Old 4th June 2007, 11:55   #1
Default Halogens or xeon lights for karizma.
hello,
can somebody givem e in for on from where shall i install good head lamps (xeon) or anything liek that which can be done well on karizma..... i would like to know the details and how much will it cost. thanks.
maxguru is offline   Reply With Quote
Old 4th June 2007, 12:39   #2
noidaboy's Avatar
Thanked: 260 Times
a xenon kit is available at delhi for 5600 i dunt know if its suitable for a karizma or not as using a higer wattage like 100/90 drains the battery
noidaboy is offline   Reply With Quote
Old 5th June 2007, 10:38   #3
jkdas's Avatar
Thanked: 1,436 Times
search around, theres a post by blueraven about an Extreme with Xenon's
Old 5th June 2007, 11:07   #4
Thanked: 53 Times
noidaboy the price of rs 5600/- you mentioned is for xenon lights ??????? is a single unit or for pair. could post some details like wattage ,etc.
dinar is offline   Reply With Quote
Old 5th June 2007, 12:03   #5
tsk1979's Avatar
Thanked: 16,422 Times
A Xenon bulb is around 30-35W, which is easily doable in a bike.
However you may get a pair only in kits. A kit without high/low beam(single setting) costs around 4000rs. If you want H4, a kit is around 8000rs.
I doubt you will get "single" xenon bulb. Morover there is one ballast for 2 bulbs.
I suggest you get the 4000rs kit, and fit both the bulbs, with one being in an auxilary fog light.
Old 5th June 2007, 12:39   #6
noidaboy's Avatar
Thanked: 260 Times
Well, as far as i have found out,one of my friends have recently got it fit in a pulsar 200.it is a "bi" xenon which works on both high and low beam. 35watts and around 12000k.i will personally go and check out all details and post it.
Yes,it is a single unit for bikes only.. i have heard there is a cheaper one available also for 4400 but i don't have details for that,i would let you know asap
LED Lights for 2 Wheelers: An alternative to high power halogens SunnyBoi Ride Safe 34 17th February 2018 11:30
Xeon and Air filter options for a 99 Zen ZenRocks Modifications & Accessories 8 4th September 2007 09:01
which halogens for zen?? mclaren1885 Modifications & Accessories 41 12th November 2005 18:30
what is this ?? a new type of halogens ?? hkanitkar Modifications & Accessories 3 24th October 2005 10:43
