Closed Thread
Old 9th February 2010, 12:03   #961
ravi@64bhp's Avatar
Most of the Flyte owners are not satisfied with the after sales service of Mahindra, including me (I started servicing at a known local mechanic). But, it is great scooter compared to a Dio.
The negatives of Flyte are:
  • Mahindra's after sales service
  • Low ground clearance of 115mm (underbelly hits even normal speed brakers with pilion, sometimes without pilion too).
  • Mileage of around 38-40 kmpl only (some people reported even 30s)
  • 4L fuel tank.
  • Though build quality is great, not up to Honda quality. (the plastics loose their sheen very soon)
  • Initially I have seen many people reportin fuel tank leakage.
  • Though the engine is 125 cc, performance equals to a 100cc scooter only.
  • Difficult riding position if you have a pilion because of small seat.
The plus points over a Dio:
  • Front telescopic suspension gives excellent ride quality and handling
  • Easy and zippy to ride in traffic.
  • The largest boot with LED light on a scooter, which is really helpful.
  • 9 amp battery.
  • Front fuel filling.
  • Key hole shutter.
Keeping aside the negatives of Flyte, I have always enjoyed ridinig it (whenever my wife allows). After two years, it is still going good.
Headlight position in Dio is not a problem. Though it is old model, still looks supersexy due to cool graphix, and infact I loved the Dio of all the scooters in looks.
BTW, did you consider Suzuki Access? It is a better package than Flyte.
ravi@64bhp is offline
Old 9th February 2010, 12:44   #962
wmanu's Avatar
Thanks for the details Ravi, I didn't consider Access because it is above my budget.
Among the negatives you have mentioned, following worries me:
1) Low ground clearance
2) Fuel efficiency (I thought it is giving 40+, red in some review)
3) Fuel tank leakage
wmanu is offline
Old 9th February 2010, 12:56   #963
hiren.mistry's Avatar
Thanked: 255 Times
Among all this talk about scoots has anyone test ridden the TVS Wego? I want buy one for my wifey but apart from the road tests in mags, I have no real world information.
Is it launched? As the website says coming soon ...
hiren.mistry is offline
Old 9th February 2010, 15:01   #964
ravi@64bhp's Avatar
Officially Wego is launched in November. It is a pity that TVS has not sent a single scooter to any of the cities. When I enquired last week here in Hyderabad, they said it may be available in March.
As per the road test by Autocar, Bike India, and Overdrive, it makes good alternative to Activa and Aviator. Rating given 9/10.
Low ground clearance in fact a real worry. If riding single, this does not matter much. The real problem is when you ride with a pillion. Regarding mileage, may be the mileage is 40+ under standard riding conditions. I am sure in Bombay city, it will be near 40. Sometimes low mileage is because of richer fuel mixture. And playing with tuning is not a good idea, particularly with the mechanics at Mahindra service center.
I have not heard of leaky fuel tanks of late, but heard many when Flyte was launched initially. I guess (not proven) some leaky fuel tanks are caused due to underbelly hitting speedbrakers, and you know the fuel tank is located in the floor board and is made of rigid plastic.
If ground clearance and FE of 40 kmpl is not a matter, you can go ahead with Flyte. As I said, there have not been any leaky fuel tanks of late.
Old 9th February 2010, 15:03   #965
Thanked: 1,057 Times
Totally agree with the negatives and positives listed by Ravi for the flyte.
My dad rides a Flyte. He is happy with the front telescopic suspension so much that he says he does not feel tired even after a ride in heavy traffic over pot holed roads. He is 60 years btw. He does not ride the Activa [old shape] or the Dio in the house. He gave up riding geared bikes as well about 10 years ago. But he always complains about the lack of pick up at certain points in the Flyte [AFR issues i think] and also our tank was replaced twice in warranty due to leakage.
FE of Flyte - Best with very sane riding not crossing 40 kmph on the speedo was 38 kmpl which we got. Else its always in the 30-32 range and Kinetic/Mahindra service have not been able to fix the FE issues. Not sure if this is a problem with only our scoot [which i think is not the case as there are others who are reporting low FE]
You can also add the fuel tank capacity of 4L tops which is a pain in the wrong place. Imagine if you happen to be plagued by low FE coupled with a small tank, the number of visits to the petrol pump. Thankfully they have given front fueling and not under seat.
If its a choice between Flyte and Dio, then Dio is a safer bet if you are ok with the leading link suspension [which is not very bad but yes it is not the same as the scoots with telescopic suspension]. Ground clearance is also better than Flyte and you wont have to worry about fuel tank capacity as well.
My $$
EDIT: Headlight position of the Dio is not a problem. The spread is good and bright enough for the unlit stretches of Bangalore roads.
abhinav.s is offline
Old 9th February 2010, 15:54   #966
wmanu's Avatar
Low ground clearance in fact a real worry. If riding single, this does not matter much. The real problem is when you ride with a pillion...
I have not heard of leaky fuel tanks of late, but heard many when Flyte was launched initially...
Thanks Ravi, it looks like I've to accept the low ground clearance as a fact and have to learn to live with it. 40kmpl sounds reasonable for me.
My dad rides a Flyte. He is happy with the ...
FE of Flyte - Best with very sane riding not crossing 40 kmph on the speedo was 38 kmpl which we got....
You can also add the fuel tank capacity of 4L tops which is a pain in the wrong place...
If its a choice between Flyte and Dio, then Dio is a safer bet if you are ok with the leading link suspension [which is not very bad but yes it is not the same as the scoots with telescopic suspension]...
My $$
Thanks for your $$, Abhinav. I'm aware that Dio will be a safer bet than Flyte, but the 20days waiting period is one of the fact which worries me.
The under seat fueling system is another head-ache for me, because I'm so used to the front fueling (bikes) for more than 12years.
wmanu is offline
Old 9th February 2010, 16:14   #967
mail4loys's Avatar
Now that you are sold to Flyte, go for it and enjoy your ride. Remember there is no prefect bike that exists.
mail4loys is offline
Old 9th February 2010, 16:16   #968
JVH
JVH's Avatar
Thanked: 148 Times
The 20 days waiting period should not be a deal breaker. I received mine after 75 days
Are you sure its only 20 days? Its really a big leap from a typical 90 days waiting period.
JVH is offline
Old 9th February 2010, 16:33   #969
nairrk's Avatar
Thanked: 37 Times
Infractions: 0/1 (5)
As I already written in this thread , Flyte is a good scooter minus Fuel economy,
ground clearance,small fuel tank.
I made several complaints to the service people regarding the FE but nothing great they can do to improve the FE. I get between 25-28kmpl which is far too low in this segment?
nairrk is offline
Old 9th February 2010, 16:43   #970
wmanu's Avatar
Thanks Buddy, I think I'm sold. Will keep you updated with the progress.
It could also be a sales strategy, because what the sales paerson said was "minimum 20 days waiting for all Honda vehicles and we'll call you when your vehicle arrives".
wmanu is offline
Old 9th February 2010, 16:47   #971
wmanu's Avatar
Thanks Nairrk. Fuel tank is not an issue for me because I live next to a fueling station.
Fuel efficiency below 30? of course it is far too less for any scooter. There should be some thing seriously wrong! What does the service station say about this issue?
wmanu is offline
Old 9th February 2010, 17:24   #972
agspins's Avatar
Thanked: 311 Times
20-30 days waiting for Honda seems to be okay as compared to here(Nagpur) its still 120 days for Activa and almost similar for other models.Same is the story with Suzuki but at 60 days.Still trying to dodge the waiting periods of both vehicles.
BTW wego was supposed to arrive by mid feb but still its not...could do well amid these waiting periods.Even the site is under construction
http://tvswego.com/
agspins is offline
Old 9th February 2010, 17:46   #973
nairrk's Avatar
Thanked: 37 Times
every service I make a complaint on this FE and they assure that it will be attended but after that the situation remains same. Earlier when the scooter was introduced and marketed by Kinetic (I bought this at that time) , there was a service station near my house. However when Mahindra took over, this guy lost the job and now the nearest service station is about 37 kms away from my home hence not economical to visit them often. Anyway they are now in the process of opening a service station near my place, then I can concentrate the FE matter with them more seriously. Till then I will have to live with what I am getting now?
nairrk is offline
Old 9th February 2010, 17:58   #974
wmanu's Avatar
I'm sure, Mahindra's acquisition of Kinetic will workout better for Kinetic users. So let us wait and see how Mahindra performs, I heard it is covering the market better than expected.
wmanu is offline
Old 9th February 2010, 18:49   #975
ravi@64bhp's Avatar
I agree with you. They have revamped the website and it is really good. The quality of the bikes seems to be consistent now. But, sadly, the service part is left untouched as of now. If they can take care of the after sales, it would be big relief to the customers.
Closed Thread
Hero announces 150cc Turbo-Diesel Scooter and Dash 110cc scooter CARDEEP Motorbikes 64 1st October 2015 10:24
Gearless scooter on rent in Bangalore? Gandhi Shifting gears 6 5th April 2010 18:58
Now that's what I call a scooter! The genuine scooter company NoMind Motorbikes 0 31st March 2009 15:07
Looking to buy a gearless scooter rascalangel Motorbikes 5 28th January 2009 15:22
Gearless scooter for my dad sathya_j2084 Motorbikes 36 27th February 2008 05:46
