Old 15th October 2010, 08:33   #16
Thanked: 175 Times
Originally Posted by jingaboysr View Post
Since you have already tried the Amby headlight and night vision bulbs, may I ask how is the lighting and throw? Is it running on stock battery?
The Hella head light cost me just 120 RS so i highly doubt that it is original. with that i am using the Philips Extreme 65/55 and prior to this i was using the HELONIX or something like that 65/55 running on the allternator.
The throw and lighting has improved drasticly. there is a big difference. i would suggest you all go for it. but there is a small problem. when you fit a H4 bulb wich you have to do with this beam you cannot use the H4 connector because that touches the Speedo meter. so instead you have to make the connections by THIMBLES and bend the connectors of the Bulb.
I am very satisfied. my main purpose of moving to the H4 dome was to put an HID which i think i dont need now.
desideep is offline   Reply With Quote
Old 15th October 2010, 19:45   #17
earlier I have used 90/100 halogen on minda headlights but there was no throw in terms of the lightening... I used to find it hard to ride during the night.
but after the said modifications i have a strees free view in low beam itself.
iam using the lumax head light with 55/65 bulb from osram (as philips was not available ).
Had to struggle to get it fixed with the mechanic... but worth the effort in my case
kingcrank is offline   Reply With Quote
Old 15th October 2010, 21:15   #18
Thanked: 175 Times
KIING when did you get this done?
Old 18th October 2010, 10:56   #19
got this done recently
Old 23rd November 2010, 13:37   #20
thegame's Avatar
I have 2004 Thunderbird. Stock battery is 12V 5 Amp. The stock headlight is 35W. My understanding is with this setup, upgrading to 55/60 W bulb is only going to get degraded results.
What are my options to fit a 60W bulb and extract full potential out of it?
thegame is offline   Reply With Quote
Old 23rd November 2010, 15:00   #21
Thanked: 175 Times
Try it with a good bulb and you will not like your Understanding.
Old 5th December 2010, 22:22   #22
ash
Noobish question - So after reading through this and a couple other threads, I thought of upgrading to the Philips H4 for my LB500 at Reliance Autozone (it's closer). However, the chap there said that because of the higher wattage than stock (40/45), the cutouts need to be changed too. I didn't read about a cutout change in any thread. Am I missing something or is it *that* obvious?
ash is offline   Reply With Quote
Old 5th December 2010, 23:35   #23
Thanked: 175 Times
You are just not missing at all let me tell you what i did once again.
My Bulb works off the alternator. (it goes dim when i am not accelerating)
Step 1:
I bought a HELLA (Duplicate) Dome for Ambasador
Step 2
I had a Phillips bulb that i took out of my Tool Kit.
Step 3
I fitted the DOme in the crome ring thing of the head lite.
Step 4.
I did not use the H4 Holder for the bulb as it would not fit with the Speedo meter.
Step 5.
I fitted the three wires care fully.
Step 6.
I was wrong and i did it again and now i was rite.
Step 7.
i Went out at night and i was Surprised.
Amber
Old 5th December 2010, 23:46   #24
jkdas's Avatar
Thanked: 1,436 Times
Its Halonix unless you got a fake.I had used it on my Sunny. Did their job well.
Step 1:
Step 2
Step 3
Step 4.
Step 5.
Step 6.
Step 7.
Amber
Poem?
Old 6th December 2010, 07:24   #25
Thanked: 175 Times
Poem?
hehehe JK. some times you have to make a flow chart to make some simple things more simpler. but guess what i did not have program to make a flowchart
Old 6th December 2010, 12:40   #26
ash
Smile
Amber
I did get what you'd done, no doubts on that. My only question was if any cutout job was required (in general, not specific to OT).
Thanks!
Old 6th December 2010, 12:56   #27
Thanked: 175 Times
Thanks!
i am sure i did not mention any cutouts hehehe.
i dont know its been working fine for me. if any one wants to get perfection then yes you may try all you can. but from the alternator i did not need the RELAY. but ys if you want to go the battery path then do use the relay.
Old 6th December 2010, 15:01   #28
Spitfire's Avatar
Thanked: 707 Times
Why would someone want a headlight that blips depending upon the throttle? Why not have a constant spread. Bulbs will fuse easier in this setup. And when you go WOT see your fuses burning themselves at the altar of common electrical sense.
@ash: Use a relay. The circuits are simple to understand and implement. Think of a relay as a separate switch that keeps the primary electrical circuit happy. If you need more understanding open a new thread. Why relays in electrical circuits. This thread is specific to bullets.
Spitfire is offline   Reply With Quote
Old 7th December 2010, 09:13   #29
Thanked: 175 Times
Spitfire. you could be rite but it has not happened yet to me.
Old 7th December 2010, 09:27   #30
ash
thanks, I'll try and figure that out! looks like I have to do some digging around, I thought I could just plonk in a higher wattage bulb and move on with life
Auto Lighting thread : Post all queries about automobile lighting here Chevy Modifications & Accessories 11102 14th July 2018 08:29
All Bullet Gurus:: Need your Suggestion : Planning to Modify Bullet-Project Wanderer Shubhendra Motorbikes 56 6th October 2014 11:18
Upgrade Lighting on the Pulsar 220 jukebox101 Motorbikes 5 26th January 2013 21:25
NANO effect and EURO effect in Small Car market allwheeldrive The Indian Car Scene 8 15th June 2009 22:29
Lighting Upgrade Help Needed NikN Technical Stuff 8 18th February 2008 13:03
