Old 18th June 2007, 11:36   #1
pjbiju's Avatar
Location: Karamattom, Aluva, Kotagiri, Yercaud, Hospet, Indore, Nashik, Pune (now)
Thanked: 465 Times
Default Pulsar 180 service questions - Millenium Auto, Pune
I have the first version of the Pulsar 180 which has now completed 5 years and has clocked 20000 kilometers. I had overhauled the shock absorbers and changed the spark plug at 10k kilometers from the Bajaj company owned show room. The initial glitches of the gear box was resolved under warranty by replacing the clutch assembly under warranty.
Recently I took my bike to Millenium Auto (near DAV School, Aundh, Pune) for a routine service (taking my bike here for the first time). The owner test drove the vehicle and suggested that I need to change the following:
  1. Chain kit (sprockets and chain)
  2. Clucth plates and pressure plates
  3. Rear Brake Pads
  4. Front Disc brake pads
This along with other charges comes to Rs. 2450 approximately. I have been using the bike at speeds of 50 kmph to 80 kmph in the city and close to 100 kmph on the highways (very rare use of the highways). I do not revv the vehicle really hard. Now my questions are:
  1. Do I need to replace the chain kit by 20k kilometers. How do we know it is time to replace that?
  2. Same with cluch plates and pressure plates - how long do they normally last
  3. Replacing the brake pads for both the brakes are ok.
-Biju
pjbiju is offline   Reply With Quote
Old 18th June 2007, 21:30   #2
hemi's Avatar
1)If you are not able to adjust the chain tension/slack,then clear sign of worn out chain or look at the sprocket's teeths which looks sharp and short.Wear n tear depends on usage,maintainence(lubricating the chain helps it to last longer)and riding habits.
2)Clutch plate,if you are into city riding too much,higher the rate of worn out clutch plates.i have come across clutch plates giving up as early as 5K while some lasted 50+k kms.
hemi is offline   Reply With Quote
Old 19th June 2007, 12:16   #3
superavi's Avatar
Thanked: 13 Times
One sure way of finding out whether your chain is not right is to look for slack when you rotate the rear tyre, if the slack is non standard i.e. goes from slack to tight to slack as you rotate, your chain might have to be replaced.
What hemi says about the sprockets is also right. Sharp short sprockets indicate damage/wear. Do change both sprocket and chain as a package.
superavi is offline   Reply With Quote
Bhimashanker- Trek of the Millenium Sudden123 Travelogues 0 22nd September 2011 15:45
Pulsar 220 (new) or the Apache RTR 180 - EDIT - Bought Pulsar 220 M abhayshanu Motorbikes 203 1st March 2011 14:27
Pulsar 150 Vs Pulsar 180 !!! EDIT: Its the 180 NOTORIOUS Motorbikes 34 24th June 2010 17:49
Vtec vs Karizma vs Pulsar 180 dts-i Shan2nu Street Experiences 75 31st January 2010 12:06
Pulsar 180 UG3and Apache 180-for a new bike? EDIT - Its the RTR 180 deepclutch Motorbikes 76 26th November 2009 00:34
