Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 12th October 2007, 15:51   #1 (permalink)
redrage's Avatar
Default Mid Range & Top speed loss in my Karizma - Please help
Hi Guys,
I Have a 2003 model Karizma which has clocked close to 30 K kms on date. I use the bike for city riding and normally long trips. I have serviced the bike at regular intervals and maintained it pretty well. My first modification for the bike was changing over to K&N airfilter (RC 1060) on which i experimented a lot, firstly removing the stock filter and plugging it in its place, this dint provide me any difference hence i mounted it directly to the Carb, removing the airbox completly. The revs were good but it wasnt really noticable in terms of performance. Then i wanted to upjet the bike learning that there wouldnt be any gains in performance riding the bike with stock jets. I got "convinced" by this certain mechanic who said he had got the right tools for upjetting the bike & wanted to work on my bike.He upsized the stock main jet, in a crude way. After completing work on the bike bike i rode it and it felt a little bit different but eventually i understood that he had made a mess of the main jet and bike was struggling. I added a free flow which i thought would help but that hasent either.
My pain problem now is the bike is slower than a stock Karizma ( I have compared it with my friends stock karizma) when it comes to top speed and midrange, the stock bike just vrooms past (even with me having filter,ffe etc what not). I brought the bike back to stock and again compared with similar results (Midrange, top end is bad). To add to my worries the mileage also is extremely poor (28 - 31 kmpl) compared to 35 - 38 Kmpl on my friends bike.My mechanic suggested i change the cam tensioner.I did. Please enlighten me whether this is the problem i dont have a good top end; beacuse with the old tensioner i feet nearing 7k rpm, i get a cut-cut sound and i felt like something was restricting the bike from revving beyond 7k. I have put back the filter and ffe and trying to work on it with a differnt mechanic. Hopefully i will get to compare it again with a stock karizma tommorow.
Please give me some inputs on which i can work on my bike.
Thank you guys.
__________________
2003 Hero Honda Karizma
2002 Hyundai Accent GTX Tornado
2003 Suzuki Esteem Vxi
redrage is offline   Reply With Quote
Old 12th October 2007, 16:35   #2 (permalink)
Originally Posted by redrage View Post
Hi Guys,
Thank you guys.
One thing redrage. Never try to make a bigger jet by drilling/re shaping your existing jet, it simply never works. Increasing performance is not so simple as rejeting the carb or adding a free flow to a single cylinder engine. it feels with your faulty upsized jet now, the bike simply dumps more fuel into the engine, and leads to higher unburnt fuel at high revs. You can verify this by checking the condition of your spark plug. Rejeting a carb is almost a fine art, and you need to visit an experienced mechanic for this. Also be aware that rejeting the carb, adding free flow, better air filter, might hardly give u a 0.5 bhp increase if at all, so not worth it.
One a karizma, one simple thing possible is to change the gearing by either a size smaller rear sproket or a one tooth higher front sproket, i believe the bike has enough torque to ensure a slightly better top end through this mod
apachelongbow is offline   Reply With Quote
Old 12th October 2007, 16:39   #3 (permalink)
Are you running on stock tires or did you upsize?
solly is offline   Reply With Quote
Old 12th October 2007, 16:44   #4 (permalink)
redrage's Avatar
I am using 120 section tyres from MRF
__________________
Old 12th October 2007, 17:51   #5 (permalink)
crazydiablo's Avatar
I would say bring it back to stock. Stock jets, stock filter and stock silencer. Probably take it to a authorized SS or a good mech and get it back to stock. While you mech played with your carbs maybe something has gone wrong.
Other than that,
1. change only one thing at a time
2. FFE is pretty much useless
3. Filter should be done with proper upjetting. Jet should not be crudely drilled.
crazydiablo is offline   Reply With Quote
Old 12th October 2007, 18:16   #6 (permalink)
praJEEP's Avatar
[quote=crazydiablo;593417]I would say bring it back to stock. Stock jets, stock filter and stock silencer. Probably take it to a authorized SS or a good mech and get it back to stock. While you mech played with your carbs maybe something has gone wrong.
i second your words dude,
@red bring the bike back to stock
i have pm'ed you.
__________________
A wise man should have money in his head,
but not in his heart.
jonathan swift
praJEEP is offline   Reply With Quote
Old 12th October 2007, 18:37   #7 (permalink)
redrage's Avatar
Any place you reccomend does this job properly? I have tried and i havent come across 1 mechanic who has confidently said he will upjet a karizma.
Even after i tried on the stock jets, stock filter, stock silencer, I found it slower than another karizma( stock) . This is my main worry, so i started this thread. I am lamenting that even after i tried getting the bike back to stock it dint give me any results, so i thought heck with it and bolted everything back.
__________________
Old 12th October 2007, 19:08   #8 (permalink)
extreme_torque's Avatar
Did you switch riders while comparing performance?
__________________
My Clicks:
extreme_torque is offline   Reply With Quote
Old 12th October 2007, 19:13   #9 (permalink)
redrage's Avatar
Yes, We tried that as well. My bike seems to be losing out after higher 2nd , 3rd & 4th gears in midrange , bike is not able to cross 122 - 123 kmph on the speedo where the stock bike clocks about 140kmph (125 true speed).
__________________
Old 12th October 2007, 19:15   #10 (permalink)
Team-BHP Moderator
Technocrat's Avatar
Most of the points have been covered by people. But one note I would like to make is that 28-31kpl is nota bad mileag for ZMA all those who claim higher are either lying or ride very sedately. The max in sedate riding that you can get is 35kpl
__________________
180, 225, 150, ??? -> 159?
Old 12th October 2007, 19:18   #11 (permalink)
redrage's Avatar
Techno you had a karizma right? Do you think the camtensioner has anything to do with the bike not able to rev freely?
About the mileage part when i rode with my friend on his 10 k logged karizma, he got a comfortable 38 - 40 on the highway where i could manage only 32
__________________
Old 14th October 2007, 01:11   #12 (permalink)
doomsday's Avatar
Post
The only issue you will face because of a faulty tensioner is rough low speed operation. The idling will not be stable as well. Also did you change your cam chain while changing the tensioner or just the tensioner? Ensure that you change the cam chain also since a used chain with a new tensioner will wear out the tensioner much sooner. (something like chain sprockets)
Make sure that the main AND the pilot jets are back to stock sizes. Get the carb disassembled and cleaned and check the carb slide for damages. Once you set up the carb and tune it, ride the bike for some kilometers and check the spark plug. The tip should be brownish in colour. If this is the case, it means your carburetion is perfect.
Moving on then, get your clutch plates inspected as well. Replace if they are worn out (which might be in case you are running on the first set). Also check the sprockets and replace if they have worn out (which might be in case you are running on the first set)
Lastly check your front disc assembly and ensure that the plate is in shape and the pads are not grinding against the plate even though there is no pressure on the lever. (I know it sounds overboard but this happened in my case). Change the disc place if its bent; dont be convinced by someone who says he can re-surface it.
Hope this helps.
doomsday is online now   Reply With Quote
Thread Tools
Car loosing speed too quickly uphill... and power loss amu1983 Technical Stuff 10 27th June 2007 19:09
Low Mid Range with Pioneer HU maverick Product Discussions 2 2nd January 2007 14:07
Headphones & Hearing Loss navin Ask the Gurus 5 12th September 2006 11:16
Top Speed drifter The Indian Car Scene!! 37 13th February 2005 00:18
getz top speed .anshuman The Indian Car Scene!! 18 26th January 2005 23:44
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
