Old 18th April 2007, 20:10   #16
Thanked: 3,650 Times
Originally Posted by lancer_mania View Post
but on longer rides when i max out on the speed the engine gets very hot and at tht speed with the amount of air flowing in im sure that a little more fuel would be better.
You need a slightly bigger mainjet. The Pulsar 180 comes with a 115 main, try putting in a 120 or 125. The avenger comes with 125 mains. The needle has only two clip positions to play with on the BS29 so it's not gonna help much.
Don't go to the showroom and ask for an Avenger mainjet, they'll rip you off. Instead go to the car parts dealer and ask for the Solex 120/125 mainjet. It's of the same type. If u need reference carry your jet with you.
Edit: If everything is fine with your engine the engine shouldn't get hot on long rides. Are you using any kind of those fibreglass engine covers?
Old 18th April 2007, 21:08   #17
pawan's Avatar
my friend wanted to know what can be done on the unicorn carbs thats the keihin carbs he was planning to import the keihin racing carbs an put them on.or any other suggestions.
pawan is offline   Reply With Quote
Old 18th April 2007, 23:05   #18
i think i will suggest that to my friend sankar he has a p180 v2 black & black wanted to modify it for more power well will a freeflow exhaust help with k&n that he is already got? well i will let you know about the model of K&N as soon as possible......
mrstyx is offline   Reply With Quote
Old 19th April 2007, 03:49   #19
Awaiting Email Confirmation
lancer_mania's Avatar
I DONT WANT TO MAKE IT RICH PERMANENTLY.jus want to make it rich for a particular ride thats all
lancer_mania is offline   Reply With Quote
Old 19th April 2007, 06:50   #20
ananthkamath's Avatar
Thanked: 60 Times
then change the main jet as per sankar and change it back after the ride.
ananthkamath is offline   Reply With Quote
Old 19th April 2007, 15:51   #21
Racing/flatslide carbs won't make much difference to a stock engine. And those flatslides will cost you some serious amount of $$ as well.. for less than that you could get some head work done and put in a cbzxtreme cam and that would give you a noticeable difference in performance. Then if you want a bigger carb try the pulsar 180 carb (BS29) and jet it properly.
Advice needed On setting Up a car / bike Workshop! Born 2 Be Wild Shifting gears 63 16th December 2012 09:55
Changing Compression Ratio & Gear Ratio adheesh Technical Stuff 7 3rd October 2007 09:54
Autometer COBALT Air/fuel ratio Meter RAYZ Shifting gears 5 14th August 2007 15:23
shogun's air screw setting Rice_tuner Motorbikes 4 18th September 2005 13:07
Vtec's compression ratio!!! Shan2nu Technical Stuff 8 7th May 2005 23:07
