pretty much what i meant.. what is the modification to be done in the tank.
and is it easy to remove this ' Casquette '
Old 16th April 2007, 12:01   #4
Sankar's Avatar
Casquette is the part which hold the headlight and the meters. I suggest you visit the friendly neighborhood mechanic.
Old 20th May 2011, 10:37   #5
Default Re: Headlight Mod for enfield
I need recommendations for a more powerful headlight to use than the stock one , without the need for any modifications , standard 12v battery in the bullet.
vikrut is offline   Reply With Quote
Old 20th May 2011, 11:41   #6
The Great's Avatar
Thanked: 643 Times
Have a look at my bikes pics, if thats what u mean.
http://www.team-bhp.com/forum/attach...please-137.jpg
http://www.team-bhp.com/forum/attach...please-152.jpg
The Great is offline   Reply With Quote
Old 20th May 2011, 12:19   #7
alpha1's Avatar
Thanked: 1,035 Times
Don't do it!
Not because it can't be done, but because your old headlight assembly is million tiumes more robust and accident proof.
The T Bird headlight assy is such a delicate darling that one bump and the whole thing is mashed and twisted beyond recognition!
The old bull assembly could face anything.
For stronger headlights - it depends on the dynamo amps or the battery amps.
Even if you put 100W bulb - it wont glow on an Enfield.
alpha1 is offline   (1) Thanks Reply With Quote
Old 20th May 2011, 17:04   #8
Actually you are right in a way , perhaps the RE bulb is underpowered because it cannot handle the load ? I really have trouble seeing in the night though , and I do not like modifications.
Originally Posted by alpha1 View Post
Don't do it!
Old 23rd May 2011, 12:35   #9
Leepower's Avatar
Thanked: 70 Times
Dude, you can upgrade to an HID light. I have done it on my Bull. It will light up the whole road in the night!!!
Leepower is offline   Reply With Quote
Figo Suspension - to mod or not to mod KiloAlpha Modifications & Accessories 18 13th May 2013 19:00
500cc Royal Enfield vs NEW 350cc Enfield scottoe Motorbikes 22 13th October 2009 16:47
Headlight mod: 55/60W in a HH Splendor gopz Motorbikes 20 28th June 2008 15:16
To mod or not to mod, is not the question. aalaap Shifting gears 15 18th November 2004 19:26
