Old 15th August 2007, 11:24   #16
desigNation's Avatar
Thanked: 46 Times
sabretoothe-thats a beautiful restoration done without going overboarding in modjob, congrats.
desigNation is offline   Reply With Quote
Old 15th August 2007, 12:32   #17
sabret00the's Avatar
Thanked: 45 Times
Thanks a lot...the idea was to keep the bike as much stock as possible and at the same time adding correct after market accessories..
sabret00the is offline   Reply With Quote
Old 15th August 2007, 14:08   #18
devarshi84's Avatar
Thanked: 119 Times
now that's a helluva job. Congrats! When's phase2 starting?
devarshi84 is offline   Reply With Quote
Old 16th August 2007, 00:42   #19
Thanked: 45 Times
thanks again...actually phase to requires a lot of brainstroming,mix and match and trial and error methods...hence we are currently trying to attach the Pulsar 200 wheels to the existing suspension...and then figure out a way to fit the Pulsar220 tyres...
There was a little glitch with the engine...the bike had stalled suddenly...everything was fine...only that it wont start...we invited Kinetic's Service Engineer Mr.Chandra Shekhar to Anil's workshop where both Anil and Mr.Shekhar after 2 hours of problem hunting figured out that the magneto key was broken...now Mr.Shekhar has assured us that he will arrange the tiny part...also he will try to arrange an original gear shifter kit of the Gf125...currently I'm using the one from Karizma(again mix and match)...
Old 16th August 2007, 15:08   #20
doomsday's Avatar
Post
Originally Posted by sabret00the View Post
Thanks a lot..straight line stability is perfect..cornering will take a little practice though..
You might want to lower the rear ride height a bit. Although it looks cool, it will help little with cornering; since the entire bike's weight is pushed to the front end and the rear goes light when you tip the bike into a corner. Hence, you may find the rear slipping and sliding all over the place while leaned over. What setting are you using on the Unicorn monoshock?? I reckon medium is the best mix for city and spirited riding.
doomsday is offline   Reply With Quote
Old 16th August 2007, 16:00   #21
Thanked: 45 Times
very good point...actually the pics I've posted have been taken immediately after we assembled the bike...we've been experimenting with the shocker settings and ride height...currently it's set to soft and hence that explains the increased height...I'am planning to make the suspension a little stiffer probably set it to medium and decrease the height of the rear overhang...that will certainly enhance cornering...
Old 18th November 2007, 22:50   #22
Thanked: 45 Times
Final Picture: My re-styled Kinetic GF 170 Laser sporting custom paint job, 3 stage clip on handlebars, rear mono shock absorber, lighter flywheel, half-cut chain cover, shortened rear mud-guard, redsigned rear suspension system and lastly custom fabricated "rearset" front footpegs with GF125 shifter kit and brake lever....
[Bandwidth Warning : Large Image]
Old 19th November 2007, 11:02   #23
praJEEP's Avatar
Wow, a nice job dude, any headlight upgrades done, or else you are on the stock 35/35w. if you a get a pair of 60/55w with getting the coil rewinded, your bike would be a complete man.
EDIT: osram bulbs would be good.
Last edited by praJEEP : 19th November 2007 at 11:08. Reason: just added info about the bulbs
praJEEP is offline   Reply With Quote
Old 19th November 2007, 11:06   #24
praJEEP's Avatar
nice job dude, any headlight mods carried out, a pair of 60/55w bulb with getting your bike's coil rewinded would be great, your bike will become a complete man though..
Old 19th November 2007, 11:44   #25
Thanked: 45 Times
^^ thanks man..but dont you think a pair 60/55w would actually burn the reflectors since each headlamp is really small in size..
Old 19th November 2007, 11:56   #26
praJEEP's Avatar
Try out, i think you have to replace the stock regulator with a new one which supports the 60/55w bulb. i am running my cbz ex on 60/55w osram. just contact a good auto electrical guyz, they might help you out.
Old 19th November 2007, 14:04   #27
Thanked: 45 Times
looks like its worth a shot...let me consult my mechanic..
Old 19th November 2007, 22:24   #28
rider60's Avatar
Thanked: 47 Times
the pictures look really good after the restoration, i would say why not add mag wheels and a longer swing-arm too, it will make the bike look really awesome then!
rider60 is offline   Reply With Quote
Old 19th November 2007, 23:53   #29
Thanked: 45 Times
^^^ thanks a lot dude...I'm planning to upgrade to the P200 alloys and tires but I guess I would like to change the stock swingy although I know that's not that longer..
Old 21st November 2007, 16:03   #30
Thanked: 46 Times
sabretoothe-like reider60 suggested,mag wheels would really spruce up the looks of the current work.please consider doing it.
Radar / Laser Detectors tsk1979 Gadgets, Computers & Software 49 23rd March 2018 08:48
Laser Eye Surgery - LASIK discussion Sam Kapasi Shifting gears 326 27th January 2017 17:38
Samsung ML1640 laser printer hack. SirAlec Gadgets, Computers & Software 2 2nd January 2010 19:18
Caution: Do not take photos/videos during a laser show. Vid6639 Gadgets, Computers & Software 15 7th September 2009 17:20
