| Motorbikes Everything related to the two-wheeled breed. |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: May 2006 Location: Shillong
| Hi freinds, I have a P150 III already covered 15k since 2nd march. Really a pleasure to ride, Minimum maintainance needed till now. The problem is The stock tyres, 2.75 x 17 front and 100/90 x 17 are good but sometimes makes me nervous in wet conditions and since they are tube type, punctures are pain in these hills terrains. I want to use tubeless Tyres in my bike with Tyre Milk, so the issue of puncture is taken care of. Here is Shillong good tyres are very hard to come by, so the best option remains to go for stock Tubeless tyres that comes with P200/220. But again those are oversize tyres for P150. So can experts advice, on the negatives, long term/Short Term of using bigger tyres on my bike? Please note that I tend to ride long distance and my avarage running daily is of around 60~70 km. Thanks in advance. |
| | #2 (permalink) |
| Newbie Join Date: Dec 2005 Location: Mumbai
| After having searched for tubeless tyres for long.. i have reached to a conclusion that the P200/220 tyres are the ones to go for. I know the rear is oversized, and if you are too finicky, you will feel the loss in power, but like i said, there are no other options. Please do not put that tyre milk (or any other puncture resistant material). Tubeless tyres usually dont lose air unless the nail punctures and get out of the tyre. I am myself riding with 2 big nails in my rear tyre for 2 weeks now :P The tyre milk only makes handling difficult and also corrodes the inner wall of rims. |
| | #3 (permalink) |
| Newbie Join Date: Oct 2007 Location: Bangalore
| hey there......the closest city for u to get a really good set of tubeless tires will be kolkota...i suggest u ask someone to look around and get u something from there.....sizes i am not too sure but u can specify the Pulsar 200's sizes. Should fit on the 150...bec my friends Pulsar 150 is running the 200's rear tire without any issues...good luck mate....
__________________ Live life quarter mile at a time - evoVII - |
| | #4 (permalink) |
| @iamkapilb so how often do you have to fill up air in the tyre? I am tired of having punctures, already had 5 all due to nails. Thats why I am thinking of Tubeless. And I am not so much bothered about the pick up or Top speed, Cause I am a very sedate rider, I am looking for harms to the engine, Drive mechanism, Chain, on long term/ short term basis, As you can see, my bike is a very high milage bike, and is very reliable till date and I want it to remain like that only. @evoVII what about the long term reliability, engine wear and tear if any, 'cause I am planing to change both the tires. (Depending on Budget) |
| | #5 (permalink) |
| Senior - BHPian | dude if puntures are your prime problems then there are various puncture kits that you can carry along, and also an eletronic pump to inflate, dont know exact details on this airpump, one of the xbhp guys has it, he says its primarily used by car guys, to inflate the tyre! and if you just run out of the options for the rear tyre then my best next suggestion is that you purchase a honda unicorn's rear alloy wheel alone which is 18inch one and other rubbers and the rear brake set etc this will increase your options to choose more rear tyres that are tube less! also get the nitrogen filled in the tyre if possible this will ensure the longest tyre life and the puntures wont bother you much either! with normal air inflation one needs to check the air at least once a month but this nitrogen one needs to check the pressure at only once in three months intervals! this is much better option than the milk and normal air if its avaliable, it should cost around 15 bucks a tyre! |
| | #6 (permalink) |
| @sumitkalindi I have been using 120/80 MRF TL rear for around 6K kms now and i dont think it does damage to the engine. maybe it does, but how do i know? atleast it doesnt show Logically speaking, it shouldnt.I am not a mileage worrying guy. My 90% commute is on highways and the way i ride i get around 40-41kmpl from my P150 irrespective of tyre - I have tried the normal tubetype MRF, Low profile tubeless Duros and now this P200's MRF. I fill air everytime i fill petrol. That ranges from 4 times to 1 time a month. All i can say is, if you want to shift to tubeless, and unless you have the moolah to import tyres, go for MRF front and back. They are absolutely worth it! |
| | #7 (permalink) |
| Thanks @kapil this was the info I was looking for. BTW are the rims for 200 and 150 same??? About my checking tire pressure it is same, only difference is I have to fill almost every week, so this should not be any problem. Last edited by sumitkalindi : 7th November 2007 at 20:08. |
| Thread Tools | |
Similar Threads | ||||
| Wanted: Landrover Series II or III | BlackPearl | Shifting gears | 3 | 21st January 2008 13:49 |
| pulsar150 dtsi ug3 problem | sujit007 | Motorbikes | 5 | 31st January 2007 12:24 |
| upgraded version version of unicorn or pulsar150 dtsi | sujit007 | Motorbikes | 6 | 5th January 2007 08:34 |
| About Bharat I/II/III Pollution Norms | mithun | Technical Stuff | 3 | 27th February 2006 12:59 |
| Euro III WagonR | gkrishn | Test-Drives & Initial Ownership Reports | 16 | 13th March 2005 16:35 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462
