Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 12th August 2007, 12:22   #1 (permalink)
Unhappy Mods/replacement for Apache-150
Hi All,
I own a TVS apache 150 which is 5 months. I wanted to make some mods/replacements and would like fellow bhpians to give their opinion/suggestions for the same.
1) I would like replacement the existing headlamp with a more powerful one. I feel that the current headlamp does not have reach on the high beam though the low-beam is very good. Due to this, I dont feel confident enough to take bikes on long rides. I feel that even my older TVS victor had far far better reach and visibility with the high beam. So what ratings lamps should I replace the current one with? What other modifications are required to get this done? Also will it damage the reflector area?
2) last week somebody broke my sidebox lock. Now just a hole is remaining. Nothing else was stolen as I had not kept the toolbox there as I had got it late from the showroom. Because of this, I will need to replace both the main key unit and the side box key unit. Along with same, I was thinking of replacing the speedometer with the digital one from the RTR. Can this be done?
3) I am tall person(6 ft 1 in). When taking turns the handle bar touches my knee and I have to (most of the times) remove my leg from footrest and create some space to make the full turn. While reading the reviews on RTR, I read that the new handle bars(with adjustible clip-on) liberates good leg space which makes it confortable for long riders. Can I replace my current handle bar with the clip-on version. Will this need any additional changes on the front end?
Also, would appreciate if you can give the costs associated with these mods, if you are aware of the same.
askids
askids is offline   Reply With Quote
Old 12th August 2007, 14:24   #2 (permalink)
madbullram's Avatar
WHat type of bulb is in Apache? H4 or H3?
madbullram is offline   Reply With Quote
Old 12th August 2007, 14:49   #3 (permalink)
I dont have this info off-hand. I will have to look in the manual which I dont have know. I will let you know tomorrow.
askids
Old 13th August 2007, 11:11   #4 (permalink)
I checked the manual. It says Halogen HS1 12V 35/35W.
Old 13th August 2007, 12:49   #5 (permalink)
madbullram's Avatar
Found some info about your bulb type. I think its a variant of H4 and the HS1 pin, middle pin is thicker so we can't fit a H4 bulb. CHeck with your showroom if we can change it to a H4 pin (i think it should be possible).
If possible, then buy Philips +50 Halogen 60W bulb and trust me you will forget any lighting upgrades. I have this in my bull and have stopped using the Fog Lamps
HS1 bulb
HS1 is a new range halogen bulb with a PX 43t fitting. The only difference between the HS1 and an H4 halogen bulb, is that the middle pin at the base is 1-2mm thicker. Hence the notation PX 43t compared to P43t. The HS1 will become the standard bulb for all new 2 wheelers launched.
Lamp Type Voltage Wattage Lumens Base MRP
HS1 12 35/35 825/525 PX43t 79.50
Applications to date:
Bajaj : Boxer CT, Caliber, Caliber Chroma, Eliminator; Bajaj Pulsar 150 (KS),Pulsar 150 (DTS-i), Pulsar 180 (New), Wind 125, Hero Honda CD 100SS Splendor, Splendor Plus, Karizma, Passion, Passion Plus, CBZ, Ambition, CD Dawn Kinetic Velocity; LML Graptor,Freedom 125, Freedom (DLX); TVS Fiero F2
Old 13th August 2007, 18:35   #6 (permalink)
madbullram, wont this affect the reflector because more heat will be produced by the higher rating bulb? Also will it require a winding upgrade or battery upgrade. I think the current battery on apache-150 is rated at 12V 9Ah.
Old 14th August 2007, 09:21   #7 (permalink)
madbullram's Avatar
Nope...60 is perfectly fine for your reflectors. Anything above 60 will affect it and the reflectors we get these days are damn good. for 60W a 5 ah battery is enough...how?
Amps = Watts/Volts
60 watts / 12V = 5 amps
So don't fret
Old 14th August 2007, 12:04   #8 (permalink)
60W will fry his electricals. If i recall, apache is AC lighting, so 60W will overload lighting coils - and the effective output would only be close to a 35W. You either need rewinding, selective removal of bulbs, or an HID, or run the 60W bulb straight off the battery.
Bullet methinks comes with wiring which can support even 80W bulbs easily (remember navendu of BN posting something like that). never heard similar of apache.
Old 14th August 2007, 13:29   #9 (permalink)
madbullram's Avatar
That's a good point but it will not overload and fry...it will just still give 35W lighting. Frying happens when more power is sent through the wires...if its A/C lighting then coil is going to give only 35W so should not be any problem.
I dont think TVS would have fed a wire that can't take 60W but better to check with the dealer as I dont know about it. If the DC wiring from the Battery to healight (once connected) can take 60W i dont see a problem.
Old 14th August 2007, 14:13   #10 (permalink)
When i say fry, I really meant that the bulb will cause a greater voltage drop, and hence impact reliability over the long term. He wouldn't wanna find that out on a dark dusty night
how about 60W bulb + removal of pilot lamps and tacho/rear nr plate lighting? Works just fine for pulsars
Old 14th August 2007, 18:57   #11 (permalink)
Just wondering, are HID conversion kits available for bikes . I know that that they are available for cars.
Thread Tools
2007 Apache 150 @ Rs 40K TrueDreamer Shifting gears 2 28th December 2007 07:08
New Apache ad benbsb29 Motorbikes 2 7th March 2007 13:41
Apache / Pulsar 150/ Unicorn??? BuRnT RuBbEr Motorbikes 18 17th August 2006 10:07
TVS Apache garvit2002 Motorbikes 77 4th August 2006 00:22
TVS Motor launches 150 cc `Apache' kiku007 Motorbikes 81 11th June 2006 11:53
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
