Closed Thread
Old 19th June 2010, 21:39   #1246
mail4ajo's Avatar
Thanked: 261 Times
Originally Posted by abhinav.s View Post
Honda leads the roost here. They charge even for the number plates which is ridiculous to say the least!!!
Luckily Access includes everything right from saree guard, side stand, plates etc.
mail4ajo is offline
Old 19th June 2010, 22:27   #1247
prguru's Avatar
Thanked: 19 Times
Even I got Access but I was charged 150 bucks for the plates. I don't know if the side mirrors came free but the plates, floor mat, hand grip, seat cover were charged extra.
prguru is offline
Old 19th June 2010, 23:20   #1248
rk_sans's Avatar
Thanked: 783 Times
Hi All,
I am looking for a gearless scooter for my wife. I was initially confused between Activa and Access, then decided Access but now after the launch of Wego, I am confused again. Any suggestions ?
Any inputs on Wego ? Planning to check it on Monday personally.
rk_sans is offline
Old 21st June 2010, 08:21   #1249
ghodlur's Avatar
Thanked: 2,438 Times
Angry
A couple of queries to Honda Activa users
1) Are there quality issues with the battery in Activa coz day in the morning the Activa does not start with the Self start which means that the battery is drained overnight. Have to manual kick start it and then the self start functions normally during the day.
2) The storage compartment gets unevenly hot after riding the Activa. After a short run when I open the storage area to keep my helmet I find the area too hot. The helmet also gets hot and unbearable to use once kept inside.
Any Activa users observed these issues. I will be taking this up during the second service.
ghodlur is offline
Old 21st June 2010, 09:36   #1250
nairrk's Avatar
Thanked: 37 Times
Infractions: 0/1 (5)
Originally Posted by rk_sans View Post
Hi All,
General opinion is that Wego is worth a look and test drive prior finalising any other Scooters. (the TVS dealer in my place is flooded with people who coming to see the wego and also understand many are doing the booking).
Go, see the scooter and then decide.
nairrk is offline
Old 21st June 2010, 10:36   #1251
Jayant..B's Avatar
Thanked: 7 Times
Hi All,
Have you checked HH Pleasure? It has got the same engine as Activa,it is light and more fuelefficient. And cheaper also.
Jayant..B is offline
Old 21st June 2010, 13:48   #1252
nairrk's Avatar
Thanked: 37 Times
I just came back from TVS Dealer (I went there to collect the Insurance papers of my TVS Jive). I have discussed about the WEGO with them ( just got some details about the vehicle which am giving below - may be useful for some one?).
The special features in this vehicle, as advised them are:
=LED tail lamp with Optical Glow
=Large 12 inch alloy wheels
=Ignition Key glow
=Telescopic Front Suspension (it is there in most of the latest scooters)
=Internal storage (there in other models also)
Engine- 4 stroke single cylinder, air colled, OHC
Displacement : 109.7 cc
Max Oiwer:8ps@7500Rpm
Max Torque: 8Nm@5500Rpm
Transmission: V-matic
Ignition: self/kick
Battery: 12V, 4Ah, maintenance free
Head Lamp: 12v 35W/ 35W Halogen
Tail Lamp: 12V LED Lamp
Chasis:
Dimensions:1834x640x1115 mm (lxbxh)
Wheel Base: 1275mm
Ground Clearance: 145mm
Suspension -Front: In-line Telescope suspension
Rear: Unit Swing with spring loaded hydraulic damper
Tyre Size: Front/Rear: 90/90 -12
Brakes: Front/Rear: Drum. 130mm dia
Fuel tank: 5 Litres
Ex-Showroom price here - Rs.42,500/-
nairrk is offline
Old 21st June 2010, 22:29   #1253
prguru's Avatar
Thanked: 19 Times
Have you tried using the choke and doing a self start ? I remember reading it somewhere that if the engine is cold we need to use choke or use kick to start.
I recently got a Access and seems it is the same case with Access too and you know what they have clearly mentioned that the trunk will get hot in the owner's manual ( See attachment) . Am guessing since the engine part is completely covered there is no enough space for proper ventilation and so the trunk gets heated.
prguru is offline
Old 21st June 2010, 22:56   #1254
rk_sans's Avatar
Thanked: 783 Times
Visited TVS dealer today and had a look into Wego. Somehow i did not like the finish quality of it. Plastics were of low quality. And most importantly Rs.50K on-road in bangalore. Too expensive
Thanks Jayant, this one never came to my mind. Will check it out tomorrow.
rk_sans is offline
Old 22nd June 2010, 08:31   #1255
ghodlur's Avatar
Smile
I have tried using a choke and it does start, however the summer temp are not that cold for the scooter to start on choke. Will take it up with the dealer.
There should have been sufficient heat insulation inside the storage compartment, sometimes it becomes too unbearable to put on the helmet after storing it.
My comments in Bold.
A few days back I got an Extended Warranty of 3 years for Activa costing me Rs 649/-. So apart from the normal warranty of 2 years, I have the vehicle wrranty for 3 more years.
ghodlur is offline
Old 22nd June 2010, 09:33   #1256
nairrk's Avatar
Thanked: 37 Times
Storage compartment getting hot - I think this problem is there in all gearless scooters which have the storage compartment under the seat.
I had a Flyte and anything kept in the storage compartment get heated even after a small ride (more ride means more heat) ?
nairrk is offline
Old 22nd June 2010, 18:54   #1257
mail4ajo's Avatar
Thanked: 261 Times
Please check if 3 more years or for the 3rd year? 6 years warranty that too at peanuts is really hard to digest....
mail4ajo is offline
Old 22nd June 2010, 22:51   #1258
prguru's Avatar
Thanked: 19 Times
So I think the total Warranty period would be 3 years( 2+1 ) as noted by mail4ajo and yes it gets really hot which makes it unbearable to wear the helmet once you take it from the trunk. You are right, they should have put some kind of insulation to at least minimize this. Even I am thinking of taking it up with the showroom guys.
prguru is offline
Old 23rd June 2010, 08:00   #1259
ghodlur's Avatar
Cool
Its 3 years Extended Warranty in addition to the 2 years warranty which comes with a new vehicle. So a total of 5 years warranty for my Honda Activa. As rightly said the EW is for peanuts.
ghodlur is offline
Old 23rd June 2010, 08:19   #1260
prateekm's Avatar
Thanked: 338 Times
+1, my Dio has this problem too. Sai Point said in about 6-7 months after purchasing, you won't have this problem. Though I am still facing the problem after 10 months, it has certainly reduced. You need to use the choke in the morning generally.
I have never faced this problem in my Dio or the old gen Activa.
prateekm is offline
Closed Thread
Hero announces 150cc Turbo-Diesel Scooter and Dash 110cc scooter CARDEEP Motorbikes 64 1st October 2015 10:24
Gearless scooter on rent in Bangalore? Gandhi Shifting gears 6 5th April 2010 18:58
Now that's what I call a scooter! The genuine scooter company NoMind Motorbikes 0 31st March 2009 15:07
Looking to buy a gearless scooter rascalangel Motorbikes 5 28th January 2009 15:22
Gearless scooter for my dad sathya_j2084 Motorbikes 36 27th February 2008 05:46
