Old 16th December 2008, 05:30   #31
akshay4587's Avatar
Thanked: 1,686 Times
Originally Posted by Joe M View Post
Has anyone used the ABS marketed by SafeRide? Saferide ABS. It can be fitted on any bike with hydraulic disk brake, and can be installed easily. I was planning to fit one, but haven't read any user review anywhere. It costs only Rs 1500/-, and if it works, I think it's a good bargain.
Does anyone have info about it?
It does work to some extent.
Bike India people had tested it some time back
Its available at KRP Delhi for around 700 bucks.
Old 16th December 2008, 08:39   #32
Sankar's Avatar
Thanked: 4,654 Times
How does it work? What's the basic principle behind it's working? Anyone know, i would like to know.
Old 16th December 2008, 08:53   #33
akshay4587's Avatar
KRP introduces a low-cost Anti-Lock Braking System imported from China Powerful front discs on powerful bikes are always a tricky affair to handle. While proficient riders modulate the hydraulic pressure effectively to handle emergencies, without locking the brakes, the case is not the same with their inexperienced counterparts. Squeezing the front brake lever is usually a common reaction by the not-so-honed rider in case of a predicament. The brake pads cling on to the discs, full force, locking the system, the front tyre slides, loses grip, the rider loses control, lands into a mess, and usually doesn’t come out of it without an injury.
Anti-lock-braking systems prevent the brakes from locking up, providing the rider more control in case of an emergency. The system allows the wheel to turn even when the brakes are slammed completely, lending the bike manoeuvrability even in panic situations. However, being very expensive and complicated, it’s not a viable option to install a proper ABS on bikes. Especially in a market like India where the economies of cost are the primary drivers for sales and even disc brakes are considered a luxury, it’s a very far fetched dream to think of installing such a system for the sake of biker safety.
So when we were offered a small one-piece kit, with ‘Motorcycle Hydraulic Anti-Lock Brake System’ neatly written over it for testing, we were more than amazed. The surprisingly small unit from Zhaoxiang Automobile & Motorcyclefittings Company of China costing a mere Rs 660 appeared nothing less than a miracle to us. Excited about the promise that the product held, we wasted no time and went straight ahead to test it on an Indian bike. We fitted it on a Hero Honda Karizma to find out the difference in brake feel, braking distance and time that the unit offered.
The gadget is quite simple in its operation and prevents the wheel from locking up by modulating the oil pressure on the calipers when the front brake lever is squeezed. Beyond a certain pressure point, it releases the pressure on the calipers, reducing the pads’ grip on the disc in turn, and thus allowing the wheel to turn. What remained to be seen, however, was how effective the system was in real life situations.
Fitting the system on a bike is no big task: you just have to remove the brake hose from the caliper unit and connect it to the ABS unit, while joining the other end of the system to the caliper unit. The unit that we got for test, however, was compatible only with ‘Nissin’ brakes. The oil seal for the fitment started dripping the moment we fit it, and had to be replaced to make sure that the oil didn’t leak. Even an additional washer was required, which was not provided with the unit.
Off we went, slamming only the front brakes for a number of runs, both, with and without the system. The unit worked wonderfully well for its size, mechanism and price. Okay, the brakes did lock up with the lever squeezed in the fist, but it surely prolonged the locking up state to a fairly distant point, as compared to what we could achieve on runs without the system installed. The effective braking time and distance too reduced, and that was a really pleasant surprise. The system does work, no doubt. In its own, limited way, if not like a full-fledged, electronically controlled ABS with all the techno-gimmickry of the world and an obscene sticker price, this little gadget makes a lot of sense. Bottom line, the inexpensive, compact unit, does justify being called an Anti-Lock Braking System and does prevent the wheels from locking up, up to a fairly reasonable extent
Source-Bike India/xBhp
Old 16th December 2008, 10:17   #34
Thanked: 159 Times
@akshay4587 Thanks a lot for the details
When I contacted the SafeRide people, they said that they have done some in-house testing, and ARAI testing is in process, and they'll be getting it certified soon.
Is the ABS system sold by KRP available for Unicorn? [ Unicorn has KBX brakes].
Which one could be better, the KRP or SafeRide?[I don't mind the price difference] The SafeRide system seems to be fully developed and manufactured in Mumbai, by EATA group.
Joe M is offline   Reply With Quote
Old 16th December 2008, 10:25   #35
akshay4587's Avatar
You can contact them on Kaulson@vsnl.com
for info regarding Unicorn.
Old 16th December 2008, 11:25   #36
hillram's Avatar
Thanked: 982 Times
This is amazing to me..ABS for Bikes...can these be fitted to ay bike?
What about for legendary Power horses like RD 350 and Enfield Lightning.
hillram is offline   Reply With Quote
Old 16th December 2008, 11:40   #37
Thanked: 159 Times
They say it can be fitted to any bike with hydraulic disk brake. It is a very small & simple equipment. They have given a video demo also, on how to fit the thing. [ it is available in www.saferideabs.com]
I too find it a very amazing thing, at such a cost .
Old 18th December 2008, 11:21   #38
Thanked: 25 Times
Infractions: 0/2 (9)
Wenzhou Zhaoxiang Automobile &Amp; Motorcyclefittings Co.,Ltd.
Is this the original company? The products contain ABS...
Ramki.
ramki067 is offline   Reply With Quote
Old 18th December 2008, 13:46   #39
Thanked: 25 Times
Default KRP email.
This is what KRP had to say about ABS, please see the attached file. Is it trustable to transfer amount to any account like they said in the mail?
Ramki.
Old 27th January 2009, 14:09   #40
knp
Thanked: 18 Times
krp website is updated now and they have provided their account details in their website. I guess it should be fine to transfer.
knp is offline   Reply With Quote
Old 30th June 2009, 01:59   #41
This ABS device seems like a really good thing. and its cheap too.
Does any know how it works ? Pressure valve ?
Also has any one else fitted it. Would be nice to have some more reviews of it.
Basic is offline   Reply With Quote
Old 2nd August 2009, 19:25   #42
fireblade007's Avatar
Thanked: 56 Times
Can this be fitted on to the rear disc breaks of apache rtr 160/190 or the pulsar 220? In my opinion the rear wheels has more chance of skidding by getting the wheels locked.
fireblade007 is offline   Reply With Quote
Old 2nd August 2009, 22:36   #43
mithun's Avatar
Thanked: 59 Times
Might be possible since there is not any tech difference between front & rear discs.
Old 8th February 2010, 15:38   #44
shishir_bn's Avatar
Thanked: 108 Times
Default TVS RTR 180 Concept Bikes With ABS
MODS,if this thread already exists then please merge accordingly
__________________________________________________ _________
Source : TVS RTR 180 Concept Bikes With ABS
Fuel Injection, Delta Frames, Disc Brakes, Digital gizmos are the desires that every young man wants to be an integral part of his life. So far no Indian company has evolved with their bikes, but TVS seems to be taking much interest in different technological stuff and even Bajaj is there with TVS. TVS already has one of the finest motorcycles in India in the form of TVS Apache RTR 180 which is not only one of the fastest in production but also upholds the tag of being the best stopper among all the machines produced in its segment in India.
And apart from the gorgeous features that this bike offers TVS has taken up the concept of installing this bike with an ABS pretty seriously. The new Apache RTR180 with ABS was showcased in the 2010 Auto Expo. With a majority of Indian consumers still sticking with the conventional 100cc economical bikes TVS would take some time firming their feet in the auto sector with this new marvel.
ABS: The bike loaded with ABS consists of a sophisticated Hydraulic Electronic Control Unit (HECU) and speed sensors which continuously keep a track of the speed of the wheel. As soon as it senses a possibility of a wheel lock, the control unit alters the hydraulic pressure in the braking system which doesn’t allow the wheel to lock up and hence, the rider doesn’t lose control of the bike.
RLP: In addition to the standard ABS functionality, TVS also has couples it with RLP which stands for Rear Wheel lift-off Protection. As the name is suggesting this system doesn’t let the rear wheel getting lifted in air in case of an emergency braking. As soon as the unit senses the rear wheel lifting off the turf, the front brake pressure is released for an instant which ensures that the bike is safely grounded at all times.
Technical Specifications Of Apache RTR 180 With ABS
Function: ABS + RLP
Hydraulic: 4 Valves, pump &LPA
Electronics: 12 Volts
ECU: Integrated
Valves: Digital Control
Communication: K-Lin
  • TVS Apache 180 RTR Dimensions
  • Height: 100mm
  • Length: 2085mm
  • Width: 730mm
  • Ground clearance: 180mm
  • Kerb weight: 137kg
  • Fuel tank capacity: 16 liters
  • TVS Apache 180 RTR Engine
  • Engine capacity: 177.4cc
  • Engine type: single cylinder, air cooled 4st
  • Max Power: 17.3bhp @ 8500rpm
  • Max Torque: 1.58kgm @ 6500rpm
  • TVS Apache 180 RTR Gear box
  • 5 speed
  • constant mesh
  • TVS Apache 180 RTR Fuel system
  • Fuel: Petrol
  • Type: carbureted
  • TVS Apache 180 RTR Suspension
  • Front suspension: Telescopic hydraulic fork
  • Rear suspension: gas shocks
  • TVS Apache 180 RTR Tyre
  • Front tyre: 90/90 x17
  • Rear tyre: 110/80 x 17
shishir_bn is offline   Reply With Quote
Old 8th February 2010, 20:49   #45
bivin's Avatar
Thanked: 114 Times
now that is a really neat feature!! could be very useful on highways when the dogs go jaywalking!!
nice one TVS!! please price it right though...
bivin is offline   Reply With Quote
Government could make ABS compulsory for two-wheelers Aditya Ride Safe 38 22nd December 2014 09:27
TVS Motors to launch five new two wheelers in India JayPrashanth Motorbikes 7 28th December 2013 10:17
TVS Apache RTR 180 ABS launched! First Indian bike with ABS GTO Motorbikes 37 3rd June 2011 17:35
My friend has got an offer in Dubai-Is it a good offer ? snaronikar Shifting gears 50 14th June 2010 16:27
Bajaj Alianz Car Insurance offer: is it a good offer amya Indian Car Loans & Insurance 7 25th January 2008 12:08
