Old 23rd May 2007, 20:51   #1
Thanked: 100 Times
Default New Unicorn problems
Hi All,
Recently I bought "all new" Unicorn. It has done ~ 800 kms (first servicing done).
I'm having problems with clutch judder in first gear (when taking off from standstill).
Also once I cross ~ 4000 rpm mark, the engine loses its smoothness and I can sense the vibrations and the noise is also quite audible.
I had stated the first problem to the servicing person & he did some tweaking. But after running the bike for 100 kms, the clutch judder seems to have come back.
What could be the problem here??
Thanks,
rb2399
rb2399 is offline   Reply With Quote
Old 23rd May 2007, 21:25   #2
moralfibre's Avatar
Thanked: 6,532 Times
RB what exactly do you mean by clutch judder? Also my old version Unicorn makes a sound at 4k ++ rpm. Any bike will.
Old 23rd May 2007, 21:26   #3
sathyaprakash's Avatar
Thanked: 44 Times
i own a unicorn for more than two years and i have not experienced any thing like this may be manufacturing defect pls check with the right mechanic
sathyaprakash is offline   Reply With Quote
Old 23rd May 2007, 21:38   #4
Thanked: 100 Times
The bike does not accelerate smoothly in 1st gear (only) & that too at places like signals where you stop and start again....It's a jerky motion.
The 4000 rpm I'm talking about here is in all the gears;be it 1st or 5th.
Thanks,
rb2399
Old 24th May 2007, 14:31   #5
Thanked: 21 Times
the clutch may be too tight which may be the cause.
nosfreak is offline   Reply With Quote
Old 26th May 2007, 06:18   #6
mithun's Avatar
Thanked: 59 Times
Try to re-adjust the clutch and also make sure that the cable is not stuck anywhere.
Old 26th May 2007, 15:23   #7
Zappo's Avatar
Thanked: 2,080 Times
At 800 kms your bike would not have completed its run-in period as yet. I would suggest you do not force it at such high rpm levels. Till the engine properly beds it tends to feel a bit harsh at high rpm. Thats natural.
Also, what is clutch judder with respect to a bike?
Zappo is offline   Reply With Quote
Old 4th August 2007, 04:07   #8
rider60's Avatar
Thanked: 47 Times
1.check the clutch cable if the cable inside is properly lubricated.
2.check if the choke cable is in proper condition i.e. if its jammed or harder.
i had the same problem of jerking and found out that my choke cable was jammed due to rain. it happened this reason and my bike is new too i bought this april. but i chose the non mag version!
the problem can also be from the improper setting of the crab, before the runin period no bike gives the optimal mileage for the crab is set to pour in more fuel to ensure correct completion of bike's runin as this ensures there is enough fuel in the engine to lubricate it.
if the crab is not been tuned by a experienced mechanic after the first service the above mentioned problems are inevitable!
rider60 is offline   Reply With Quote
Virus problems/spyware problems! post here! SirAlec Gadgets, Computers & Software 10 16th July 2014 00:05
Honda CB Unicorn/Unicorn Dazzler - Technical Specifications & Feature List bluevolt Motorbikes 0 25th September 2011 15:35
Mahindra Scorpio CRDE 2007 - Problems 'n' Problems chandrda Technical Stuff 3 13th November 2009 09:59
RTR/Unicorn or Avenger - which one? Edit: Bought Unicorn - Dealer woes manish7 Motorbikes 34 24th April 2008 11:53
