Closed Thread
Old 19th April 2013, 10:59   #2461
ghodlur's Avatar
Thanked: 2,438 Times
Red face Re: The Gearless Scooter Thread
The 2 wheeler manufacturers have quitely hiked the prices of the vehicles to offset the increased freight charges. The increased charges are with effect April 1, 2013. Honda has hiked the cost of 2 wheelers in the range of Rs 200-800, Bajaj in the range of Rs 300-500 and TVS in the range of 0.25 to 0.5% of the vehicles cost.
http://post.jagran.com/twowheelers-g...-as-1366259613
ghodlur is offline
Old 19th April 2013, 11:24   #2462
Thanked: 7 Times
Default Re: Wego travails
Ditto here Vikram,
This is my story.
26 months of ownership and 15000 kms with my TVS Wego.
Problems faced:
1. Transmission Oil Leakage - Happened 2 times in the first year. Not anymore.
2. Kick lever assembly - This happened two months back. Kick lever goes up & down without start. I haven't replaced the battery yet, complicates the problem. But, now it is fine.
3. Battery is pathetic in Wego (2011) models. My battery is almost dead.
4. Speedometer cable and headlight switch - Speedometer cable replaced under warranty, headlight switch replaced after the warranty.
5. Break wire replaced - Sometimes, I feel that the break is not as responsive as it was originally. Anyways, Wego travels best at 55-60kmph, no point in going beyond that speed.
6. Wego hates water bath - For all the wego owners, wego hates water for sure. Whenever I have given it for water wash, it takes atleast 15 mins of kick start for it to start. No water bath for Wego .
Did anyone else face similar problems with Wego.
Positives:
1. Still get a comfortable 40-45kmpl.
2. Only once I had a flat tyre. This is inspite of travelling on some of the worst roads.
3. Ride quality is very good. Doesn't put lot of strains on the body.
4. I had a head-on collision with a great soul who thought that they allow you drive the american way in IT highway. Vehicle bore full impact w/o much damage. The body of Wego is really good.
As my battery is of no great use, I use only kick-start in the mornings, it usually starts with the first kick. But, did have starting problems a couple of times, Never used choke/start switch for starting (excluding waterwash incidents). My vehicle is serviced at regular intervals. (Century TVS in Pune/ Ramkay TVS in Chennai now).
Are there anyone with later Wego models other than 2011. Mine is brought in Jan 2011. May be they can add their cup of woes/ positives here. In later Wego models, it seems they increased the capacity of the battery and made some changes with the headlight/wire assembly.
I am satisfied with my Wego though. At that time, the choices weren't great either.
Last edited by GTO : 20th April 2013 at 15:52. Reason: Please quote ONLY the relevant bits of a post. Quoting a full, long post inconveniences our mobile readers.
ks14 is offline   (2) Thanks
Old 19th April 2013, 12:58   #2463
comfortablynumb's Avatar
Thanked: 1,029 Times
Originally Posted by ks14 View Post
Ditto here Vikram. This is my story.
Agree with you on the positives part. Decent mileage, comfy seating position [at least for a person of medium height] and good ride quality [even with pillion] are the USPs of the Wego. I'm trying to find out if I can buy the extended warranty at this point in my ownership. If yes, then I will keep the vehicle for another 2-3 years, else bye-bye to it. I cannot afford to pay for oil seals and broken kick start repairs out of pocket.
Cheers,
Vikram
comfortablynumb is offline
Old 19th April 2013, 13:09   #2464
Thanked: 7 Times
Agreed Vikram. We were used as the guinea pigs unfortunately. In my opinion, it is best to get away with the defective vehicle asap. Does an extended waranty help here. Don't wait for the vehicle to break-down in your 40km daily travel.
Cheers,
Vikram
ks14 is offline
Old 19th April 2013, 15:11   #2465
Thanked: 1,059 Times
When i was buying the Wego in 2012, I was told that I have to decide on the extended warranty within 90 days of purchasing the vehicle. But anyways no harm in trying to procure it from your dealer if available as an option.
abhinav.s is offline   (1) Thanks
Old 19th April 2013, 19:55   #2466
Thanked: 306 Times
Has anyone bought Honda shooters with their new HET engine? Does it really give mileage of 60 kms/ltr, or how much petrol does really consume in city traffic?
zulfi hansi is offline
Old 19th April 2013, 22:02   #2467
AlphaLamb's Avatar
Thanked: 33 Times
Can agree on the fact that Battery is a real problem area with the Wego.
Having bought a Wego 2 years ago (April 2012 and 7800 Kms to date), have had a few occasions (5 to be precise) where the Wego would stall while at idling speeds and after that no matter what was done, the vehicle would not start.
4 of the 5 times the vehicle had to taken to a local garage, where it would start after they tinkered around with it. Nothing specific and no amount of diagnosis could point to what went wrong. In the meantime besides this issue, there were no other issues with the unit.
On the 5th instance, it started off after being just left alone overnight.
After the 5th instance, things pointed to some issue with the battery and once i insisted on this, the TVS service center swapped out the Maintenance free Battery (Make: Amaron) (this one came as standard fitment) with a regular battery (Make : Exide).
After the battery was replaced, which was roughly 7 months ago, i have not had any further issues with the abrupt stoppage.
As far usage of the vehicle goes, i always start off with the kick start to bring it from the dead and then use the self starter (and consequently the battery) for all subsequent starts.
Have just have had one other instance where the speedo/odo cable had to changed.
Overall the vehicle as per my observations has been a good ride with a consistent mileage of 45+ (40 plus - city and 50 plus - highway).
Ditto here Vikram,
This is my story.
AlphaLamb is offline
Old 20th April 2013, 11:33   #2468
longhorn's Avatar
Thanked: 337 Times
Default Re: The Gearless Scooter Thread
You can realistically expect around 45kmpl +- 5 in city conditions. My Dio (pre HET)gives an average of 45 kmpl in the city. HET would add around 2 kmpl to this max. Don't expect anything above 50 kmpl with HET.
longhorn is offline   (1) Thanks
Old 2nd May 2013, 10:25   #2469
amtak's Avatar
Thanked: 382 Times
What is the mileage of Vespa LX125? Is there any service centre in an around Mira Bhayander? I am asking this as the indicative price lists Mira Bhayander as an area.
amtak is offline
Old 7th May 2013, 22:15   #2470
Thanked: 29 Times
Have booked DIO from Whitefield Dream Honda, white colour. Delivery time quoted is 30-40 days. I was under a impression they are available off the shelf. The waiting period came as shocker!
shijinpr is offline
Old 8th May 2013, 10:22   #2471
longhorn's Avatar
Thanked: 337 Times
Did you check with other dealers? In Chennai the waiting period is more for Dio while the Activa is available off the shelf, but the quoted time of 30-40 days seems to be on the higher side. I got mine in 10 days in August last year.
Old 8th May 2013, 10:39   #2472
audioholic's Avatar
Thanked: 6,144 Times
Guess demand has gone up again and hence the wait. Did you take it under finance? I got mine in two days after I gave the full amount by cheque. Which colour?
Btw my dio is returning just 38kmpl, tankfull to tankfull. Not sure what I must do now. Think I will wait for sometime before taking any action.
audioholic is online now
Old 8th May 2013, 11:01   #2473
longhorn's Avatar
Thanked: 337 Times
I did get a 37.xx figure on a couple of fill ups. The small tank will have a direct bearing on FE readings if tankfull is not actually tankfull (due to air in the tank). My long term average as of now is ~ 45kmpl. If you are getting 38 kmpl consistently, check if the idle rpm is on the higher side. Again, bumper to bumper traffic, waiting at signals for more than 1 min with the engine running, quick acceleration/deceleration, short runs <5 kms etc would take a toll on the FE. I do see a definite 2kmpl jump + a smoother and silent engine in winter when the air is denser.
longhorn is offline
Old 8th May 2013, 11:04   #2474
Rajesh Rawal's Avatar
Thanked: 153 Times
In my 3 months /1100km of ownership i have recorded average mileage between 35-40kmpl.
Still have second service to be done ,the s.a said it will gradually go up.
Rajesh Rawal is offline
Old 8th May 2013, 13:52   #2475
vikash49's Avatar
Thanked: 442 Times
Default Honda Activa / Dio vs TVS Wego!
Originally Posted by vikash49 View Post
Hi Guys,
Please suggest a gearless scooter form among the below candidates:
1) Honda Dio (new)
2) Suzuki Swish
3) TVS Wego
User :
Myself, a 33yr old male. Already have a CBR250 and a Honda City. Need this primarily for running small errands close to home. Very low usage expected less than 3~5kms per day.
My Top Priorities :
- Comfortable low speed ride on bad (read pot holed) roads.
- Good headlight illumination
- Trouble free & dependability
- Stylish looks
- Responsiveness
Not so important :
- Fuel Economy (Mileage)
- On road Price
The Honda Aviator DLX was initially on the top of my list, but i had to strike it off after riding one belonging to my friend as I found the seat height a tad too high for me
So guys, please do give your suggestions and share any feedback / tips regarding any of the above models.
So in Nov 2012, I finally picked up a sporty White TVS Wego
The main points that contributed to my desicion were:
- Telescopic Front Suspension
- Larger 12" tyres bot front & rear
- Gas charged rear shock absorber
- Very convient external Fuel Filler Lid
- Extremely easy to use Centre Stand
- Upgraded 5AH Battery & higher rated (120w) alternator to solve the battery problems faced by earlier gen wegos
- This more powerful electrical system allowed me a simple swap upgrade from the 35/35w H4 OE bulb to a Philips Xtreme Vision 55/60w H4 bulb!
Also, many accessories, some which you need to buy seperately with the Honda, come as OE fitment on the Wego:
- Side Stand
- Indicator Buzzer
- Front glovebox
- Both Number plates
- Floor mat
Last but not least, NO WAITING!
Neither for purchase, not for service!
The fact that our Local TVS service centre remains open on Sundays is another bonus.
Post the purchase, I swapped the OE 35/35w headlamp bulb with a much more powerful Philips Extreme Vision 55/60w H4 bulb
Name:  Xtreme vision1.jpg
Originl bulb..
Name:  OEM Halonix HS1 35w35.jpg
Replaced bulb..
Name:  Philips H4 55w60.jpg
Low beam on friends 1st gen activa..
Name:  Activa low beam.jpg
Low beam on wego with upgraded bulb..
Name:  Wego low beam.jpg
High beam on friends 1st gen activa..
Name:  Activa ligh beam.jpg
High beam on wego with upgraded bulb..
Name:  Wego high beam.jpg
Hope this helps!
vikash49 is offline   (2) Thanks
Closed Thread
Hero announces 150cc Turbo-Diesel Scooter and Dash 110cc scooter CARDEEP Motorbikes 64 1st October 2015 10:24
Gearless scooter on rent in Bangalore? Gandhi Shifting gears 6 5th April 2010 18:58
Now that's what I call a scooter! The genuine scooter company NoMind Motorbikes 0 31st March 2009 15:07
Looking to buy a gearless scooter rascalangel Motorbikes 5 28th January 2009 15:22
Gearless scooter for my dad sathya_j2084 Motorbikes 36 27th February 2008 05:46
