Go Back   Team-BHP > Around the Corner > Motorbikes
Motorbikes Everything related to the two-wheeled breed.
Thread Tools
Old 10th November 2007, 22:42   #1 (permalink)
dustDevil's Avatar
Default RD350: Trouble after up-jetting
Guys, I own a 1988 Yamaha RD350, which I got about 6 months ago. When I decided to go in for modifications, I first decided to get rid of the stock air-box (which almost everyone has told me is pretty restrictive).
So I got myself a pair of cotton filters and upgraded to 150 jets (main).
The result was very pleasing in the begining, but with more city riding I noticed a rather irritating PROBLEM:
The bike sounds and moves well as long as it is accelerating, but as soon as it reaches a constant speed (at a constant throttle and mostly at moderate revs) it makes a very bad spluttering noise. It seems as if all systems have gone out of sync. There is no jerking though! But again, this does not happen at full throttle!
What might be the problem? Is it happening because I've left the pilot jets untouched? Help!
__________________
Motorsport is the only 'REAL' sport.... all others are just Games!
Aalap Patel
'97 Zen
'88 RD350
dustDevil is offline   Reply With Quote
Old 10th November 2007, 22:47   #2 (permalink)
straight6's Avatar
Contact rohit arora on 9820111242, he is very good with rd's & has an official yamaha service center. He will guide you and take care of this problem.
straight6 is online now   Reply With Quote
Old 10th November 2007, 22:59   #3 (permalink)
spluttering at steady throttle means that the bike is running very rich. nothing odd considering the jetting you've done. if you are able to attain explosive acceleration and top end performance with the 150 jets then perhaps you have to live with the low speed constant throttle splutter. besides am sure that your mech knows what he is doing.(?)
an rd on stock jets itself splutters a bit in slow city traffic but once its given a few blasts of acceleration and the engine temperature is up the splutter becomes minimal.
__________________
life is a beach....enjoy it!
surYa
hollywoodhogan is offline   Reply With Quote
Old 10th November 2007, 23:46   #4 (permalink)
The fluttering sounds like your running rich around half throttle. Might want to try dropping the carb needle by a slot.
sharan666 is offline   Reply With Quote
Old 11th November 2007, 08:58   #5 (permalink)
dustDevil's Avatar
I was suspecting a rich mixture. But my mech says its not a problem.
The bike really is a pain in the city. Will try playing around with the needle!
Thank you guys!
__________________
Aalap Patel
'97 Zen
'88 RD350
Old 12th November 2007, 12:43   #6 (permalink)
topend_hooligan's Avatar
Dude, are those 'jets' you've put the right kind? Mikuni follows 2 completely different numbering schemes for its round head and hexagonal head jets. What you wanna try is a original hexagonal head mikuni jet. You should get pairs of sizes ranging from 150 to 200.
I'm pretty sure that one of your pilot jets has dirt OR airscrew is set incorrectly. When you accelerate, you open the throttle and hence most of the fuel sucked by the engine is through the main jet circuit. When you settle into a 3000-5000rpm cruise, the throttle is barely opened past 25%. The pilot circuit plays a huge role in carburation till that throttle opening and hence any problems in the pilot circuit would show up at low thorttle cruising. Once warmed up does the bike idle well on both the cylinders?
__________________
Signatures dont make you smarter.
topend_hooligan is offline   Reply With Quote
Old 12th November 2007, 13:08   #7 (permalink)
Jaggu's Avatar
what are the porting specs? what size pistons and whats the condition of the engine otherwise? whats the kind of ignition you are using and the timing set?
Its easy to blame it on jetting, but to set it perfect there are lots of other parameters that need to be corrected.
take it to a good professional workshop.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 13th November 2007, 12:49   #8 (permalink)
dustDevil's Avatar
The bike is stock (porting-wise) and am running an RXG CDI-kit (atleast for now). The piston is also OEM (not an over-size)
The problem got worse yesterday. Bike ran as if on a single cylinder. The right cylinder was giving excessive smoke! Took it to the mech, and on checking it we found:
1) The bike was actually on one cylinder.
The right carb was flooding and also the oil-seal between the gearbox and the right side of the crank-case had leaked. The bike was sucking in oil! Eventually plugs got fouled, and the cylinder stopped firing!
2)The right carb was flooding because the float level was excessively high.
(I have no clue how that could happen on its own)
3)Put forward the idea of dropping the needle... but my mech was against it.
For now, the plug has been cleaned and re-installed. The float level has been corrected and the carbs have been re-tuned with the same jets.
On a short test-ride, the bike seems to run well (except a little extra smoke from the right cylinder). I have been advised to avoid using it much till the oil-seal is replaced.
__________________
Aalap Patel
'97 Zen
'88 RD350
Old 13th November 2007, 12:54   #9 (permalink)
dustDevil's Avatar
@topend hooligan: Ya the bike did idle well after warming up! And after re-tuning the carbs, things are better!
__________________
Aalap Patel
'97 Zen
'88 RD350
Old 13th November 2007, 13:02   #10 (permalink)
moralfibre's Avatar
Aalap, where did you get jetting done on the bike in Pune?
__________________
"As long as there are short, balding, middle-aged men, there will always be a market
for the Porsche 911." - A BMW Owner. :)
moralfibre is online now   Reply With Quote
Old 13th November 2007, 13:08   #11 (permalink)
dustDevil's Avatar
@MF: There's this guy near salisbury park! I got the bike from him, so now I get my usual servicing and repairs done at his workshop.
__________________
Aalap Patel
'97 Zen
'88 RD350
Old 13th November 2007, 13:27   #12 (permalink)
Jaggu's Avatar
a) fix the air leak
b) ensure carb float level and all the circuits are in order
c) tune and time the bike (plugs, timing and syncing)
__________________
Old 13th November 2007, 15:20   #13 (permalink)
moralfibre's Avatar
Original pistons were from ART. Are you sure you have the ART pistons?
BTW are you using the oil pump or have bypassed it? Its safer to add oil in petrol since using the oil pump means setting it on the markings everytime you set out for a ride.
__________________
Old 13th November 2007, 15:38   #14 (permalink)
dustDevil's Avatar
No, no.... they are not ART. It was a mistake on my part! By OEM I meant the original size. The seller tells me they are TKR. I'll be opening her up by next month, when my exams finish. Only then I can confirm!
Ya, had bypassed the pump the day I got the bike! Have been adding oil to the fuel eversince!
__________________
Aalap Patel
'97 Zen
'88 RD350
Old 13th November 2007, 17:25   #15 (permalink)
moralfibre's Avatar
TKR I believe were RD350 LC pistons? Anything other than ART used on bikes are prone to Piston slapping since you have to keep a slightly more clearance otherwise the engine packs up. This is little I learned when we restored a friends RD way back when I just got out of school. Give me a shout when you open up your bike. I know of a VERY renowned and silent guy who works on SBK's in the backyard of his house. Not many people know of him but he is the guy you must show your bike.
__________________
Thread Tools
Need RD350 Studboy_441 Motorbikes 3 8th February 2008 07:02
Rd350 greatmana2000 Shifting gears 2 8th August 2007 11:46
Need a RD350 jessie007 Motorbikes 18 30th January 2007 16:01
what is jetting devsus Motorbikes 8 17th April 2006 22:51
Jetting For My Pulsar 150 nikibusa Motorbikes 18 22nd March 2006 02:00
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
