Old 4th July 2004, 18:37   #1
guys i am the owner of a 150 dtsi run around 3000,jan model,i am unable to go above 105 with pillion,but without pillion it is quite wobbly,what do u attribute this to.
corvette is offline   Reply With Quote
Old 7th July 2004, 19:04   #2
hey...
well the bikes needs to run a few kms more... it shud go around 115 kmh... the egine has to open up. well abt the wobble check for any rim bends n the bearings.. the oil level in the front shock...
teen_ninja is offline   Reply With Quote
Old 7th July 2004, 19:14   #3
Tom
Tom's Avatar
i dont think any 150 dtsi will go faster than that with pillion
as for wobbling ninja is correct... rim/wheel bearing/shocks...etc need to be checked
Tom is offline   Reply With Quote
Old 7th July 2004, 19:22   #4
Jaggu's Avatar
Thanked: 8,685 Times
tighten all chasis nuts n bolts also..
Old 26th July 2004, 00:07   #5
Hi!
Decided I'd add my two paise.
Chk whether the rim and spokes are true. Chk the swing arm. and Chk whether both the shocks are adjusted to the same settings. And also chk whether the tyre itself is not worn out etc.
kylohere is offline   Reply With Quote
Old 26th July 2004, 22:41   #6
Shan2nu's Avatar
Thanked: 89 Times
Were you riding against the wind or on a slight slope? These are factors we usually overlook. next time, make sure the conditions are idea.
Regards...
Shan2nu
Old 28th July 2004, 01:51   #7
speedsatya's Avatar
Thanked: 712 Times
regarding wobbling check the spokes on the rims,tighten them.
check the bearings under the handle.it used to happen on my splendor.so ,greasing them and replacing with new ball bearings used to help.
check ur tire air pressures ,and get ur servicings done on time.
but do all ur speed testings after the rains.
drive safe,
satya
speedsatya is offline   Reply With Quote
RE Bullet 4 speed to 5 speed gearbox swap LOGS Motorbikes 17 30th July 2012 10:50
Hi-speed and Low-speed jeeps? MalluDude 4x4 Technical 17 21st May 2012 14:17
How to deduce top speed of a car without breaking speed limit opendro Technical Stuff 47 1st October 2008 02:05
Internet : Connection speed vs download speed!! Shan2nu Shifting gears 16 21st May 2005 03:59
Speed Freaks - Watch your speed!! GTO The Indian Car Scene 18 14th July 2004 03:02
